Question about Cell Phones
My I-870 WON,T POWER UP, EVEN IF i PLUG INTO WALL OUTLET, WHAT GIVES?
  • 4 Answers
The battery must be completely dry of charge. first charge the battery alone for 30sec using a 6volt dc eleminator and then put the battery in the mobile and charge for 15min an the switch on the mobile
Posted on Jul 24, 2009
Tv won,t come on makes beeping noise
Try unplugging from outlet for fifteen seconds. Press the power button for a few seconds "before" plugging back in. Now plug back into the wall outlet and try turning it on to see if this reset the TV's settings.
Sep 28, 2014 | Emerson Televison & Video
Tip
Laptop will not turn on, laptop will not power on, laptop will not start
Make sure your laptop battery has a charge. Plug it into the wall outlet for 30+ minutes and then try powering it on. When you plug it into a power source, usually the laptop will have a light indicating that it is charging. Look for a light. If the light does not light up, try a different wall outlet. <br />If it still does not charge, you may have a bad power cord, a bad laptop battery, the wall outlet may be bad or the laptop itself is damaged and will need to be serviced by a technician or replaced.<br /><br />Through the process of elimination you can narrow down possible causes.<br />-Try a different wall outlet(or by testing another device make sure the wall outlet is good)<br />-Try a different power cable.<br />-Try a different laptop battery.<br /><br />If none of the above help then you may need to have your laptop repaired(internal damage) or replaced.<br /><br />If your laptop is under warranty you should contact your laptop manufacturer or warranty policy holder to have it repaired or even replaced. <br /><br />If it is not under warranty you should look for local computer repair shops or technicians. <br /><br />-G33k<br />
on May 22, 2011 | Computers & Internet
Why wont my sharp lcd LC-32D44U turn on?
Well, there could a be few issues. First thing is to verify the breaker that gives power to that wall has not tripped off in the home's break power panel. If it is not tripped then verify the wall outlet that the TV is plugged into has a reset button, like a GFI (ground fault interrupt) If it does then verify that it has not tripped. If the GFI on the wall plug is tripped simply push the reset button back in and then try plugging in your TV power plug again. Then if that checks out or does not have a GFI outlet, verify that the power plug going into the back of the TV is not loose. Unplug and replug power plug that plugs into the back of the TV in and verify it is securely connected. Lastly, the power supply in the TV might have gone out.
Aug 22, 2014 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Tv won't turn on power indicator light not lit
As you mentioned the tv have problem with the power supply stage. Before suspecting for any intenal fault Chcek the following first. Remove the AC plug of the tv and connect the same in any other wall outlet. If then also it shows the same problem then its the powersupply board of your tv.
working on power supply board should be done by a skilled worker. Because there is risk of electric shock even if the power is disconnected. some of the capacitors will hold charge even if the power is not connected.
Here i have adde the link which will lead you the powesupply board.
Power supply board
Ajin
Apr 01, 2012 | Magnavox 32MF338B 32 in. LCD HDTV
My wii won't turn on
Wii Console Won't Turn On, and Has No Power Light Situation:
  • The Wii console won't power on, and the Power LED is unlit
  • The console powers on, but shuts off after a few seconds/minutes
  • Attaching an accessory to the console turns the power off
Information:
This issue can be caused by an accessory or power surge tripping the circuit breaker on the AC Adapter.
What To Do:
  • Check any accessories attached directly to the console to make sure that it is licensed and undamaged. Unlicensed or damaged accessories shouldn't be used with the console.
  • Try using a different wall outlet, or plug a different device into the outlet to make sure the outlet is providing power.
  • Perform an AC Adapter Reset. (How To)
Dec 23, 2011 | Nintendo Wii Console
X5470 constantly is powering on and off
Please try the steps below:
  1. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer.
  2. Disconnect the power cord from the power source. Re-connect after 30 seconds to a different known working power outlet. Bypass any power surge devices or power extensions/strips and directly plug in the cord into the power outlet in the wall.
  3. Re-plug the power supply into the printer.
  4. Press the power button if the printer won't automatically power on.
If the problem continues, please contact Lexmark Technical Support for further assistance. Thanks.
Nov 02, 2011 | Lexmark X5470 All-In-One InkJet Printer
Good morning. I was on the drive yesterday, all was fine. I just plugged it in, and it won't even go on. We had storms in the area lat night, and I know we lost power for a bit. It was plugged into...
First don't worry about the content of the drive, it is probably a burned powersupply or no power in the electrical outlet, check if you have power with a good multimeeter in the house outlet and at the plug of the power supply, if you have power than bring it to a certified technician it could be the system board inside that is dead, you could always take the drive out and plug it in a desktop computer to recover the data (I would be surprized that the drive it self is dead) but with lightening you never know!
Aug 20, 2011 | Iomega Computers & Internet
Power to switch, will not come on, is there a reset button?
Try to unplug the power adapter from the printer. Disconnect the power cord from the power outlet in the wall.
Wait at least 10 seconds before you re-plug the power cord into the power outlet (bypass any power strips or surge devices). Re-plug the power adapter into the printer. If printer won't automatically power on, press the power button. If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Jun 27, 2011 | Lexmark X75 All-In-One InkJet Printer
My Toshiba portege R 500 wont turn on until I remove the cmos battery, main battery and mains power. If I power it on again It gives the rtc battery error and prompts me to press f1, Pressing F1 gives me a...
According to Toshiba Support the remedy is to connect the laptop to the ac adaptor and plug in to wall outlet. Then turn it on and leave it on for 24 hours while the rtc battery charges.
Oct 11, 2010 | Toshiba Portege S100-S1133 Notebook
Seems to be working fine, scans the documents then says sending p.1, p.2 etc. then at the end it freaks out and all light start blinking. When I push the On button once it gives me a report that says...
1. Verify that the unit is switched on. Disconnect power cable from All-in-One and also from wall outlet.
2. Wait 30 seconds.
3. Plug in the power cable to All-in-One and also to wall outlet. 4. Check for the functionality.
Mar 16, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
