Question about Line 6 Spider Iii 30
Amp wont turn on, but i hear a pop when turning off
I checked with multiple cables, and different plugs, but the amp will not power on, but when i turn it off, i hear the same pop-ish sound you usually hear when turning off an amp.
I just got this amp brand new about a month ago.
If you can, look at the PC board, usually this indicates a blown amplifier chip, transistor or FET. The poping sounds can be the transistor base feedback, because of the RC filtering and amplification. You can sometimes see brown, or lifted clad on the board, if not always lick your finger and touch the top of an amp chip. I say lick your finger because if it is shorted, it is going to be hot!!!!! When you lick you finger, you will hear the sizzle before you burn your finger, just be careful not to touch the high voltage.
Posted on Jan 14, 2013
    Problem Solver:
  • 3 Answers
First off nothing should pop when turned off next it could be a grounding problem external or internal or worse an audio output problem take a volt meeter and turn key to on check the ground and positive on the amp should read 12 to 14 volts do same with ground and remote wire if these both read correct remove the back set your meeter to the diode setting the audio outputs are usually the larger ones but sometimes not take your leads and touch out side legs then to the outside to center try each one every way you can switching leads if at any time the buzzer stays on or goes to flat 0 then that output is bad if all check good i would go through the car making better connections and cleaning up any wires that might seem to be faulty maybe even replace your RCA cables
im running 18 speakers and 8 amplifiers in my car and i have done this several times :( but i don't pop unless something is wrong hope this helps
Posted on Jul 24, 2009
  • ex32006 Jul 24, 2009
    guess i been working on cars to long sorry the poping you are hearing is most commonly caused by a faulty saulder joint in the pots or in the input output plugs sorry 1:30 am lol you can check outputs same way though pull the board and give it a good look over if there apears to be a ring around a leg through the board re saulder it try moving things but be gentle watch legs on underside for movement or you could do it the hard way and just resaulder the whole board done that before you may need glasses after you finish lol
Peavey tnt 115 blowing fuses
your either overloading something cause that's what pops fuses. My guess is that what your plugging in or into has a ground issue. I'm wondering if it does it with nothing plugged in at all. I would say if you have nothing in and it does it, you need to find where the ground issue is. that's my best guess
Feb 20, 2014 | Peavey Electronics Peavey Tour Tnt 115...
Amp not comming on until strings played hard.
Check your cables - I've had similar problems with various amps playing various guitars; the guitar electronics and the amp electronics are fine, but the cable is damaged internally and this causes the same problems as you have described. Have you tried using a different cable? Buy a different one, try it out, and see if you have the same problem. If you have a friend who plays, let them plug their cable and guitar in the amp - if it works, your faulty cable is the issue. Hope that helps!
May 01, 2013 | Genz Benz Shenandoah 150lt Acoustic Amp...
The amp does not work at all even though the lights on the amp come on but when i connect it to the guitar no sound whatsoevva i checked the sound nobs on the guitar and the amp n all r ok but no soun
Have you checked a different cable?. Also, when you plug in the unit, there should be a "pop" if everything is turned on. If there isn't, the connection is bad someplace.
Aug 06, 2012 | Marshall Amplification Marshall MG15FX...
I Just bought a brand new Fender Hot Rod Deville 2x12. I get no sound when i turn it on. I can hear the hum of the speaker, everything lite up, including the two 6L6 tubes. When i plug into the jack, i...
If it is new then something is a bit strange to say the least. Turn all the knobs to midpoint. If it is going to click/pop then you will definitely hear it. Switch to standby, then power to on for a minute then standby to on. You should then see the 6l6 and the 3x 12AX7's all glowing. Plug into each channel. Don;t use a pedal to try any of this. If you get a pop on on ch then it can be one side of the preamp either a tube or one of the op amps on the board.
Make sure you try out the cable/guitar on a different amp to make sure it is working. Could be a cable or plug that is the problem.
Honestly if this is new I'd haul it back to the store and return it. It should just work with no hassles. Once you know your guitar/cable is not the cause then I would take it back and get them to either set it up or replace it. Something is just not right here for a brand new amp.
Jul 26, 2011 | Fender Hot Rod Deluxe Guitar Combo...
My new SWR workingpro 12 has a low frequency permanent noise, any idee ? Maybe from the Power supply... Thanks, bolliger_rudolf@bluewin.ch
All amps make a small amount of noise (system hiss) but the amps own power supply should not cause a problem on it's own.
However if the frequency is around 50hz (the G 2 1/2 octaves below middle C on a piano) it is most likely due mains electricity interference or an earth (grounding) issue.
Here are a few things to try to identify the source.
  1. Could be a lack of earth (grounding) This is potentially VERY DANGEROUS and could result in electric shock if you touch a metal part of the amp or touch some other metal object (like a microphone stand at the same time as your guitar strings). Check the earth wire is firmly attached at both ends of the power supply lead.
  2. Could be a defective mains socket - try plugging it in to a different one, preferably on a totally separate circuit.
  3. Could be an earth loop. These can occur if you are using the amp with an output to a public address system or mixer that is also earthed because of a 'potential difference' between the two earths. Solution - use the balanced (xlr) output which incorporates an earth lift rather than the unbalanced jack output.
  4. Unplug any effects pedals, foot-switch etcetera to see if that eliminates the problem. Turn off any internal effects, including bass intensifier.
  5. Make sure any signal cables (guitar leads) have good quality screening and that the screen is well soldered to the jack plugs at both ends.
  6. Ensure signal leads do not lay along side (parallel) close to mains electricity cables but are well separated and only cross at right angles.
  7. Move the amp away form other electrical equipment that may have a powerful magnetic field (especially CD or DVD players, hearing loop amplifiers, radio microphone transmitters / receivers, mobile phones
  8. Turn around or stand in a different position - it might simply be the pick-ups in your guitar causing interference in the magnetic field of the power supply.
  9. Does plugging in or unplugging a signal lead / guitar make any difference? This particular amp requires only mono jack plugs a stereo (trs) plug may be shorting across terminals
  10. Does it change when you touch the strings with your hand? If yes check internal wiring and screening within the guitar.
Feb 09, 2011 | SWR Workingpro 12 200watt 1x12" Bass Combo...
Hey . uhm just wondering does anybody have the problem where when you turn your amp on nothing happens .. everythings gone ..but when i turn it off i can hear it turn off .. it clicks when i turn it off ...
Wonder no more, there are many others with many different brand of amps that do this. Obviously it needs repair unlless you have a problem with the cable or source you are using or have forgot to turn up the gain controls which I am sure you have checked. There are so many possibilities that there is no way we can say open it and replace this... If you get a small pop in the speaker when you turn it off, then the power portion of the amp is probably OK. A common probllem on amps that have a preamp out or power amp input jacks is a failure of the switch contacts on the crummy jacks that pass the audio through from teh preamp to the power amp...
Jan 03, 2011 | Line 6 Spider Iii 15 Modeling Guitar...
My amp, was working fine last night, it wont turn on, and i tried switching guitar, cables, even power supplys and still wont turn on, i heard a pop last time i used my amp, and then the signal was lost...
The unit will require repair and if you are not adept at electronics, you will need to take it to a shop. Likely there is failure in the power supply or amplifier that has blown the fuse. Replacing the fuse WITHOUT repairing the cause MAY do additional damage.
Dec 28, 2010 | Fender Hot Rod Deluxe Guitar Combo...
I have a Marshall MG100DFX. I turned my amp on a few days ago and I heard this loud sound (not the standard hum/buzz that you hear when you plug a guitar into an amp; it sounded more like a foghorn). Now,...
I would try hitting the side of the amp before turning it on. There may be a loose piece of solder or other conductive particle stuck somewhere. Bang the cabinet rather hard with your fist. If that doesn't help it might be a loose solder connection at a resistor or capacitor but a tech should check that out.
Dec 04, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
FENDER HOT ROD DEVILLE 410 POPPING SOUND
I have answered some of this before, however I have reveiwed the schematic and as an electrical engineer I want you to do a couple tests.
First, plug in a set of headphones into the preamp out jack. Note that due to the impedance mismatch what you hear will not be very loud. Now change the state of the clean OD. Did you hear a faint pop?
Next plug a LOW impedance device OR even an instrument cable into the power amp "input" jack. Do this with the power off then warm amp up.
Now, change the state of the clean OD. Did you hear a faint pop?
Now for the analysis. If you did hear one in the first test and NOT in the second, the pop you are hearing is the "NATURE OF THE BEAST".
I can tell you from the design that the pop you hear is from coupling within the clean and OD relays within the unit. There is no cure for this within the unit other than find another brand...
I would recommend that you use an EXTERNAL pedal for the effects you want rather than trying to use the clean OD in this amp. I suspect it was never intended to be shifted during playing as I can guarantee it will pop when you shift while having anything other than dead silence (not even a bit of hum from your guitar). There is also statistical noise in the preamp that the laws of physics will not let us get around that may be enough to create a bit of a pop.
You could also use a volume pedal between the preamp output and the power amp in to throttle the volume to zero before shifting to OD.
In general I think you will find that what you are hearing is the nature of this beast.
Mar 18, 2010 | Peavey Music
Line 6 Spider Iii 30 Logo
251 people viewed this question
Top Line 6 Music Experts
Vito Vacirca Jr.
Larry Stiles
Larry Stiles
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Line 6 Music Expert? Answer questions, earn points and help others
