Question about Margaritaville Frozen Concoction (DM1000) Blender
Cleaning Please tell me how to get up/inside to clean. Thank You
  • 1 more comment
  • jsnbrant Mar 01, 2009
    cleaning?
  • Anonymous Mar 23, 2009
    Please, how can I clean this thing. It is not safe to use after it is so dirty!!!
  • kjm316 Apr 27, 2009
    hi, i can't seem to hold the button in while turning the paddle, even with help
You have to hold the button (above the blending jar) down while turning the rotating paddle in the ice hopper. It will eventually catch, then you can unscrew it, take it apart, and clean it. Just be careful not to cut yourself on the shaver blade.
Posted on Apr 08, 2009
Once the button "catches", I use a rubber kitchen brush handle to hold my button down.
Mine is really hard to hold down too, but using a rubber brush handle makes it very easy. I think maybe something might be wrong with mine, it didn't use to be so difficult, but this seems to work for now.
Posted on Jul 19, 2009
I use a small block of wood to hold the button in while turning the paddle. Even then it sometimes is still difficult. I started putting vegatable oil on the paddle screw to help lubrcate it.
Posted on Aug 16, 2010
Blade on MD95 not spinning
The shaft has probably siezed at the bottom near the blade. The seal can fail and let liquid inside the shaft and gunge it up.
Take the orange handle apart, then unscrew the four steel pins, then pull out the motor. From the blade end, take the screw from the blade and prize it off. Then pull the shaft out from the top and clean it. It may be stuck - push a blunt nail or similar in the bottom to free it. Clean the shaft and solidified debris inside the tube. Then reassemble carefully.
Feb 14, 2012 | Dynamic MD95 Handheld Blender
I just purchased the cooks 5 in 1 blender today and cleaned it out, per instructions, and put ingredients into it to make pesto. After it was done, I tried to loosen and take off the base (lid) and I have...
I'm afraid when that happened to mine, I ended up taking a sledge hammer to it! I had a very tasty shake inside that I just had to get to! Hence, that's why I need a new base!
Sep 18, 2011 | Cook's Essentials Smoothie Maker Work Top...
After starting the microwave, I get a "F-7" message on the display and it shuts down. What can I do to fix this? This is a whirlpool model # GH5184XPS-4.
hello,
what this error means indicate is as follow
The F-7 error code indicates that the water or oil (any liquid form) temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
what you need to do to fix up your is to do general cleaning up on your oven both internal and external do this with care and allow it to dry up it self.
please when doing this you will have to put off any form of power supply connected to the oven .
thank you and thanks for using fixya.
Jun 01, 2010 | Blenders
I have a new ultrexblender,doesn't work,even when blender pitcher is securely on, is there a pamplet telling the secret
some have a reset plastic pin for security reasons , so it will not turn on accidentally , check also check inside if the voltage is present to switch and motor need a test voltage Meter though . there is a hidden thermal fuse too in line of power cord inside . sneaky Mfr companies, can be purchased if needed @ Radio Shack 8-10 amperage rating about 6-10 dollars
Feb 26, 2010 | Blenders
I have i blend 5 speed and i turn it on and nothing happens
COMMON sorry to say , the problem is with the control , there is no fix except to return it . what i have been telling people is untill appliaces start getting better and not just this PRETTY JUNK from china go find a goodwill store and get a nice 20 year old blender and you will have it for years . or if you have the bucks buy a VITA-MIX there good but expensive good luck
Jan 15, 2009 | Krups 574 Power Xtreme VI Premium Work Top...
Back to basics auto serve smoothie machine
Ok here is a number for you too call Tell them your problem and they should have no problem sending you the part you need being that it is new!.....866-290-1851. they are available by phone Monday through Thursday 7:30am until 5pm and Friday 8:30am until 4pm C.S.T. You may need the make and model number (should be on unit!) I think they are a division of west bend inc.
Please rate my response!
Thank YOU!
Jan 15, 2009 | Back to Basics 600 Smoothie Plus Work Top...
Margaritaville Frozen Concoction (DM1000) Blender Logo
1,985 people viewed this question
Top Margaritaville Blenders Experts
john h
Tom Chichester
Are you a Margaritaville Blender Expert? Answer questions, earn points and help others
