Question about APC Smart-UPS 1000VA UPS System
APC Smart-UPS 1000VA shut down and now will not power on. How do I troubleshoot? No power, no lights, nothing and I've never tried to troubleshoot a UPS before. Where do I start?? :-( Thanks Chris
  • Chrisssy Nov 23, 2007
    Thanks for the response. I checked the fuse and its fine. The twin batteries test at 4 and 6 volts and the battery connections are fine. My house circuits are fine and still no lights on the machine. I can understand if the unit doesn't have enough juice to power on, but I can't even get a light on! Any other suggestions would be appreciated?
    regards Chris
  • Anonymous Mar 28, 2014
    when i turn on the ups(APC Smart UPS 2200) it says the ups regulating high AC power
    Problem Solver:
  • 4 Answers
Hello Chris,
I have a similar unit and there is a fuse inside that can blow. Mine did. It worked again after replacing the fuse.
Another option...check the battery connections.
Another option...are the batteries getting old? If so, when they won't reach a certain level of charge the unit will not power on.
Finally, make sure you don't have a blow fuse or popped circuit braker in your home.
Hope this helps?
Posted on Nov 23, 2007
My apc smart ups sc 1000 do not switch on. when i need to chage no any light open in normal its open two secont then its quiet. how to do it?
Posted on Mar 13, 2009
2 Suggested Answers
  • 91 Answers
SOURCE: APC smart ups 1000va
Here we go again.. i encouter a lot of this problem. just change the whole front panel board and everything will work fine.
Posted on Aug 14, 2009
Apc sy lx
What's the problem? And is the UPS a Smart-UPS or Symmetra? Jotting down the exact model number will help.
Daniel • Power & Systems Innovations • 800.260.2259 •
** If this helped - Give it a Thumbs Up :) **
Dec 17, 2013 | APC Smart-UPS 1000VA UPS System
I've a smart UPS 1000VA SU1000INET I've had new batteries fitted. I put on to charge everything seemed ok. Went back to it about 2 hours later to find the 6 middle lights flashing.
Hi Ian,
Time for a new unit. Some component on the board level is malfunctioning.
If you need UPS, Surge, or Power Related help contact:
Daniel with Power & Systems Innovations 800.260.2259 or go to our website:
•• If this helped - click YES :) ••
Apr 15, 2012 | APC Computers & Internet
Problems with APC Smart-UPS 1000VA UPS System
Whenever you get problem with UPS call the concern technician for repair, you never try do any thing in UPS if you doesn't know about it.
Feb 04, 2010 | APC Smart-UPS 1000VA UPS System
APC UPS 1500 w/full load forces immediate reboot at pwr failure
With a 980watt load the run time is only 7 minutes on a brand new battery. If you have the system on full load your run time will be much less and it has likely damaged the battery. here is the APC web site page for your model. If you are running that much equipment I think you need either a bigger UPS or another 1500 and spread the load out.
Corporate Computer
Jul 24, 2009 | APC Smart-UPS 1000VA UPS System
Jun 11, 2009 | APC Smart-UPS 1000VA UPS System
Apc smart ups 1000va does not work propery. when i switch on they make noise continuous so how can u help me plse.
UPS has an internal fault, ask APC to replace it if there still have a warranty or send it to service center for repair
Apr 29, 2009 | APC Smart-UPS 1000VA UPS System
APC Smart-UPS 1000VA UPS System calibation problem
If battery charge indicator is flashing it should be UPS calibration issue, If all the LED indicator is light up in the front panel and UPS still can go online on battery mode you just need to replace the board on the front panel and the light will just back to normal state.
Apr 25, 2009 | APC Smart-UPS 1000VA UPS System
APC Smart-UPS RT 1000VA
Hello Dear Specialists I have a problem with the APC Smart-UPS smart 1000VA: when I insert the
power plug in the wall outlet in one ups , indicate the AVR Boost ups regulating low AC voltage, when I measuring the AC city power voltage that is 207v .whey this ups is not working about the AC low voltage? ,but it should be work from (170v ~ 230v) AC input volte.please solve this problem, which element of AVR from the ups is failed or wrong and give me free circuit diagram low & high AVR and charger and inverter circuits. thanks allot
Aug 20, 2008 | APC Smart-UPS 1000VA UPS System
APC Smart-UPS 1000VA is powered on but not working
Try turning the unit off for a little while, unplug it from the source even. afer about 5 minutes plug it back in and try it again. You may have a bad battery, how old is the unit. UPS batteries should be changed out every 3 year's, max every 5 year's if you want good reliability. At 5 years you are taking a chance.
Jan 18, 2007 | APC Smart-UPS 1000VA UPS System
APC Smart-UPS 1000VA UPS System Logo
2,404 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
