Question about Homelite Garden
Have homelite weed trimmer that won't start
Rebuilt carb, replaced fuel line, replaced coil.
fuel to carb but not to cyl
  • 850 Answers
Recheck carb dighram is located properly! & that its sealed at the mounting of manifold to head!
Posted on Jul 24, 2009
Homelite Pro weed trimmer, model TLT254EBC. Where can I find a replacement carb?
go to any mower shop that repairs homelite and get one
go on line to homelite select the page for replacement parts and order on line .
previous pages give a price between $12 -30$ us.
try e-bay for carby
May 20, 2015 | Homelite Garden
Why wont my homelite string trimmer start. It has spark and gas and air.
Something could be keeping it from getting the right mix of air and gas. It could be a crack in one of the fuel lines or primer bulb. Maybe the carb needs rebuilt. I made some videos on how to do all that. I got all my parts form Home Depot, except the carb rebuild kit I got from Amazon. Hope this helps.
Jul 04, 2014 | Homelite Mighty Lite Lawn Trimmer
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
Bulb will not prime
Bulb or fuel line could have a crack or a clog in fuel line/filter or carburetor. Here's a video on how to change the bulb and fuel lines and another video on how to clean/rebuild the carburetor.
Homelite Tune Up
Apr 22, 2014 | Homelite Mighty Lite Lawn Trimmer
Any special procedures to starting an old ST-175 homelite weed trimmer that has not been run on over 8 years.
the carb and fuel lines will most likely need repair, i would mix a little extra 2 stroke oil in the gas on the first run, and a few drops 2 stroke oil in the cylinder is a good idea..oh and you might want to check the spark arrester on the muffler .. jay
Dec 31, 2011 | Homelite Garden
How to proceed starting a homelite weed trimer for the first time in over eight years.
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, @@
Dec 31, 2011 | Homelite Curved Shaft Trimmer Bump Feed...
I have a homelite weed eater(20699), and the fuel lines became detached. What line does the fuel filter go on? The line that primes the engine(with the little pump) or the other line!!
you want the filter keeping the inbound fuel clean to the bulb and the carb... the other line should be a return line to the tank...to pressure the system... So put it on the inbound to bulb and carb.
Jun 03, 2010 | Garden
H232R weed trimer won`t start no spark new coil
make sure the shut off switc isn't shorting out and the flywheel may not have enough magnetism in it to create a charge in th coil.
Apr 30, 2010 | Homelite Consumer Products 4.0 Amp, 13 In....
Blower will not start fuel is not getting to carb.
You may have a clogged fuel filter or a fuel line has a pin hole in it or the carburetor needs to be rebuilt. These are just a few suggestions I can offer.
Good Day.
Oct 14, 2009 | Homelite Mighty Lite Lawn Trimmer
My homelite weed wacker will only run in the choke position
Check the fuel lines for breaks/cracks. If they are o.k. then you will need to clean the carburetor. Disassemble the carb. and spray with carb. cleaner. Make sure the small screen in carb. is free of debris. Use a Den Tek Brush,(http://www.amazon.com/dp/B000V5MQ7Y/ref=asc_df_B000V5MQ7Y820727?smid=AKZ54EXMVZHXW&tag=dealt5228-20&linkCode=asn), to clean the small portals in carb. Reassemble and start.
NOTE: If your carburetor internal parts are more than 4 yrs. old, you may want to replace them. So buy a carb. kit.
Jim
Jun 10, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
338 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
