Question about Cobra 19 DX IV CB Radio
Need to know where modulation diode is so i can replace
  • 33 Answers
Dm1 next to transformerneed to know where modulation diode is so i can - 9da19ae.jpg
Posted on Jul 28, 2009
  • Ed Paparo Jul 28, 2009
    the one with the leg up!
Need help identifying a SMD diode
BAV70T it is a switching diode.
Apr 23, 2014 | Cars & Trucks
The picture looks bowed, centre portion shrinked. More like a convex image.
The E-W correction circuit or the modulating diodes from the horizontal drive have failed. The tv must be opened and the presence of the modulating signal checked: if the signal is missing then the E-W circuit has failed and you will have to check and fix it; if the signal is there then one of the diodes from the modulator has failed - identify it and replace it.
Apr 24, 2011 | Televison & Video
Gme electophone tx 4000.is it possible to turn up mic gain on my uhf rig?if so which pot do i turn?thaks in advance ajax66
  • To boost modulation you need to add another diode in series to the diode located next to C92, it will reduce the power a little bit but it does help give the radio more modulation.
  • The AMC itself is the middle pot under the wires towards the front.
  • If you want to do a receive alignment you need a Oscilloscope. Peak on Ch19 T1 - T2 - T2a - T3 - T4 - and do this with a little signal level as possible from the Oscilloscope. Then set the Oscilloscope to -67dB output no modulation and adjust RV1 to not quite light the +30 LED.
You are now set.
One more thing, The finals are a strait drop in. So if one goes just drop in a replacement.
Regards, Tony
Apr 24, 2011 | Radio Communications
Part Number of laser diode (Mitsubishi), Sharp Copier AR-M160.
L6 code means the motor is not working. You need to replace that, which means replacing the entire laser module. They can be gotten cheaper used from your local sharp dealer. I know this because I work on these things every day, being a certified sharp tech. L6 code means motor lock or motor sense dead, not necessarily laser dead.
May 25, 2010 | Sharp (SHRAM900) All-In-One Laser Printer
Fan on heater works on high only is it a diode
It is the blower motor resistor module.On passengers side by the blower motor.Under the dash.Make sure the connector and wires are good.If they are then just replace the resistor module.If they look like they got hot na d melted.Replace both.Hope this helps.Good luck.
Feb 01, 2010 | 1999 Dodge Intrepid
I need to replace the diode on a 4.8 volt NiCad 400m rechargeable
If you de-solder the diode, there should be a number on it i.e. 1N4000. You may need a magnifying glass depending on how tiny you can read. Once you know the number, you can go to DigiKey or another online electronic parts supplier and order it.
Mar 19, 2009 | Uniden HH9485 - Drop in Charger Fits the...
Daytime running lights not working
a diode is just more than a buck at radio shak. but its probly dtrl relay under the hood at fuse box-distro box.
Jan 24, 2009 | 2005 GMC Yukon Xl Denali
Cobra 29 LTD CLASSIC C.B.
You should not cut the modulation diode, you should adjust the potentiometer VR-4 for full modulation. By cutting the diode, you risk over modulating. By turning up the pot, you can correct for an over modulation.
If you are still insistent on cutting the modulation limiter, it is D11, located directly in front of VR4 and C73. Looking at the radio from the front to back, it is in the right corner, apx 2 1/4" from the back and 2 3/8" from the right side.
Dean Pitts
Rollin CBs
Nov 17, 2008 | Radio Communications
Width out of screen compaq mv5500
Replace modulation diode & TIP122
Sep 20, 2008 | Computers & Internet
Cobra 19 DX IV CB Radio Logo
181 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
