My Logitech Dinovo Edge is not recharging. When I put it in the charger the battery charging indicator light flashes red instead of green.
Im no expert but i had the same thing. would not charge, nothing i did made a difference until i did the following.
1- Had it in the cradle failing to charge as usual.
2- Went to the logitech setpoint (running the original CD version, no updates.
3- Clicked update the software.
4- got a error message after dealing with the update saying something along the lines of please reset this computer before running this command.
5- reset my compter and removed from cradle.
6- logged in and waited for the logitech software to update.
7- put my keyboard back in the cradle and clicked update again which it did. by this stage it was already charging as it should, green light.
this after MONTHS of not using it. so give it a go. it may NOT be broken.
Posted on Jan 26, 2010
  • Blakerb420 Jan 26, 2010
    Sorry, when i reffered to step 6-. i meant waited for the software to LOAD. not update, thats not relevent to step 6.
  • Mr Proctor Aug 18, 2011
    BlankerB420 solution to the problem worked for me.
  • 28 Answers
Were you having problems with short battery life before this happened? Most of the time if the battery is not recharging it needs to be replaced. Have never seen the red flashing light before though. It may mean that the battery has shorted out.
Posted on Jul 24, 2009
HELLO: OUR MILWAUKEE 48-59-2401 BATTERY CHARGER IS NOT CHARGING OUR 48-11-2401 BATTERY PACKS. WHEN YOU RUN THE PACK DOWN TO 1 OR 2 LIGHTS & PUT IT IN THE CHARGER BOTH RED & GREEN LIGHTS FLASH....
If both lights are flashing after you put a cool battery on the charger, the battery is bad. It could have a bad, worn or shorted cell or other problems inside and the charge will not charge it as long as it reads it as a bad battery. Rechargable batteries do have a finite life determined mainly by how many times you recharge them.
Jan 20, 2011 | Garden
Logitech DInovo Edge: When I charge the keyboard in the station, Setpoint tells me that an error has occurred while charging. The battery lights on my keyboard are flashing green and red. is my charging...
It looks to me like Logitech changed the design a bit. I found no such "CAP", however the problem did in fact lie in the same spot under the sleep button. I found a flat cable that had 6 jumper wires running through it to be the culprit. The cable was made too big, so they bent it to make it fit thus damaging it. I'm going to have to replace it, but just from playing with it a little I got my keyboard to turn on advertising a full charge and when I set it on the base I get a green light off happiness.
Jun 07, 2010 | Logitech diNovo Edge 9676850403 Keyboard
What does it mean when a household battery charger flashes red then green? The charger is a SYNERGY DIGITAL rapid quick charger. I'm trying to charge new AA Energizer Lithium batteries.
When the charger light is changing from red to green that is a indication that it is charging the battery. When the charge is complete the light will stay green until the battery is removed or the charger is unplugged.
Jun 06, 2010 | Energizer Rechargable Battery with Charger
Digimax i5 problem charging battery
■ Charging LED
Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
 Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
Jul 06, 2008 | Samsung Digimax i5 Digital Camera
Dinovo edge keyboard
try flicking the orange power switch on the side of the keyboard while the keyboard is sitting on the charger
Jun 02, 2008 | Logitech diNovo Edge 9676850403 Keyboard
Rechargable Batteries Battery Charger
When batteries are placed into the charge mode, the red light will come on.
When fully charged, on those units with a green light, the green light will be an indication that your batteries are charged and if your unit has no green light, the fully charged indication will be when the red light turns iff.
Apr 24, 2008 | Universal Battery Charger Charges Multiple...
Battery problem,...
I had this problem with mine so lets start by saying there are solutions!!
Solution 1:
Logitech state the battery cannot be replaced. It CAN. You can purchase the exact battery from ebay. Its a simple case of taking the orange backing off, removing all the screws (not forgetting the one hidden under the bluetooth address sticker) and popping the keyboard apart. From there, flip out the battery, pop in the new one, put it all back togeather and voila.
Solution 2:
Now if you dont care about your warrenty or it has none (as does mine) there are two contacts on the back of the keyboard which connect to the charger stand. Having took the keyboard apart, solder a wire onto each contact and then solder onto the battery connection contacts taking care to match red to red and black to black. Every time the keyboard is docked it will charge until you remove it. One other thing to note is that the low battery will keep flashing at you now and again (according to logitech you have about 10 mins use left until battery gives up) I have been using it for over 5 hours like this and its still going strong.
Enjoy.
Dec 07, 2007 | Logitech diNovo Edge 9676850403 Keyboard
Logitech mx1000 Not charging.
I had the same problem with the mouse MX1000 not charging when it is on its charger.
Then, I realized that I forgot to plug the adapter for the charger - this charger is not taking its power from the USB port but from an external charger!
Once I plugged the charger, the mouse recharged without any problem.
I hope this helps.
This mouse is really great, once this question of recharge is solved.
Stephan
Oct 27, 2007 | Logitech MX1000 Laser Cordless...
Charging the Mx700 cordless optical mouse
I found the following:
Red light slow blinking: Battery Low, please put mouse in charger and charge;
When in Charger Red light Slow Blinking: No charging, please check and clean Gold Plated contacts in charger and Mouse;
When in Charger green light Blinking: Charging in progress
When in Charger green light Steady: Charging complete
When in Charger Red light Fast Blinking: Mouse detects overvoltage during charging! Please clean Battery contact inside Mouse, or replace rechargable batteries NiMh 1500-2100 mAh only
Oct 02, 2007 | Logitech MX700 CORDLESS OPTICAL MOUSE...
Not charging
Try to turn on the Keyboard.
There's a switch in the right side of the Keyboard.
For more information download the User Manual at Logitech Site
Sep 15, 2007 | Logitech diNovo Edge 9676850403 Keyboard
Computers & Internet Logo
496 people viewed this question
David Payne
David Payne
