Question about Little Tikes Cozy Coupe
Need a replacement steering wheel for a car that we bought from some neighbors in one of their sales. The car is in excellent shape but the steering wheel is missing. I am hoping that someone may have a car that is no longer in service and would be willing to sell me the steering wheel.
  • dbugg
    dbugg Dec 19, 2012
    I know it's been awhile but was your problem solved by the link THEGTW provided? I'm in the same situation!
    Sniper:
  • 55 Answers
You can purchase a replacement steering wheel directly from Little Tikes.
http://www.littletikes.com/consumerservice/ReplacementParts-detail.aspx?Product_ID=2823&
Sincerely,
The Grand Toy Wizard
www.thegrandtoywizard.com/store
Posted on Jul 24, 2009
Chevy Malibu 6 cyl, hit 200,000 miles--what is necessary?
I would recommend having a shop you trust inspect the suspension and steering. Shocks/struts, tie rod ends, ball joints, wheel bearings and such. From the information you have provided it appears the drive train is in good shape. Other than having the suspension and steering (maybe brakes too) looked at just keep up the regular services.
Aug 17, 2014 | Cars & Trucks
While driving 1989 Hyundai Excel (carburator), the steering began to behave erratic. Steering wheel became harder to turn left/right the longer it was driven. * Checked brand new front tyres at closest...
Sound like you may need a new power steering pump or rack and pinion. Have you noticed any leaks from the vehicle? If you've had the vehicle for 21yrs, then I would have to go with the power steering pump is begining to fail. Hope this helps.
Mar 19, 2011 | 1989 Hyundai Excel Hatchback
Need value of 1986 chevette with 35,000km. automatic and never winter driven, in excellent shape.
Go to the Kelly Blue Book site:
http://www.kbb.com/used-cars
Enter the data for your car and they will provide you with values for trade-in, private party sale and dealer sale. Good luck!
Mar 08, 2010 | Chevrolet Chevette Cars & Trucks
How to get the blinker switch assembly out of a 1966 oldsmobile 98?
1966 Olds 98?
It's been a while, so bear with me. The main objective is to remove the steering wheel, to have access to the turn signal switch.
1.Negative battery cable disconnected
2.I believe you twist the horn button in the middle of the steering wheel, and pull up, to remove. The horn button should have a ring of thick rubber on the bottom, which keeps it in the steering wheel. The chrome piece under the horn button may come off with it, or it stays on the steering wheel. This is the part that is fuzzy to remember.
3.Remove the steering wheel nut, and lock washer.
4.If you do not have a steering wheel puller, go to your nearest auto parts store, and see if one is available to rent. The cost of this puller is relatively low, so you may just want to go ahead, and purchase one. While you're there you need to obtain another tool also. Steering Wheel Lock Plate Tool.
5.After the horn button is removed, and the steering wheel nut, you will see a flat metal area of the steering wheel. On each side of the threaded part of the steering column shaft, there are two small threaded holes, in this flat metal area.
The steering wheel puller, is a bar shaped piece of metal, that has a threaded hole in the middle. There is a threaded shaft that goes into this hole. On each end of the metal bar are slots. Threaded bolts go through these slots, and line up with the two threaded holes in the steering wheel. There is a pointed tip, that rotates on the threaded shaft, of the steering wheel puller. This pointed tip goes in the middle of the steering wheel shaft. (The shaft that you removed the nut from)
Find the two correct threaded bolts in the steering wheel puller kit, that matches the threads in the steering wheel holes. They HAVE to be the correct size, AND the correct thread. (Fine thread, or Coarse thread. They will be SAE thread, and not Metric) If the puller does not come with bolts, or the correct bolts, you'll have to purchase them separately.
Place the puller on top of the steering wheel shaft. Run the threaded shaft of the puller down, until at least 3 to 4 threads of the shaft, are showing on the steering wheel side. Now place a threaded bolt in the slot on the outside part of the bar.
Run the bolt down into the steering wheel threaded hole on one side. Make sure it goes in at least 1/2 inch. Do the same with the threaded bolt for the other side.
Adjust the length of the threaded shaft of the puller, so that the two outside bolts will go in as advised. Adjust the threaded shaft out, or in. Be SURE the two threaded bolts, are threaded down into the steering wheel the same depth, and the bolts are the same length!
Now turn the threaded shaft of the steering wheel puller in, with a ratchet and socket, to remove the steering wheel. (Turn the shaft to the Right)
6.Now remove the steering wheel lock ring. The steering wheel lock ring tool is now used.
There is a cylindrical shaped piece that has threads on the inside of it, and has a hole at the top, that a lock pin slides through, for the above tool. This cylindrical shaped piece is threaded down onto the steering wheel shaft.
The tool has a handle shaped like a screwdriver handle, and a shaft attached to the handle. The shaft goes down into the cylindrical shaped piece. Then the lock pin goes through the cylindrical shaped piece, and also a hole in the shaft of the tool. This lock pin locks the cylindrical shaped piece to the shaft of the tool.
BEFORE the cylindrical shaped piece is pinned to the shaft, you slide a U shaped piece up on the shaft. (Thought it would be better to explain it this way)
The opening of the U, goes down towards the steering wheel. It's U shaped to clear the steering wheel shaft.
As you turn the handle of the tool to the right, it pushes the U shaped piece down. The U shaped piece then depresses the steering wheel lock ring down.
(There is a Thick metal spring under the steering wheel lock ring)
You have to take a metal pick, and a small flat tip screwdriver, and remove the round snap ring. May take a little finesse, and a few tries. Use patience. Now back the steering wheel lock ring tool off. (Turn to the Left) The steering wheel lock ring will come up, so that you can take it off. Remove the spring. Remove the plastic horn contact assembly. Now you can see the screws to remove the turn signal switch.
Sep 28, 2009 | 1972 Oldsmobile 98
Steering Wheels Problem
There could be a lot of reason for vibrations on your steering, One reason could be is that your wheels need to be balanced. Car tires, can go out of shape and the farther the tire shape becomes from a circular shape the more vibrations you may encounter. Another is bad bushings, ball joints or tie rods especially when you turn and in some cases these problem can be tested by moving the wheel laterally as if trying to turn it by hand on the outside. Some cases it could be bad shocks.
Aug 26, 2009 | 2004 Toyota Matrix
Need 4 replacement wheels for an emmaljunga pram,can you tell where i can find them?
I have 8 extra Emmaljunga wheels for sale - 4 black inflatable and 4 white rubber. I would like to sell them asap! Contact me if you're interested!
Jun 25, 2009 | Emmaljunga Coronado Stroller
I have a 1990 Ford F-150 My ignition switch will not work and the steering is locked I had it toad to my house The driver left it on my neighbors property need to move it.How can I get the steering...
ok we know your not responable for any car stolen in your area. around your steering wheel the are screws that hold on the cover. depending on the make and modle you might need star shape or allen wreches. remove this. then you should have a screw or pin or something holding the igntion in place. remove it. then take a flat head screwdriver and turn it forward. this should be no problem unless there is some kind of anitheft or alarm on it.
Mar 29, 2009 | 1990 Ford F150
Steering vibration while driving
check badly worn frt tire,bent wheel rim,loose wheel rim,frt tires may need te be rebalance
Feb 26, 2009 | 1994 Hyundai Excel
Lcd screen on slave unit not functioning
looks like Lenoxx, Alco, Funai possibly bought out durabrand but from what I hear durabrand is not a good brand people should by more expensive dvd players why by 40 doller dvd play that will brake down quick when you can by a bigger screen last longer better featured dvd player used ones are ok to
Apr 20, 2008 | Durabrand Portable DVD
Set up instructions
i need setup instructions too ... bought a mad catz steering wheel and pendals and the tender centre it had no instructions
Dec 08, 2007 | Mad Catz 5320 Wheel And Pedals Set
Little Tikes Cozy Coupe Logo
895 people viewed this question
Top Little Tikes Toys Experts
 Russ Hill
Russ Hill
Brett Duxbury
Brett Duxbury
Bill Boyd
Are you a Little Tikes Toy Expert? Answer questions, earn points and help others
