Question about iLO 3200 32 in. LCD Television
I have cable and would like to attach cable to my tv buy theres no screw on or cable plug in what do i do and what do i need to hook up to my tv
There is no cable screw in jack on tv, how do I hook up tv to cable box
Using an hdmi cable which is the whole point of buying flat screen televisions for the amazing picture quality. They should come with the television but they don't.
Your screw in cable is analogue but your television is now digital. Buy good quality cables with gold flashed contacts. Be prepared for the shock of seeing such a fantastic pin shap picture ??
Oct 06, 2015 | Televison & Video
How do hook my tv to cable
If you don't have the male end on the tv itself, go to radio shack, best buy, etc and pick up an adapter. One end has two prongs that screw to the back of the tv where you would attach the prongs of 'rabbit ears' antenna. The other end of the adapter has the male end that screws into the cable.
Oct 28, 2014 | Televison & Video
Cable from converter box don't fit audio holes on back of TV
you need to buy some adapter radio shack sold him
Apr 24, 2009 | Televison & Video
Digital to analog converter box hookup
You will have to go to Radio Shack or Wall Mart, maybe Home Depot and get a matching transformer. That will have spade terminals on one end to connect to your tv and a round (75ohm male thread) to hook to your converter box.
Jan 08, 2009 | Televison & Video
Tv is not cable ready
You need to buy a cable output to television antenna input adaptor. One end will allow you to connect the cable box output to a cable input. The other end will hook up to you television just like a antenna, on the two screw hook -up. The usually can be purchased at any electronics store, like Fry's, Best buy,Radio Shack. Or you can buy them online. Use google to search cable output to television input adaptor's. Hope this helps you with your problem.
Nov 28, 2008 | TruTech PLV16320 Television
Hook up
On the back, there are three ports that are color-coded and match the cables. Take the yellow cable and plug it into the yellow port. Do the same with the red and white. Take the other end of the cables and plug them into your TV or VCR. Most TVs and VCRs have ports for the cables on either the back or front, and are also color-coded. Plug the yellow cable into the yellow plug on your TV/VCR, and repeat for the red and white cables.
Oct 24, 2008 | Philips Magnavox MWD7006 DVD Player
Hook up old tv antenna to converter box
how do you hook up a tv with just screws to a converter?
May 27, 2008 | Televison & Video
Hooking up Dvd to TV
Buy an RF adapter for 30.00. It takes cable in and dvd and
has one output to tv.When you play DVD's it auto switches!!
Saves alot of good tv's.........T.
Oct 25, 2007 | Orion STV2763 27" TV
iLO 3200 32 in. LCD Television Logo
49 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
