Question about Refrigerators
Freezer and fridge not cooling. I hear the motor trip in and out occasionally. It is a MFD2560HES
  • 3 more comments
  • scottblue33 Jul 25, 2009
    Thanks for you responses. The fan is clear, so what should be my next move regarding the Start capacitor and Relay. Power down fridge, locate them, remove and items?. Replace them?
    Thanks.
    You also mentioned "overload", is that also a device or current?
    I have looked at the parts this model (MFD2560HES), and I have seen the relay and capacitor, but nothing about an overload.
  • scottblue33 Aug 12, 2009
    See Breeze,
    I have replaced the start relay and capacitor, the fan is free of obstruction, but the problem remains. I still hear the the relay clicking in every 2 or 3 mins, but no cold air. I can feel the fan blowing air in the freezer but it is not getting cool.
  • scottblue33 Aug 14, 2009
    Hi Sea Breeze,
    Thanks for your help.
    I have tested the resistance between the RSC and it passed the test; no resistance, but on the ground test, I got open circuit on all three terminals to ground.
    What's next?
    Alton.
  • scottblue33 Aug 19, 2009
    Hi See Breeze,
    Sorrry for the delay, I was out of town for a few days. I tried to connect to your email link from your last comment, but got an error page. Try putting http:// in front of your email address. I will try email you my phone #.
    Alton.
  • Refrigerators Master
  • 4,654 Answers
Sound like the start relay, start capacitor and the overload all located at and near the compressor cover on the side of the compressor need to be looked at to see if they are defective. When this happens this is the most likely reason. Let me know if you need more help, Thanks, Sea Breeze
Posted on Jul 24, 2009
  • 4 more comments
  • John Tripp
    John Tripp Jul 25, 2009
    Disconnect power and there is a cover on the side of the compressor. The start relay and overload are there. usually the start capacitor is nearby connected to the three. There is a start kit called a (3 N 1 Start Kit) that just may be the parts you need. http://appliancepartseast.blogspot.com/ Get a good look at them for heat damage the start capacitor should be checked.Thanks for the rate! Sea Breeze.
  • John Tripp
    John Tripp Aug 12, 2009
    I see you made several replies to me and today is the firt time I ever recieved a response from Fixya. I am very concerned when this happens. Because you responded and I did not get your message we both missed valuable time in the repair of this refrigerator. Here is my email. We need to take this one on one until we resolve this.
    appliancepartsse@yahoo.com
    864-812-1887
    HOW TO CHECK A COMPRESSOR
    Unplug the refrigerator and remove the back panel that covers the compressor. There should be 3 wires going inside the cover of the compressor. Mark all 3 and mark their location so if compressor is OK you can put them back in same order. The plastic cover may snap on and you may need to squeeze the sides to unlock the cover and sometimes there is a metal clip holding the cover in place. Remove the cover. May look hard but it's simple. There will be three connections under the cover and 2 will go through the start relay. Unplug them leaving the three prongs exposed. They may be marked R =Run, S=Start and C=Common. Set your meter on continuity and then begin by testing 2 at a time until you have checked S to R and R to C an C to S and S to R again. You should get a reading all the way around. If no reading between any of the pairs as you go around you should get no reading between any two the compressor has an open winding and is defective.
    Then if it passes that test then touch one probe to R and the other to the copper pipes or clean metal on outside of compressor, then S to metal outside and C to metal outside. If you get a reading this way even just a little. The compressor is a burnout. Then let me know what you find. Thanks, Sea Breeze
  • John Tripp
    John Tripp Aug 14, 2009
    Then the power is not being supplied to the compressor in some way. I am reviewing the drawings and if the compressor is not showing signs of damage then something has stopped power to compressor. Email me and let me call you so it don't cost you. I want to discuss this and ask a lot of questions. Sea Breeze
  • John Tripp
    You mentioned you had no resistance do you mean that you show continuity between RSC?
  • John Tripp
    If after replacing the start relay and capacitor you still had the clicking noise the compressor may be what we call a hard start. That can only be resolve on a temporary basis. You will need a hard start capacitor or replace the compressor. I don't recommend that. It just cost too much to replace. Some compressors when they reach a certain point they wobble inside and when stopped it's very hard to get them going again. That clicking noise is the overload making the noise because it tried to start the compressor and could not so the bimetallic disk inside clicks to stop the power from going into the compressor to prevent it from burning out. It also has an internal overload and it becomes weaker over time and just cannot take the struggle of starting and keeping the compressor running. Sea Breeze
  • John Tripp
    John Tripp Aug 19, 2009
    Just call my phone I will return the call or manually put appliacepartsse(at)yahoo.com into the email
Check for obstructions at fan on bottom of unit.
most common problem. clear so that fan turns
freely.
My fridge isnt cold freezer is our friend gave it to us she has no idea its our grage fridge fridigdare elite not brand new
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 10, 2011 | Maytag MFD2560HES Bottom Freezer French...
Maytag MFD2560HES stay at 33 freezer and 50 fridge
Sounds like an electrical fault.
check the balance or levelling of the unit.
could also be the compressor on the way out.
do you have any refigerant leaks ?
Mike @ Compurepair.
Feb 23, 2008 | Maytag MFD2560HES Bottom Freezer French...
Fridge won't cool. Freezer is still working
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 17, 2011 | Maytag MFD2560HES Bottom Freezer French...
Hi, I have a Maytag (MFD2560HES) fridge. The Freezer is working but the fridge is not cooling. What could be the causes? Alton.
you need to check and make sure the evaporator fan is running in the freezer compartment while the unit is in the cooling mode if it is then check the damper in the top of the fridge and make sure it is opening all the way to allow the cold air in the fridge.if ti does not open it needs to replaced.
If the fan is not running it needs to be replaced also check for excessive ice build up in the freezer compartment that would also block the air flow
Feb 23, 2010 | Maytag MFD2560HES Bottom Freezer French...
MFD2560HES refrigerator is not cooling proerly
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Feb 11, 2010 | Maytag MFD2560HES Bottom Freezer French...
MY FRIDGE FREEZER KEEPS TRIPPING OFF AND COOLING DOWN
Replace the overload/relay . This is the piece plugged onto the side of the compressor , with 2 or 3 wires going to it . This is if you are hearing an occasional " click " . It is easily replaceable .
If you do not hear a "click" , tap on the thermostat ( knob that adjusts the temp ) , and see if the freezer fan comes on . If so , then replace the thermostat .
Nov 08, 2009 | Refrigerators
Frige and freezer are not cooling!!! Help
chances are the fan motor has quit have a tech replace it if this is not the problem it could be a sealed system issue or a defrost problem
Dec 14, 2008 | Maytag MFD2560HES Bottom Freezer French...
Maytag fridge model # MFF2557HEB
This has to be the evap. fan motor. I have ran into this alot. If you take the vent off the topcenter of the freezer back panel useing a simple flat head unlock the clips. Once you see the fan blades push it with your finger carefully if it spins slow and little wobblely the motor has failed. If it turns not at all then check for 120V. going into the motor by unhooking it if you get 120V motor bad if you get nothing then the Jazzboard or Highvoltage control board has failed. To install a new fanmotor is easy take your time most parts come out with a flathead screw driver and 1/4inchnutdriver. Evap. fan motor is just clipped in.
Jan 19, 2008 | Maytag MFD2560HES Bottom Freezer French...
Warm fridge
If you are sure the fan is running either the damper motor (vent in fridge section) is bad and not opening or there is ice in the return vents and not letting air circulate. Take out the bottom drawers in the fridge and look down the two return vents in each corner with a flashlight. If they are iced up the top will not cool.
Nov 17, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
169 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
