Roper model rt21lmxkq08
inside the top refrigerator on either side of the light in the rear there are two square holes that drip water
The most likely cause for this is the defrost condensate collector tray below the evaporator is frozen over and the back panel in the back of freezer will need to be removed after disconnecting the power. Then defrost the tray and pour warm water with a mixture of Clorox in the drain to make sure the water drains to the pan below the refrigerator that is near the compressor. If you continue to have problems I will send links that may be more helpful for this problem. Sea Breeze
