Question about Oster 76076-010 Hair Trimmer
Power cord on flat iron broke
Need new one
    New Friend:
  • 49 Answers
This is a very common problem. Only way to fix it is to replace the cord, which is not all that easy. You'll need TWO regular philips screwdrivers (size #2) plus a couple of little ***** philips screwdrivers. And a soldering iron, solder, and heatshrink.
Start by popping off the two plastic covers on the hinge area. Sometimes they break: they're not really necessary anyway. Use the two screwdrivers on the screws on each side of the hinge: one will eventually come loose. Take the screw out, then use a screwdriver to push out the hinge pin. Keep track of any washers that might fall out. Carefully remove the big spring, and lay the two halves of the iron out flat. On the control side, there are several screws that hold the covers on: remove those carefully. If the cord is the kind with the swivel thing, you'll have to take out all of those parts. There will be two wires going from the cord into the circuit board: sometimes they are attached with tiny screws, sometimes they are soldered. You have to solder a new cord onto those wires.
You can buy replacement cords at most hardware stores, or steal a power cord off another (broken) appliance. Two-wire cord is preferred: flat irons don't use a ground wire.
Cut the power wires in the flat iron: they are usually blue and brown. Brown goes to the black wire on your replacement cord, blue goes to white. Strip the wires carefully, slip the heatshrink on, solder, then slip the heatshrink over the repair and heat it to seal it up.
Now the hard part is trying to secure the new cord, since it doesn't fit the way the old one did. I usually put a big zip-tie on the cord, which is then captured when you put the covers back on.
Once the cord is repaired, you can re-install the covers. Don't tighten the screws too much, they are really easy to strip out. Carefully insert the legs of the spring into each half of the iron, then hold them together while you slip the hinge pin back in: it's a little tricky. Then use the two screwdrivers again, this time to tighten the screws. If the plastic covers aren't broken you can snap them back in if you want.
See? I told you it's not that simple. But since a new iron is, what, $100, it's worth a try.
Good Luck!
chris
Posted on Jul 30, 2009
2 Suggested Answers
SOURCE: Defective power cord on CHI GF1001 flat iron straightener
My wife's flat iron had an issue with losing power while moving the iron around. I at first thought it was a cord issue, but before tearing into the cord, I disassembled her iron by popping off the two "CHI" covers from either side of the fulcrum. This revealed a screw which when taken out allows you to push the pin out releasing the handle's spring mechanism. Once opened, you can see the power-swivel thing-a-ma-jig and I saw the positive (red) wire had come off of the little flat board mounted on the swivel piece. I simply re-soldered the wire back on to the flat board and BAM! Good as new!
Posted on Nov 25, 2009
Would it be possible that a new electrical cord that would work with an antique GE Hotpoint Waffle Iron Cat. #119Y182 might be availabld
Using this info "GE Hotpoint Waffle #119Y182" for your search on eBay brings up 2 results for the power cord you need.
Oct 03, 2014 | Kitchen Appliances - Others
How to stop a flat iron from turning on and off when being used
sounds like a bad connection in the power lead be careful about a possible short hazard ZAP!!! Find a handyman to fix it.
May 16, 2013 | Sedu Pro Ionic Ceramic Tourmaline Flat...
THE PLUGONMY CHI IRON GOT BROKE NEED A NEW ONE
We can't sell a plug, but we can repair your CHI iron. Please visit www.flatironrepairs.com or email @ info@flatironrepairs.com!
Sep 07, 2012 | Chi Ceramic 1 inch Flat Iron GF1001USA
Where can I get replacement parts for Rowenta irons?
Fixya is unable to advise parts sources.
Aug 15, 2017 | Irons
I need a replacement power cord for chi flat iron model #gf1001
They don't sell replacement power cords, but you can send it in for repair to flatironrepairs.com.
Oct 06, 2011 | Chi Ceramic Flat Iron Gf1001
Iron won't stay running. I'm pretty sure it's the cord because if you move the cord the power is restored. Would a new cord solve the problem and where do you get a new cord?
With modern iron it can be difficult to renew the cord due to the special screws they use when making them. It does sound like the power cord is damaged. It may be cheaper to buy a new one from wallmart or similar store.
Jul 29, 2009 | Rowenta DX6700 Iron
Jan 26, 2009 | Oster 76076-010 Hair Trimmer
My iron needs a new cord
purchase it from==
http://www.powercord-manufacturers.com/
thank you for using FixYa
Nov 14, 2008 | Black & Decker Irons
Oster 76076-010 Hair Trimmer Logo
2,682 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
