Remove a small part off ziper from underneath the main
How to remove asmallpart off ziper from underneath the main wash plate ?
  • 636 Answers
Did you try a shop vac? I don't under stand what you are asking ? the agitator come off if you pull on it.
Posted on Jul 24, 2009
Dewalt dw005
Remove the cap and the circlip underneath and slide it all forward. Pull back plate holding the small ball and remove it. Put drill bit into a vice and pull on the machine. If it still won't come out you might have to tap on the main spindle with a copper hammer to knock the spindle off. Check the spindle for damage before reassembling.
Jan 18, 2014 | Drills
F02 error on whirlpool front load washer. How do you open the kick panel?
Depending upon what model you have, most kick plates are removed by taking the 3 or 4 (1/4 inch or torque) screws out located underneath the kick plate. Note that not all front load washers have a kick plate so be sure that there is a prominent gap between the upper most region and the small lower region being the kick plate.
Apr 22, 2012 | Whirlpool Duet GHW9150P Front Load Washer
How do I remoce the agatator and tub from my colypso washer?
On this machine - the "agitator" is referred to as a NUNATOR or wash plate.
1. UNPLUG THE WASHER.
2. Open the washer top. Look along the front seam of the washer where the top meets the front. There are a couple of retaining clips (about 2" in from each side) that you will need to push in on with a putty knife while gently lifting up on the top to get the top to release. Carefully open the top and lay it back in a resting position. Make sure you support the lid so it doesn't fall open when you tilt the top back. NOTE: I would recommend using duct tape to keep the lid closed and gently place the top against a wall for support. Use a towel between the cabinet and wall to prevent any damage to painted surfaces. This also reduces the strain on the top panel supports.
3. Remove the tub ring. This is the plastic donut shaped ring that sits on top of the wash tub. There will be a tab on either side of the outer tub near the back that you can use a screwdriver to release the tub ring. The ring is filled with fluid and is used to balance the tub. So, if you hear liquid sloshing around, this is normal.
4. Remove the wash plate center dome from the wash plate. This is the center cone on top of the wash plate. Use a flat blade screwdriver and insert it into any of the slots available along the sides. Gently pry until it pops off. I say "gently", but you may have to use a little muscle to get it to come off. Sometimes they stick. Once the center cone is removed there will be a series of nuts under it.
5. Remove the nuts and the main wash plate should lift out, exposing the inner wash plate. This is another cone shaped device located under the main wash plate. Remove the inner wash plate, using care not to damage the gasket under it. It is common for clothing to become tangled in the leveler or u-joint under this inner wash plate.
6. When all required maintenance is complete, reinstall the inner wash plate, ensuring the gasket is seated under it. The inner wash plate is keyed and should only install one way.
7. Insert the main wash plate and insert mounting bolts. Use a criss-cross pattern when tightening to ensure all bolts are tightened evenly and the gasket seats properly.
8. Reinstall the center dome on the wash plate by snapping it back in place.
9. Reinstall, the balance ring on the wash tub.
The following is a parts list of the most common items that may require replacement when you experience erratic motion of the wash plate, and/or clothing becoming damaged or entangled:
Wash Plate Dome
Main (Outer) Wash Plate
Inner Wash Plate
Leveler Assembly
Inner Wash Plate Seal
U-joint
Thanks for using FixYa!!
Nov 09, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Calypso washer, has debrise and clothing
Wash Plate Dome
Inner Wash Plate
Leveler Assembly
U-joint
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 13, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
How do I remove a small part of ziper
You go buy a magnetic or three hook flexible retriever from your hardware store and go fishing down the side.
Or if the zipper is floating about loose you take the back off the machine after dumping the outlet hose into a bucket to drain off the water.
Tip the machine forward or backward so that the outlet hose from the drum to the pump is as near to the ground as possible then remove the clip retaining it to the outer drum and your zipper should be within grabbing distance.
Make sure you have an old towel underneath the hose before you crack the joint
Jul 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
How to remove outer washplate from. kenmore
Wash Plate Dome
Inner Wash Plate
Leveler Assembly
U-joint
Jul 24, 2009 | Kenmore Washing Machines
How to remove a small pice from uderneath a main washpla
Have you tried a shop vac with a nylon over the end of the suction pipe yet ? Usually works wonders.
Calypso washer
You likely have clothing stuck under the wash plate. I received "out of balance" & "suds lock" errors & tried resolving the issue with extended spin and extra rinse cycles with the same results you have describe "not going below 7 min left in cycle". Thinking I had a clogged drainage hose, I removed the back panel after hose disconnection and "snaked" drainage hose - had problem here once before. Some lint here again but not enough to cause problem I reasoned, then I move to the basket area. Remove the plastic cover in the middle over the wash plate with a flat head screw driver by pressing in on indented tabs. Once removed, use a 10mm socket & ratchet to remove wash plate. I had three pieces of laundry underneath, 2 socks, & a microfiber runner's tank top. I concluded this to be the major problem caused by the small items entering in the gap in the rubber ring around the wash plate. This gap has increased over time by the ring's shrinkage. I am applying silicone to close this gap, but will also use a mesh laundry bag for smaller items in the future. Also recheck the leveling of the machine - mine was off considerably. Once I reassembled the wash plate & hose connections, the machine began working properly. No doubt, this design was not well thought through.
Apr 21, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Clicking Noise
small cap in middle of plate pops out bolt underneath ..remove it and plate pulls up
Apr 17, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Water Leaks from beneath my washing machine
Our WM2077CW just started the water leaking from underneath. We unplugged the electrical cord and disconnected the hoses (water, drain). We then removed the inspection plate from the back and checked for wet hoses. The big black hose on the bottom was a little wet. On careful examination we found a small hole that looked like a material fatigue failure at the point where the accordion part of the hose met with the solid part of the hose near the main drum connection. I suspect this is may occur in other LG washers of the same design. Unless your floor is perfectly level it's hard to tell whether coming from the left or right side really indicates where underneath the water is coming from.
Nov 26, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
