Question about Gateway MD7820U Notebook
Left click button got floppy
The left mouse pad button is a little floppy like a spring came out of it or something. i have only had this laptop about 2 months.
  • Gateway Master
  • 32,281 Answers
If this laptop was purchased new, I suggest you return it to the supplier to have it repaired under warranty. If you try to repair it yourself you may void your warranty.
Posted on Jul 24, 2009
Samsung laptop mouse left button
-If me I'll buy a new mouse.
Good luck
Mai
Jun 16, 2017 | Computers & Internet
Mark favorites delete internet
Left hand mouse = tap the bottom left of pad. Right hand mouse - tap bottom right of pad.
Nov 04, 2013 | Acer Aspire One PC Notebook
Unlock cursor for acer laptop
Your laptop comes with a touch pad that acts as a mouse. Instead of connecting a mouse each time you want to use your laptop, you can use the touch pad that is integrated underneath the keyboard. This comes in handy when you are in a tight spot such as in a classroom or on an airplane. At times, you may need to unlock the laptop touch pad because someone who borrowed your laptop disabled it. It may also be locked due to a slight malfunction that you can easily fix by enabling the touch pad in your computer settings.
Click the Windows "Start" button in the bottom-left corner of your desktop. Scroll up and click "Control Panel." Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner. Click the "Enter" button and then click the "Mouse" link. Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have. If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button. If you are under the touch pad tab, click the enable button. Click the "Apply" button and then click the "OK" button. Hope this helps.
Dec 08, 2012 | Acer Computers & Internet
Unlock mouse intel core 15
depending on your laptop this will vary
If the Fn (Function) button at the bottom left of the keyboard is pressed in conjunction with some other key on the keyboard it can result in the disabling of the mouse pad.
To enable your mouse pad on a Windows PC go to the Control Menu.
Under the Printers and Other Hardware option, click on Mouse.
Then, click on the tab on the top of the pop-up menu that says Device Settings.
The touch pad for your computer should come up as a selectable option.
Click on it and you will see the option to enable your device, then click OK
or
Right-click on a blank spot on your desktop. Scroll down, select "Personalize" and then choose "Mouse Pointer."
Click the "Device Settings" tab. Highlight your TouchPad in the "Devices" section. Hit the "Enable" button.
or
Click the "Start" button in the lower-left corner of your computer.
Type "mouse" in the field above the button. Click "Mouse" in the list of items that appear.
Click the "Device Settings" tab. Highlight the touchpad item in the "Devices" list.
Click the "Enable" button. Click the "Apply" button and then the "OK" button.
hope this helps
Sep 25, 2012 | Intel CTL E09L 2goPC Laptop
How to unlock a mouse on a laptop
On the top of your keyboard there should be F keys like F1,F2 etc.
Every F key has a little picture.When you see a touchpad picture press Fn+F5. According to my Laptop. For example if your touchpad picture is at F6 then you would press Fn+F6.The Fn key should be located near the ctrl keys. If this does not work then try the following steps:-
1 Click the Windows "Start" button in the bottom-left corner of your desktop. Scroll up and click "Control Panel."
2 Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner. Click the "Enter" button and then click the "Mouse" link.
3 Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have. If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button. If you are under the touch pad tab, click the enable button.
4 Click the "Apply" button and then click the "OK" button.
Apr 30, 2012 | Dell Computers & Internet
On touch pad, the left and right click below the pad, for the mouse, the left button doesn't click anymore?
Since the left button is a primary button it gets used quite a lot thus the button fails at some point in time.
Either the button has broken or the spring mechanism has broken.
Don't worry it can be repaired, claim warranty support if you can. The laptop needs to be partially disassembled and the buttons inspected. The button may need replacing.
Take care!
damnor01
Jun 09, 2011 | HP G70-460US Notebook
How do I do the right click function of a normal mouse on the pad mouse of an acer aspire 4741g laptop which does not have a right click button. I have tried to press and hold the Ctrl key and press the...
On your laptop, directly beneath the touch pad are two oblong buttons. They act as mouse buttons. The left one selects and the right one gives extra options.
Hope that helps.
Feb 03, 2011 | Computers & Internet
I dont want to be able to select something just by touching the little pad, i want to hafta left click, I'm constantly accidentally selecting something, just by touching it.
You can adjust your keyboard and the touch pad , controls with the adjustments in the menu for mouse and keypad options.
Also you can use the personal settings to get this right for your touch , adjusting the sensitivity accordingly
Sep 24, 2010 | Computers & Internet
How to repair the left click button on HP Pavilion ZT1135
Hey,
I had the same problem. It is pretty easy to fix. You have one of two options to follow.
1) Push down moderately hard on the left mouse button. After 2 mins or so, and the cap should back on to the button on the bottom
2) if number 1 doesn't work get a needle or pin and lift the left mouse button off. Then just apply very little, not even a drop, maybe half of a drop to the button and apply the cap back on and push down.
Sep 25, 2009 | HP Pavilion zt1135 Notebook
Open Questions:
Gateway MD7820U Notebook Logo
57 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
