Question about GE 15" Laundry Pedestal for Horizontal Axis Washers and Dryers - White-on-White
RE: ge gsd2000j01ww When I opened my dishwasher after a run... I found a white large belt (rubber band like) on the top shelf. I have no idea where it belongs
    Problem Solver:
  • 3 Answers
At the bottom of the dishwasher (older GE) you see a plastic cover with rounded corners and two 'grill' shaped sides. Remove the screws (1\4) and lift the cover. There might be a huge amount of grey clog and dirt stuck on the inside already. Remove it with a fork or long brush and rinse it. There is another grill in the water hole pull it out and clean it as necessary. You may also want to reach into and check the water hole for debris. If you are not comfortable doing so you can remove the water by pushing an old towel into the hole first. Once all parts are clean put them back in place and fix the cover with the screws. Pour 2-3 table spoons of bleach into the machine and let it run twice on heavy duty cycles.
Posted on Dec 07, 2014
4 Suggested Answers
joe_lishman
  • 192 Answers
SOURCE: GE GSD2000J01WW dishwasher , full of water at bottom of machine
The drain motor (pump out motor) in line with the outlet pipe could be faulty. This motor must spin (to pump out water) in the drain mode. If AC (mains)voltage is across motor in pumpout mode and the motor does not spin indicates that the motor is open circuit and needs replacing. Has one of the 2 motor push on electrical connections dislodged?
Is the outlet pipe obstructed?
Posted on Jan 22, 2010
  • 457 Answers
SOURCE: Large blue band appeared on lower tray following wash cycle,
it is not a part of the machine. do the machine work ?
Posted on Mar 13, 2010
SOURCE: I have the GE 206c1513p001
I have the exact same problem!!! Found 2 loose rubber bands, the bottom doesn't drain completely, and the dishes are left either dirty with a white film on them. Please help!
Posted on Dec 02, 2010
Where to buy Sony MHC-RG40 rubber band
You just need to measure the diameter of the belt (approx) in MM. Then put "XX MM diameter Drive Belt" into Google. Get the one nearest your measurment.
Dec 17, 2012 | Sony MHC-RG40 CD Shelf System
The drive belt for the cd door is broken. how do i get a replacement part?
I'm assuming the cd door ejects outward if you need a belt. I had this happen to a dvd drive. I simply dis-assembled the top of the drive and removed the tray exposing the sprockets to the assembly that moves the tray in and out. I then replaced the belt with a rubber band and found that it worked out great after re-assembly. Considering it will not spin with the force of a vacume cleaner this should work out.
Nov 08, 2011 | JVC MX-GT88 CD Shelf System
I have the GE 206c1513p001 Potscrubber and recently found a black seal or rubber band in the dishwasher. Since then, it has been making a continuous clicking noise when it is run and does not clean the...
Oct 06, 2010 | GE Dishwashers
So. We had the same problem tonight and I have been sitting lookin at this thing for an hour and decided to run it and see what happened with no rubber band in there. After the cycle was over I noticed that my wife washes those "snap wear" containers in the dishwasher and these items have colored coated Mylar bands as sealers. When they heat they expand and can be dislodged. It was a coincidence that it wrapped itself around the bottom spinner. Myth debunked!!!!!
Mar 10, 2010 | Bosch Dishwashers
Jan 22, 2010 | Dishwashers
Have a teac p-a 400 turntable,that was just given to me. i see a rubber pad that goes on top of turntable, the turntable made out of metal, and a oversized rubber band. I put the rubber band around the...
I'm guessing that the belt is too large (stretched). Normally it should be small enough to stay on the platter itself. Install the platter and place the belt around the motor hub (white plastic), If the belt is too loose, it will just sit and not turn the platter. Try a new belt first as that is the least expensive option to try.
Keep us posted.
Dan
Apr 12, 2009 | Audio Players & Recorders
The rubber tube on the top shelf of my dishwasher is falling apar
we found a replacement at appliance parts store. thank you.
Nov 11, 2008 | Dishwashers
Drive belt for a HH957 CD player
Found a belt at a local dealer.
Aug 02, 2008 | RCA RS2605 CD Shelf System
Philco suitcase turntable / cd belt drive
Place the rubber band around the turntable and put a paper clip, bent up behind the rubber band. Start the turntable on it's spindle and you will be able to view that drive spindle on the right side, slowly pull the rubber band with the paperclip and drop over the drive spindle. remove paperclip and push turntable down seating it and replace the lock snap.
Jan 27, 2008 | Philco (R) Suitcase CD Shelf System
GE 15" Laundry Pedestal for  Horizontal Axis Washers and Dryers - White-on-White Logo
233 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
