Question about Mercury KVM400M-U Motherboard
I cant get any disply when i switch on my system
  • 53 Answers
Hi, in this case that your computer don't have any display and beeping sounds you can try the following steps to repair it.
1. Turn off your PC, then open the side panel of your PC case
2. Look for the memory RAM, maybe DDR/DDR2 then remove it.
3 Clean the DIMM socket and your memory card then plug it in
4. Now that you plug it in, turn on you PC, if it doesn't solve the problem try this next step.
5. Leave the memory on the DIMM socket and look for the Video card, unscrew and then clean the video card as well as the AGP/PCI-E port (sometimes it's just the dust that causing it) then plug it in again, then turn on your PC
6. If the step still doesn't solve the problem, then you have to replace your RAM or your Video Card (borrow to your friend RAM/VGA for testing which one causing the problem) either of the two is causing the problem.
7. Be sure also to check if there is power in your PC
8. Check for the PSU fan if running.
Hope I help you with your problem, good luck
Posted on Jul 24, 2009
My cpu is front light on but not go to disply powr fan is ok runing but not show the disply plz help me any on
check the display monitor cord to CPU if attached perfectly/check on off switch of display screen
Feb 23, 2015 | Computers & Internet
Gigaset a495 showing Register HS, and i cant making call.. plz give me a solution
gigaser A495 Handset ,
Actualy one problem may Handset Disply not work,Pls reply how to work in incoming and disply screen number.
Aug 18, 2012 | Siemens Gigaset A495 Cordless Phone
It does not switch on. if i on it, the disply only on but nothing is happened. it cant be regoganised by the computer.
Try this Remove the RAM & clean The RAM Slot & Clean RAM also then refit the RAM in the same place it may get Solved. If does not then show it to you System Engineer.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
Jun 18, 2011 | Computers & Internet
My mp3 cant on. at the time if switch on dispayed "Philips" and then disply disappers. please help; me
Hello.
First of all, try to charge it at least for an hour.
Then, check if it can switch on with a full battery.
If it still doesn't, you need to firmware upgrade it or just plug it to the computer and update it.
hope it helps.
Mar 17, 2010 | Philips GoGear SA178 MP3 Player
When the computer is switch onit disply the
Go to bios by pressing del or F2 depends on comp system and u can disable the error message by find enable/disable setting for case intrusion some where on bios
Jul 23, 2009 | HP Compaq ProLiant ML370 G3 Server
Error code 001. On/off switch trips off after 10 seconds
when you open the front door you,ll find under the disply a smal hole put eny nail in it a doller sign will apeer in the upper left corner of the disply pres
star , 4,star you will see another disply press the right arrow till you find error word press on it and then press star (astresk. the disply will turn off and on again theis error might be from the heater lamp if
it comes again change the hamps
May 08, 2009 | Canon NP 6545 Copier
Playstation 3
Go to the system options and try to switch it to default and see if that works or if you cant switch the ps3 options to default i recommend you probably config your PS3 options.
click the Thank me Button XD
I helped all i can
Mar 23, 2008 | Sony Playstation 3 (PS3) Console
Mercury KVM400M-U Motherboard Logo
115 people viewed this question
Top Mercury Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
vsri9
Computer Links
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
