Question about LG L1530S 15" LCD Monitor
Monitor displaying yellow tint
From last few days my monitor display suddenly change in yellow tint.
  • 624 Answers
SOURCE: Monitor displays "Controls Locked"
This is a "feature" they include to prevent accidental changes to the screen setup. You should be able to unlock the OSD by pushing the Menu button and the right arrow button together for about three seconds. The message "controls unlocked" should appear. Let us know if you have any other questions and please don't forget to rate the posting.
Posted on Jan 31, 2007
SOURCE: monitor flickers!!
I have also same problem with LG Monitor 700E, LB(in). I want circuit diagram/systematics of this monitor in PDF or any other format. Thanks in advance.
Posted on Dec 12, 2007
  • 62 Answers
SOURCE: monitor displaying 'check signal cable'
Make sure the refresh rate is set at 60 hertz before using the new monitor also check the display settings to see if they are set to use the external display also. Yours may automaticaly do this and your partners may not. If this does not help please let me know the type of notebook and monitor. Good Luck!
Posted on Jan 16, 2009
  • 33 Answers
SOURCE: my lg monitor has turned green
This could be a sign that the monitor is failing, but it could also be a very simple solution as well. There should be two cables that come from the back of the monitor - one is the power cord and the other goes to the back of the computer. You will want to disconnect the cable from the back of the computer and then blow out the end with the pins in it (either with a deep breath or a can of compressed air. Now connect the cable back to the computer. You may need a screwdriver to remove the cable and you definitely want to make sure the cable is screwed in after you reinsert it even if it wasn't when you removed it.
If the display still shows a green tint, perform the same steps where the cable connects into the monitor. Some displays don't allow this part of the cable to be disconnected from the monitor, so you may be unable to perform this step.
Hope this helps,
Posted on Mar 23, 2009
  • 361 Answers
SOURCE: LG - L192 WS LCD Monitor displays blue color
it isnot softwere problem. we can not solve in home. lcd graphi can be reset.which we can get in net it can be solved by expert. once atime i get it in web side, t
Posted on Jun 15, 2009
SOURCE: Monitor displaying yellow tint
Hay guys make sure your video card is seated and fastened properly and the connection for the monitor is secured firmly, worked for me.
Posted on Sep 04, 2009
0 characters
1 Points
My Cintiq 12wx is suddenly yellow-tinted
Did this problem get fixed? I am having the same issue :(
Sep 04, 2012 | Wacom Cintiq 12WX Interactive Pen Display...
My TS902 monitor display is tinted yellow for the last 6 inches on the right hand (as I look at it) side of the screen. Can anybody please offer any information on this problem.
Check that the connection to the computer is tight. Check that the connection to the monitor is tight. Check the cable for any cuts or nicks. Have you tried the monitor on another computer? Have you tried another monitor on the computer? Update the drivers for your video.
Sep 10, 2011 | GNR 19M1 19" LCD Monitor
The color suddenly changed to where everything has a yellowish tint. And now the display is too wide to fit on the screen. How do I get it back to normal?
Right-click any free space on the desktop, choose properties, choose display, change the settings to 32-bit and which ever screen ratio you want.
Nov 20, 2009 | Proview PL926WBi 19" LCD Monitor
Green tint display
The monitor is faulty, not enough red. you can make changes in your display advance settings to try and reduce the yellow and blue to make the screen look a bit better. you might want to try a differant vga cable or check the pins in the plug that nun are bent
Aug 18, 2009 | Star Logic 17" LCD Monitor
Gateway FPD1760 the red in the rgb is suddenly gone
Your graphics card is not working propertly buy a new one.
Mar 15, 2009 | Gateway FPD1760 17" LCD Monitor
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
Try this. Worked for me immediately, including with PhotoShop
  1. Go to Color Management (in Vista, just click the Windows Orb / Start Search & type in Color Management)
  2. On Devices, select your display (repeat if you have multiple ones... at least I did). e.g., Syncmaster ....
  3. Check the box: Use my settings for this device
  4. Select any and all profiles you have and Remove them.
Check to see if that fixed it. You may need to restart. I didn't have to.
more info, and where I learned about it here:
Nov 27, 2007 | KDS Radius RAD-7 17" Flat Panel LCD...
Need solution for the yellow display of my monitor
You can see one ic in right of crt base,plz resolder it (90%sure)
Sep 14, 2007 | SAMTRON 55V 15" CRT Monitor
Problem with the acer al1916w
Sounds like the backlight or inverter might need replaced. It's pretty common on LCD monitors. It's best to call a local repair shop to do that unless you know what you're doing.
Jul 31, 2007 | Acer AL1916W 19" LCD Monitor
Philips LCD Monitor 150s3
The LCD display needs to be replaced. It has kind-of-a dull yellow tint. I guess you tried changing the brightness, contrast, etc.
Jun 27, 2007 | Philips 150S3 (Black) 15 in. Flat Panel...
LG L1530S 15" LCD Monitor Logo
65 people viewed this question
Top LG Computer Monitors Experts
Lawrence Oravetz
Level 1 Expert
Are you a LG Computer Monitor Expert? Answer questions, earn points and help others
