I've got a 120GB SATA with windows XP SP2 installed and running. Now I want to add a 160GB SATA, but the MB does not pic it up on either of the two SATA ports. Then I took the 12GB HDD and swop it to the second port and it works, so the ports are fine but it does not want to recognize my 160GB. I tried diffirent cables and everything, no such luck. On another machine it pics it up so the drive is fine. What can I Do?
asrock wolfdale 1333-d667 display color bars or display disappears after boot or will work for a...
(More)
asrock wolfdale 1333-d667 display color bars or display disappears after boot or will work for a while and then shows the same problems.tried different graphic cards and get same result or would show all screen blue then green then pink then disappears.
buenas noches, temgo una board msi_k9mm_v_ le acabo de cambiar el hd tenia uno de 250 gg y se lo...
(More)
BUENAS NOCHES, TEMGO UNA BOARD msi_k9mm_v_ LE ACABO DE CAMBIAR EL HD tenia uno de 250 Gg y se lo cambie por uno de 320, tambien la desarme totalmente y la limpie, ahora que la volvi a armar, la CPU prende, las unidades de CD abren y cierran, pero el monitor se queda en negro, no da ninguna señal y cuando la reseteo no apaga, he revisado mucho las conexiones que esten bien y no encuentro el rpoblema, me pueden colaborar por favor? gracias LILIANA
I just bought a abit kn8 sli motherboard from an auction. I only have one video card so I need the...
(More)
I just bought a abit kn8 sli motherboard from an auction. I only have one video card so I need the abit shadow card for the PCIXP2 slot. Where can I get this?
