Question about Canon Pixma MP800 All-In-One InkJet Printer
Paper jams as a result of string feeding in through the paper fee
Any ideas how to get inside the case other than with a sledge hammer?
    President:
  • 2,306 Answers
Both side covers come off first, then you unplug the scanner and remove. Canon uses a combination of screws and plastic clips to hold covers. You use a screwdriver and insert wherever you see a little triangle pointing to a hole. mark the plugs so they get back to the right place, good luck!!
Posted on Jul 24, 2009
Why does my Konica Minolta 1690MF have a fuser jam error whenever I print in color?
Everything you checked sound good. Might be printer software problem, and needs to be re-flashed. Software only available from secure web site that a technician would have, see what it cost if to much buy a new one with extra bells and whistles !
Jun 18, 2014 | Konica Minolta magicolor 1690MF All-In-One...
Dell 1720 printer single-sheet feed stopped working
Pull out the paper that is jammed and continue.
Nov 29, 2012 | Office Equipment & Supplies
I cant fix the paper jam problem. every time i take the paper jam out it jams again
I have had paper jams in five different places on this machine. It has jammed at the pickup point from the tray, in which case you have to remove the paper tray and pull the jammed paper out. It has jammed at the manual paper feed tray, in which case you just have to pull the jammed paper out of the feed rollers. It has jammed at the toner/drum, in which case you have to open the front cover and pull the toner cartridge out to remove the jam. It has jammed in the back of the machine where the paper feeds through to the output tray, in which case you have to open the small back panel and remove the paper. And it has jammed in the output rollers, in which case you have to reach inside the output tray and remove the paper. Then once the jam is cleared there are times when the machine has to be unplugged for up to 8 hours to reset before it will function properly.
Aug 16, 2010 | Brother MFC 8840D All-In-One Laser Printer
My printer will not feed the paper properly. It
There must be a jam on the left side then. Open and look inside for the paper issue
Jun 16, 2010 | Lexmark JetPrinter Z11 InkJet Color...
When feeding my paper it keeps pulling the paper
You need to replace the feed rollers. One side is probably worn. You should be able to buy a rebuild kit for it. Try ebay.
Nov 02, 2009 | Lexmark X2600 InkJet Printer
Paper feeds crooked and results in a paper jam.
Assume every time this happens something microscopic fell into that tiny pinch of an area. I have found everything from a Tostito crumb to a chip of drywall blocking my paper feed. Flip your machine over and shake it around til the little bugger falls out.
Oct 03, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Epson DX6000 paper jam problem.
Shake the printer and turn it upside down.....Be carefull in doing so...
Apr 09, 2008 | Lexmark All-in-One Printer with PictBridge
Paper feed
Your printer is politely asking you to please get a torch, and open the lid of unit and thoroughly check inside all over for a tiny jam of paper or something else. I am willing to bet you will find some jam. I would also switch it off, and wait a while before turning on and printing again. Good luck
Aug 31, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Paper Feed Problem
This is caused by the solenoid that is activated when picking up the paper. The solenoid is activated and the device goes through the motions of picking up the paper. It fails to pick up the paper or fully feed it past the leading edge sensor resulting in a jam error. You should replace the pick up solenoid assy and also the pick up roller and friction pads.
Jun 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Canon Pixma MP800 All-In-One InkJet Printer Logo
83 people viewed this question
old marine
old marine
