Question about Motorola Mobility RAZR V3
BATTERY WILL ONLY CHARGE ON A CAR CHARGER
DOESNT HOLD CHARGE FOR MORE THAN 2 HOURS LEAVE CHARGING OVERNIGHT ON AN OUTLET CHARGER AND IT WILL STILL SAY LOW BATTERY YIN THE MORNING? PLEASE HELP!
    President:
  • 1,884 Answers
Old phone. Needs new battery.
Posted on Jul 24, 2009
  • 33 Answers
Turn off the GPS (location ) service. The phone may be constantly sending out signals and wasting battery.
But mostly, I bet it is in need of a new battery.
Posted on Jul 25, 2009
    President:
  • 2,976 Answers
Get a new battery and if you're storing a lot of junk on the phone, clear it out.
My phone is not holding a charge. I charge it overnight and this morning it was only at 32% charged. The day before the charge ran out very fast. How can I fix this problem?
It sounds like you need to replace the battery in your phone. NiCad batteries will build a memory, so you should not use the phone for, say 3 hours and place it back on the charger. You should use the phone and let it run down until you get a warning on the phone of low battery. That is when you should put the phone on the charger. It is okay to leave the phone on the charger for extended hours and it will not do anything to the battery, but in your case it looks like you have a bad battery.
Aug 23, 2016 | Cell Phones
I need to know how to use my new laptop battery correctly.
The first time you charge the battery allow 12 to 16 hours, after that 2 to 4 hours or when battery is charged. If you go on battery frequently drain it right down before charging it, this will give the maxi-um performance and longevity.
Mar 16, 2011 | Computers & Internet
Ive been charging my blue tooth (new) for over 8 hours, the light is still red, and it wont even turn on! Can you help?
Try another outlet. If you're charging the headset through your computer, then use a wall charger. Leave it to charge overnight. If it wont charge, then bring it back to the store because your battery may be defective.
Dec 30, 2010 | Computers & Internet
It will not charge the starter battery.
Do you have a volt meter so that you can check battery output when unit is running. The charge rate on most small engines is about 3 amp so it will not charge very fast. If you have a battery charger I would disconnect negative cable from battery, check voltage on battery then hook up charger for a couple hours. Recheck voltage.Then leave battery neg. cable off overnight and check voltage again the next day.You may have a bad battery that wont hold charge. If it holds charge overnight then I would hook neg. cable back up and leave set for a day or two and recheck voltage. If voltage has dropped then you have something draining battery. Before I did anything to drastic I would clean all connections to battery and starter switch. If your system is really not charging you will have to replace starting diode. Good luck.
Nov 12, 2010 | Watts Onan Portable Generator - 4000 ,...
I put a new battery in my camera charged it. Used the camera till the battery ran down. Now it won't charge . This is the second battery I've bought every time I try to charge it won't charge.
It takes over 7 hours to charge, so did you leave it charge overnight?
But while the original battery is chargable, disposable replacements are not. Here is what the manual says:
The supplied battery is a Li-ion battery. It charges while in the camera using the supplied charger. The camera can also use a Duracell CP1 disposable Li battery, which has the same form factor as the supplied Li-ion cell. HP claim the Li-ion cell will provide power for approximately 200 shots under "average" use and 100 shots with "extensive use of the LCD and flash".
Charge time for the battery using the supplied charger and in-camera charging is 5-7 hrs for a fully depleted battery. In the optional docking station, charging takes 2.5-3.5 hrs and using the optional rapid charger, charging takes 1-2 hrs. ... }
http://www.bobatkins.com/photography/digital/hp707.html
Aug 08, 2010 | HP Photosmart R707 Digital Camera
Headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
Aug 14, 2009 | Motorola Mobility H500 Wireless Headset
Motorola CP040 charging time
The rapid rate charger WPLN41__ will typically charge a battery in 90-120 minutes. Your battery should be depleted or nearly depleted when you place it in the charging stand. Be certain your radio is always turned off, when charging an attached battery. The NiMH battery will generally go 12-16 hours on a charge when new. If you work an eight hour shift, you might see if the radio will go 2 days on a charge. Later as the battery ages, you will need to charge it nightly. (Think of putting it in the charger as putting it to bed at night.)
Rapid charging is necessary on NiMH and Li-Ion batteries. They require a "hotter" charger, a fast rate, to completely charge the battery. It will not harm this chemistry of battery. It is safe to leave the battery on the charger overnight, or for a weekend. We would not recommend leaving the battery on the charger longer periods of time, as that will age the battery and reduce its life.
(Sidenote: Frequent rapid charging will however reduce the life of a NiCD battery.)
Aug 12, 2009 | Motorola Radio Communications
DSealed Lead Acid Batteries: 12v 7ah; belongs in a Liftmaster LA400 gate control box. Can these batteries be charged using a trickle charger? I'm trying to find out if it's the battery not holding a charge...
Yes you can charge the 12 volt bttery on a trickle charger. You should use a 1 amp or less charger. Check the battery every 1/2 hour or so for heat. If it get's hot you should stop charging. Power packs that have a 12 volt rating will charge your battery safer and better but will take longer (like a cell phone charger) look at the voltage ratings on the charger. You will have to adapt the plug to hook it up and test for correct pos. and negative connections. The 7amp hour batery should be fully charged by a .5 amp (500ma) charger in about 14 hours (multiply the amps times hours of charge and do not go over the 7amp hours of the battery when deciding how long to charge). After charging check voltage, it should be around 12. Let the battery set for a few hours (overnight) and check the voltage again. It should be around 12 still. A fresh charge will usually show a higher reading (called a surface charge) than a battery sitting around. 4.5 v will not operate your device, 9.5 v or higher should.
Aug 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Samsung omnia problem trying to charge battery
It looks like battery is damaged... When plugged in to charger phone shouldn't power on. Try put it on charger when on and see if charging icon appear. (top right corner-battery status icon should change -insted of battery to charging.) Battery is fully charged after cca 4 hours, 80% after 2 hours.
Jul 16, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Not charging?
Please plug the camera charger in AC Outlet and hook it to camera. Check camera power turn ON, works fine? if OK, switch it to Standby / Off mode. Attach battery and check any charging light lit? If yes, leave the camera on charging position for 4-5 hours until its charge light flashs or turn Off. battery is chaged now. Have fun :)
Aug 13, 2008 | Sony Handycam CCD-TRV37 Camcorder
Motorola Mobility RAZR V3 Logo
132 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
