Solid light for few seconds blinks 3 times then 2 times and repeats no high voltage or sound this is a true flat philips tv with philips chassis also used in some magnavox tvs
  • ex32006 Jul 30, 2009
    have already done the soldering thing nearly entire board the blinking light is an error code and i need to know what it is i am an electronics repairman but cant find the error codes
    i just noticed this is in projection set category this is a flat tube tv have checked all that you talked about numerous times the blinking is a code i just need to know where to find what the code means i have come across this many times if it were just blinking i would keep searching the board but its trying to tell me somthing :)
    Novelist:
  • 123 Answers
Hi! I`vw had no dealings with this particular set but have you checked the HT supply coming out of the PSU? Does the HT stay there or is it being shut down by the uPC?? It may be worth disconnecting a few things like sound O/P. If the HT is shutting down, it sounds like there`s a short or a leak somewhere. One of the main ailments with most philips TV`s are the electrolytics, they`re absolutely ****, It may be worth running a hairdryrer over the board to warm them up. I`ve had this problem a lot with the projection and standard CRT sets. Hope this helps you. Ian
Posted on Jul 30, 2009
    President:
  • 2,923 Answers
Light blinks 3 times, then 2 times and repeats, but my questions is, are you getting a screen display? If you're not getting a dispaly or picture, the problem could be the bulb inside the TV is burnt out.
If the bulb is okay, then you may want to check the following:
Capacitors, resistors, diodes, transistors or IC (Integrated Circuit). One of these components maybe bad and it could be one of the possible cause of the problem
Hope this helps and have a nice evening!
    Brigadier General:
  • 8,619 Answers
Hi
The cause of lights flashing frequently is the board of the power supply. If you have electrical expertise and know how to work with soldering iron you can fix it as these sets have high voltages even when it’s switched off. Generally the main causes are invisible cracks or dry joints and cold soldering. Turn TV OFF and disconnect from outlet. Remove TV back cover. Remove board with transformers (power supply). That board has many components on the back side. Try to see small cracks or not properly soldering dots. Use some magnifier. Resolder all not good soldering dots.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 29, 2009
Won't power on
You still have power supply trouble, even after replacement of the board. Recheck the replacement work; could be something wrong there
Jul 19, 2013 | Philips 47PFL7422D/37 Television
Mitsubishi ws65713 picture goes out
I know these sets well, you lose brightness but still have sound?
If the green power light comes on for a few seconds and then goes out the set has a self check for error codes:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Nov 02, 2012 | Mitsubishi Televison & Video
Have Hd 1080 series tv model # vs-50111 tv will not turn on. When you try to turn it on green light stays on for 3 seconds then nothing.
it may or may not have the self check but try this:
When green light comes on and goes off ON THE FRONT OF THE SET press and hold the menu and input buttons at same time for 5 seconds or more and release both.
Power light should blink a two digit error code like 2 blinks, 2 blinks and pause--repeat it several times--all their sets after 1999 have this feature.
If yours does not someone has to go inside and measure voltages etc to find problem---a lot of the older ones develop broken solder connections and the chassis would have to be examined for that.
SD TECH
Apr 22, 2012 | Mitsubishi Televison & Video
Tv turns on then off after a few seconds. No picture or sound in these few seconds.
Try this and let me know what you find:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
if this has helped you rate this solution as I do this here for free.
SD TECH
Dec 10, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Turn on the power and the green LED blinks on the front for a second, but tv does not power on
Jul 30, 2009 | Mitsubishi WS-55411 55" Rear Projection...
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Tv no pic or sound
If you hear the high voltage try to come up and set shuts down in 2 secs it could be your FBT also these sets have alot of poor connections chassis should be resolder.
Apr 06, 2008 | Televison & Video
Will not stay on.
tvtony = Install horiz driver upgrade kit for L04.1U chassis,
Part # 483531057673 + replace 47mf/25v cap in
horiz driver circuit..........................T.
Dannie = not the same chassis or exact symptom. Best if
you match info stream w / other 30PW862H tv's.
Nov 08, 2007 | Philips 32PT6441/37 32" TV
Mitsubishi VS-50607
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Oct 04, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
