Iwant to know what is shadowing and disable the memory. i want to reinstall the os but later on an error occurs and informs to disable or cachoing memory. so what is the solution
  • 192 Answers
Restart your computer, and when it is restarting, press the F8 key and using the arrow keys, select to start your computer in safe mode. While in safe mode, you should then be able to reinstall your operating system without any problems. If you require any further information, please write back.
Thanks for using FixYa.
Posted on Jul 24, 2009
Dell Inspiron 1525 Error Code 0333 Blue Screen of Death:)
Hello
If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps:
Check to make sure any new hardware and software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any windows updates you might need.
If problems continue, disable or remove any newly installed hardware/software, disable BIOS memory options such as caching or shadowing your computer, press F8 to slct Advanced Startup options, and then select safe mode
it could be a memory (RAM) problem. Many Dell's have a Diagnostic partition on the Hard Drive, accessed by F12 at initial boot up. If yours has this, run a complete diagnostic and see if there are any errors.
Try to reboot in safe mode using "last working configuration" and do an evaluation and see what comes up
Apr 15, 2011 | Dell Inspiron 1525 Notebook
Operating sysmtem not found. Cannot re-install either. Blue screen saying to disable shadowing and cacheing in BIOS!!! Cannot access F8. Installed new hard drive and the same message.
If you have a new hard drive,it must be formatted and the OS must be reinstalled upon it. You are getting this error because there is no OS on it currently, according to what you are telling us here.
thanks for using FixYa.com
Positive comments are always welcome
a
Oct 27, 2009 | Computers & Internet
RE-INSTALLATION PROBLEM
it doesn't seem to be cpu. have you tried to update bios? download usb bootable latest version of your bios and give it a shoot. if it does not help, try use external cd drive to reinstall os. press f9 at startup and choose usb hard drive. oh, one more thing-this may be memory corrupt, but not likely. test it in the bios.
Sep 09, 2009 | HP Compaq 6735s Notebook
Blue screen on my P.C.,windows shut down
If you are using an AGP or PCI graphic card try disabling the on board video adapter from BIOS.
Ensure that you have the latest drivers for this video card installed.
If the video adapter is using shared memory, then you may have a faulty RAM module.
Reinstall Direct X and any graphic acceleration software.
Go to BIOS and disable memory caching and shadowing options, this usually does not solve the problem, but you never know.
Contact video card or Motherboard manufacturer, there may be an issue between video adapter and your motherboard, or the specific software that you are using. In that case manufacturer may require to download a patch.
May 16, 2009 | Palit Microsystems GeForce 8400GS,, PCI...
Why Disable BIOS memory options such as caching or shadowing ? and how to disable it in bios ?
This particular error would typically indicate a problem with memory mapping associated with a peripheral device. I was unable to locate a hit for okfu53.sys, but most likely this is a device driver of some type. The instruction to disable cache is a holdover from old hardware and operating systems and is most likely not actually applicable- however by disabling it is just two areas that are memory users that you don't need at that point. Frankly I would just reboot. If you see it again reinstall the video drivers.
May 15, 2009 | Microsoft Windows XP Professional
Error: Page-fAULT_In_Unpaged_ area. Diable BIOS
Nine times out off ten this message is caused by defective memory. If you have more than one stick in the computer, pull them and test them one at a time until the problem triggers again.
Try taking the computer into Safe Mode and see if you still get the message. If you do, then its DEFINITELY the memory.
Feb 27, 2009 | Dell XPS 400 PC Desktop
Bad Pool Caller message??
BAD_POOL_CALLER is a stop error message that is caused because of problems with the memory management.
There is a list of more than thirty such causes that can give you this error message. If the stop error is consistent every time the system is rebooted, the following method will be effective in solving the problem:
* The hardware and RAM should be checked initially.
* Boot the system once again using the OS setup CD, or use a boot setup that has a GUI like BartPE.
* With RunScanner it is possible to use a memory test tool.
* Select a single account
* If all the accounts open then the system registry hive might be the problem.
* Locate the hive damaged and rename it, do not delete it.
* Create another hive from the backup or from the restore point.
* Initially uses the latest one and keep checking the restore points that come later.
* Avoiding harvesting any replacement hives from the hard drive booted Windows.
* After which compare the hives for differences.
This is one of the ways of fixing BAD_POOL_CALLER errors. Another method is to reinstall the OS but occasionally shows a disk read error or an error on the same lines. Switching the computer off for a minute or more and then switching it on can solve it since the error is only a slight glitch in the system operation.
The BAD_POOL_CALLER is seen for the first time after installing a hardware or software it is recommended that the computer be restarted. If it doesn’t solve the problem, the installation of the hardware or software should be checked for corrections. If the problem persists the installed hardware and software should be disabled, and the BIOS memory options like caching or shadowing should be disabled too.
The safe mode can be used as well to remove or stop components.
To enable the safe mode just press F8 when the machine is being restarted and select it from the Advance Startup options and correct the problem. The installation of the graphics card is another reason the BAD_POOL_CALLER error shows up. A simple reinstallation of the driver can solve the problem.
Microsoft has also acknowledged that the BAD_POOL_CALLER Stop 0xC2 error pops up when trying to print a document that contains a corrupt font.
A hot fix is available at www.support.microsoft.com
Jan 10, 2009 | Computers & Internet
Just use ORIGINAL OS CD and repair OS everything will work fine!
Dec 27, 2007 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
