Question about Whirlpool Dryers
Whirlpool dryer will not Let gas through Valve...
After a quick browse of the site I found most people recommend changing the coils out. So I purchased new coils and replaced them. I then tested the coils and they make a click leading me to believe the valve is open however no gas is coming through the valve... I am certain that gas is getting to the unit. The orifice is clear. Someone Please help!
  • 1 more comment
  • matt798 Jul 24, 2009
    Sorry should have mentioned the ignitor is working well, It is brand new because I accidentally broke it when I removed the assembly to change the coils... OOPS.
    Hmm, The flame sensor appears to be working, the issue is the ignitor glows but there is no gas to ignite. But I am willing to follow your advice to test it.
    The model # is LGR4634JQ2
  • Whirlpool Master
  • 4,654 Answers
Look to see if the igniter glows while trying to ignite. You can open a rear panel on the back of the dryer and see if it glows. If not then the igniter may be the problem. Try that first and let me know the results. Thanks Sea Breeze
Posted on Jul 24, 2009
  • 1 more comment
  • John Tripp
    John Tripp Jul 24, 2009
    Ok then the flame sensor is possibly the only other part that is not picking up the heat. If it does not see the heat fro the igniter or the flame the shutdown is what is told to the gas valves. There is a way to test the flame sensor but I will need your model number to retrieve the information. Sea Breeze
  • John Tripp
    Email me and I will send you a Whirlpool Elecrric and Gas dryer Repair manual.
    appliancepartsse@yahoo.com
  • John Tripp
    Gas Burner
    Thermostat
    Thermal cut-off, Hi-limit
    thermostat
    Motor centrifugal switch
    Check for voltage (120VAC) to burner
    assembly.
    Check ignitor continuity.
    Check for gas supply.
    Check flame switch/ Flame sensor continuity, (0 ohms
    when cold).
    Check gas valves for continuity.
    Check thermostat for continuity.
    Check for continuity.
    Manually close centrifugal switch contacts,
    check for continuity, (1M-2M ohms
    If having trouble contacting my email go to
    http://appliancepartseast.blogspot.com/ and fill out the email me form. I will send you the manual in PDF format. Sea Breeze
Dryer will not heat gas
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Oct 28, 2009 | Whirlpool GGQ8831L Gas Dryer
I have a lgr4634jq1 gas dryer flame wont stay lit runs but no heat
1. Gas valve coils
2. Thermal fuse
3. Igniter
Sep 09, 2009 | Whirlpool Dryers
Won't dry clothes
1. Gas valve coils
2. Thermal fuse
3. Igniter
Aug 16, 2009 | Whirlpool LGB6300 Gas Dryer
Whirlppol model LGV6634BWO gas, no heat
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jul 26, 2009 | Dryers
Gas dryer , Flame cycles on and off a few times then ignigter glows but flame does not light
Jul 16, 2009 | Whirlpool LER4634J Electric Dryer
The gas stops after 15 seconds
Hi. The problem is with a set of defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective. They are responsible for the valve actions. if these solenoid based devices start to malfunction, this will heel the gas flow and, cause erratic behavior during the cycle(no flame).
Replacing the coils will fix this issue.
Jul 09, 2009 | Whirlpool WGD6200S Gas Dryer
My gas dryer does not heat how do I check the pilot
Check the following to address this issue.
1. Gas valve coils
igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
2. Thermal fuse
3. igniter
igniter may burn out or break. Replace the igniter if found defective.
Jun 24, 2009 | Whirlpool Dryers
Dryer not heating up
Check the following areas to address this issue.
1. Gas valve coils
2. Thermal fuse
3. Igniter
If all the above check out ok, replace the timer or, control board.
Jun 17, 2009 | Whirlpool Dryers
Gas Dryer does not continue to heat.
Check the Following to address this issue--
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 02, 2009 | Whirlpool Dryers
No heat after a minute of drying
Normal 0 Hi, You need to change the coils on the top of the gas valve. This is a very common problem with the newer gas dryers.
UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post thecoils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
May 30, 2009 | Dryers
Dryers Logo
178 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
