How do you set a timer recording for the VCR for this model?
  • truahyovel Aug 07, 2009
    It is Daewoo model # DV6T834N. It is a combination DVD player and VHS VCR.
    Brigadier General:
  • 7,191 Answers
The detailed steps for setting timer recording are as shown in the images below:
To confirm or cancel timer recordings: 41e3613.jpg
You can set and view timer recording program by pressing PROGRAM button on the remote. Make sure to set the date and time before setting timer recording.
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Posted on Aug 07, 2009
  • AliTech110
    AliTech110 Aug 07, 2009
    Waiting for you feedback. Is your problem now solved or do you need further assistance? Please reply. Thanks.
Hi there
Please confirm the model of the VCR.
Thank you
Posted on Aug 04, 2009
    President:
  • 1,734 Answers
For which model?
Posted on Jul 24, 2009
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
I'm thinking of buying this VCR/DVR combo - Toshiba DVR670 -- but first I want to know if you can program the VCR recording timer using time span information -- not just those codes for programs you find...
Usually, depending on the source, or channel, timer recording can be performed on a VCR; even this model.
The short answer is YES - you can record cable times or set manual scheduled recordings on this VCR. It depends on the channel(s) available in your area, and/or the source (such as cable receivers/set top boxes, etc.) which are intended to be recorded.
Feb 09, 2010 | Toshiba DVR670 Player
Samsung DVD-4600 won't record with VCR timer set
Press fast forward and rewind button on the unit simultaneously for 10 seconds with no disc inside the player to reset it to factory setting.
Aug 19, 2009 | Samsung Televison & Video
Cannot record VCR thru Cable Box
make sure that the cable runs first through the cable box then through the VCR then to the TV.
if you know how to set timers on your cable box (if you have that option), set those in addition to your VCR timer. If you don't have that feature or are not sure, you will, unfortunately, have to keep the cable box on a certain channel before you record.
hope this helps!!
Feb 10, 2009 | Panasonic Televison & Video
Orion vcr recording
I'm sorry, but the speed cannot be changed without the remote.
Nov 07, 2008 | Orion VR213 VHS VCR
Won't timer record
- Does it have a tape inserted?
- Is the clock set?
- Is VCR off? (has to be off to be in timer mode for many VCRs)
- Is it recording but just plays back blank or does it not even start?
- If recording blank, make sure you are giving it a signal (Is your monitor hooked to the VCR output?)
- If timer doesn't start double check timer settings - they can be very tricky.
Nov 06, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
How to set the vcr to record
Hi I'm not familiar with your model in particular, but normally there will be a timer button on the remote that you must press, or you must turn the vcr off after programming it for the timer recordings to be made. There should be a timer indicator on the front, either a symbol or a red light depending on the age of the vcr. If you program it, then press the timer button on the remote, the timer light should be on and the vcr will shut itself off, if it is the other type, then the timer indicator should stay lit when you shut off the machine. If that light is on, then your timer recordings should work. Hope this helps, good luck!
Feb 06, 2007 | Hitachi VTMX4510A S-VHS VCR
Toshiba M674 Lost Remote can't change tape speed
Is this an older VCR? If you can set the timer on the VCR itself
like on an older model you can set the timer and set it to record
in another speed. But if you can't do this. You are stuck at
recording in sp. If you can set the timer, if you make just
one mistake it may not come on at all. That's why vcrs
are not as reliable as dvrs. if you don't want to miss a show
diffinatly make sure you re at home and see it come on
like fill up the whole tape and put the show on the end of the tape. like a 2 hour movie comes on a 8pm-10pm set the
timer at ep speed to come on at 4:05pm- 10:05pm and put a 2 hour tape in it. in ep it will record for 6 hours. tape will stop
automatically so you will record it, and it will be on the tape
at the end. that's the way i do it. if I'm not going to be at home
if i really don't want to miss a show at all. because when you set the timer it still might not come on if you see it on you know
its going to record it.
note its cheaper to just buy a new vcr than buying a $72 remote.
you might as well do that if it is a newer model.
I bought an older model vcr in a thrift store for $10 and it worked good for a year for recording shows. I got lucky I guess.
it didn't have a remote I use the timer to set the ep speed
to record.
Nov 22, 2006 | Toshiba M674 VHS VCR
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
