Question about Intel Motherboard
Intel Original Motherboard 946 with duel core processor.
I am having a system with intel MB 946. The system was working fine few months. Then suddently it stopped booting. There is no beep sound. But the system fan is working with the LED is on. If i try nearly 10 or 15 times simply restarting and... sometimes it start to work. Is the problem with MB 946 or with any other problem? I am using 2 512 MB Rams. The problem started even before i got the new RAM. can anybody suggest what is the problem? if i want to replace the MB, how can i do it? i am from kerala.How can i appoach Intel service centre? please let me know if you people have a solution for this?
Thanks & Regards
K. Anv ar Sadath
  • Anvar sadath Nov 22, 2007
    Thanks for your reply,
    But the system is not restarting. It just not booting up.. there in nohting on the screen. There is no probs with SMPS, because the LED light in the motherboard is on and fan is working. how do i reset BIOS in Intel 946 motherboard?
  • Anonymous Nov 30, 2008
  • 304 Answers
As you said the system is restarting because of power section problem.
Try to change SMPS and see the difference. Even though if it fail.
Try using single ram if problem repeat change with other ram.
Load bios defaults.
If Not Ok
Contact Intel Support:
With your bill No, Serial No & model no.
or you can mail to:
Hope this will work...
Posted on Nov 22, 2007
    NANDAKISHORE Nov 23, 2007
    Hello Mr. Anvar sadath,
    As I told try to check with other SMPS why because some times in the SMPS only few sections will fails. Some will work this is the problem you got, the fans, LED's Will work.
    1) Reboot the System.
    2) Press F2 Key before the POST Start.
    3) Enter into BIOS
    4) In Last Menu you can see 'LOAD OPTIMAL DEFAULTS'.
    5) Press F10 and Y to save settings.
    1) Remove the Side Door
    2) Search for a Jumper having 3 pins
    3) Change it to 1, 2 then Switch on the system this will resets Bios passwords and Default settings.
    4) Press F10 to save and exit
    GOOD LUCK :)
it may be the RAM problem check the Ram's clock speed.
for your system ram clock speed is 667DDR-II.
Prashant Sankhla
New Delhi
Posted on May 11, 2008
Hai first check for using one ram (or) change the rams .
Posted on Jan 08, 2008
Posted on Jan 07, 2008
What processors will are compatible with an hp 3396 motherboard
That motherboard uses the CPU Socket 1155 LGA. Pretty much any processor for that socket should work. (Source:
Popular CPUs for this board are:
  1. Intel Core i5-3570
  2. Intel Core i7-377
Feb 25, 2015 | HP 339661-001 HP PCIx Cage DL760 G2 Mfr...
Installed pentium d 940 duel core. Will not boot. need solution
Assuming the new processor is compatible with your MB there are several things to check. Do you have jumpers on your MB to identify different processors? Can you get to the BIOS with the new chip installed. There are several settings in there that could affect your boot process. Lastly, is your BIOS compatible with the new processor?
Feb 20, 2013 | Intel Pentium D 940 32GHz 800MHz 2x2MB...
Intel 946 mother board
You need at least 1GB of Ram Memory, and should have 2GB.
[512MB + 512MB = 1024MB or also stated as 1GB ]
The - Intel 946 - designator you have listed refers to the motherboard chipset.
It is either an Intel 946PL, or Intel 946GZ motherboard chipset,
You can see the list of processors it supports. Also look at the Front Side Bus speed it supports (FSB), and note 65nm architecture for the processor.
As for office work, or surfing the internet; more Ram Memory will help.
For editing videos, or intense games though, you need a decent graphics card.
Dec 21, 2012 | Computers & Internet
How to check my gigabyte mother board under warranty?
i read from your information and picture about your motherboard type..i think yours is not under warranty from factory anymore (GIGABYTE)
for additional information your mainboard (MB) is using old type of intel chip set (Intel 865 series) and only support intel processor type Pentium 4 with 478 pin with 533 MHz bus processor..
talking about warranty from factory GIGABYTE only give 3 years warranty only for MB with minimum chipset intel ICH 7 and up..that's mean MB must be support processor minimum 775 pin and 1155 pin or support intel Pentium D,Dual Core,Core2Duo or Core i series...
hope this is can help to solve your problem..
Aug 13, 2012 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
1333 FSB processor ( E6850 ) on a 1066 FSB motherboard, DDR2 667 memory
Hi proenza. you're making good sence! You're D945GCL MB should be able to run 1066 FSB. Not 100% sure you're memory will keep FSB up to 1066.
Here's the trouble though. The Intel Core 2 Duo E6850 will not run on the Intel D945GCL motherboard because it is not supported. Look here at Intel's web site. Supported CPU's.
Intel E6850 specs sheet.
Intel E6700 spec sheet.
This CPU is supported by the D945GCL MB.
Intel Core 2 Duo E4700 Processor BX80557E4700 - 2.60GHz.
In order to get 1066MHz (CPU can run at), you'll also need the memory support at 800MHz. The D945GCL MB can only run DDR2-667MHz.
Many people buy a CPU to run MB's specs (1333MHz) just to find the same MB does not support DDR2-1066MHz or DDR2-800MHz. Motherboard Mfg's are lagging. DDR3-1333MHz is out there now to support the 1333 MHz CPU FSB.
I hope this has helped you make a decision proenza.
Good Luck!
Jul 17, 2008 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
A8V-MXs are built for AMD processors. You will need a board made for Intel processors if you want to purchase the above processor. If you want to stick with Intel and Asus check out the P5 series of boards. If not, buy an AMD chip...I've had AMD in almost every one of my computers, laptops and desktops.
Good luck.
Dec 20, 2007 | ASUS A8V-MX Motherboard
Intel Motherboard Logo
311 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
