Question about Sony RMT-D152A Remote Control
Sony Remote Control RMTD152A All of a suddend the buttons on the remote seem to be scrambled. When I push pause the video goes to menu. When I push enter to select play, the dvd player shuts down. When I push up or down on the volume control, the dvd player shuts down. Some buttons seem to be working okay. It's the ones that I use frequently that aren't working properly. Why all of a sudden? I just put in fresh batteries. I don't know what else I should do. Any advice?
    Novelist:
  • 133 Answers
If there is a stuck button (or buttons) on the remote it may behave weirdly, also in such a way that you described.
If this is the case, you just need to disassemble the remote and clean all the parts well with some ethyl alcohol.
All the parts means the rubber pad with buttons, circuit board with contact tabs and the housing.
When you clean the housing, be sure to clean all of the holes for the buttons, this is where the dirt accumulates and makes buttons stick - it keeps them pressed so the remote gets weird as you press other buttons.
If it's not that, then it may be damaged contacts, faulty solder points (battery tabs, capacitors, quartz, LED) or something else.
regards
3rq8 (Triarcuate)
Posted on Jul 26, 2009
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
Tip
Region free code for LG 3000
Code 1:
Press the Pause button on your remote control.
Using your remote control enter the code 3, 1, 4, 1, 5 and 9.
Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2.
Power off your player and wait a few seconds.
Power on your player
Code 2:
Press the Setup button on your remote control then, Step, Next, Up and Down.
Select the region of your choice or Bypass for region free.
Save and then Exit the menu.
on Mar 07, 2010 | Televison & Video
I have a LG HR559d blue ray Is there a region Crack for this model
These are not for your model, but you can try them anyways.
LG 2300
With "no disk" on tray, press sequentially in the remote control PAUSE,3,1,4,5,9:
code -- will appear in the display. Enter the region or 0 for region free.
LG 3000
Press the Pause button on your remote control. Using your remote control enter
the code 3, 1, 4, 1, 5 and 9, Press the 0 button on your remote control for Region
free, 1 for Region 1 or 2 for Region 2. Press the Pause button on your remote
control. Power off your player and wait a few seconds. Power on your player
Or
Press the Setup button on your remote control then, Step, Next, Up and Down, select the region of your choice or Bypass for region free, save and then Exit the menu.
LG 3200E, LG 3520, LG 4351, LG 4721P, LG 4730, LG 4821P,
LG 4950S, LG 5083, LG 5822N, LG 593W
Mar 09, 2011 | Audio Players & Recorders
I have a Sony DVPNS501P ProgressiveScan DVD/CD Player and my remote died. I bought a universal, but it won't control the menu option...so i can only turn it on and off and press play, stop or pause. The...
You need a learning remote control or check e-bay. Almost any Sony DVD remote will work. 10-20$ If you list the model # of the remote I may even have one. Hope this helps
Aug 17, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
How do you test a remote?
Tune AM radio to 600 and turn up volume. Place remote nest to antenna and press every button. Each one should cause radio to emit sound. If button does not emit sound that portion of remote is fubar. And you can get the remote for the changer for lot less than 30 bucks Go to attached link 50results for dvp cx995v
Sep 04, 2017 | Sony RM-ASP001 Remote Control
Ps3 blu-ray remote control instructions
you use the ps button on the remote (if you have the correct remote for your ps3) the ps button is clearly marked and is found just above the SELECT and START buttons
Sep 21, 2008 | Sony Playstation 3 (PS3) Console
Autopause
You will need the Sony Remote Control RM-D7M to put auto pause on sony mini disc players.
On the remote control you will see a button with A.SPACE above it.Press it 3 times. Dead Easy..
I hope this cures all you people who think they bought the wrong mini disc player.
You CANNOT put auto pause on using the scroll menu.
E-mail me at wmcdrum@yahoo.com if you need anymore info on MD players. Good Luck.
Apr 30, 2008 | Audio Players & Recorders
PCS-1
Reset password sony pcs-1
1. Access the Setup menu as follows:
Press and hold the MENU button on the remote commander.
2. Select Dial using the �� button on the remote commander.
3. Access the Service menu as follows:
Press 7 then 2 on the remote commander (without pressing the
PUSH ENTER button).
The Service menu appears. (See Figure 1.)
NOTE: To cancel Service mode and return to the Setup menu,
select Cancel using the arrow buttons, and press RETURN.
Jan 18, 2008 | Sony PCS-1 (PCS1) Video Conference
Sony 36' TV Volume Goes up on own/Stuck on Video 2
There's a setting in the menu. I think it's called "smart audio". It's supposed to adjust the volume automatically for commercials. But I don't think it works that well. Give that a try.
Jan 09, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Closed Captions
plz contect me we repair lcd plasma and projection tvs
Yogesh-9811440932
Dec 03, 2006 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Televison & Video Logo
189 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
