Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
My e61 group head on my Diadema UNICO Spl...
my e61 group head on my Diadema UNICO Splendor 1group lever machine is not working properly. THe shot comes out ok but when you shut the lever off to finish shot, the excess water and pressure does not come out the bottom exhaust port like it should, the pressure comes out of the group head when i undo the group handle, thus spurt coffee grounds and more importantly hot water all over my hands and space. Please help. I have changed valve assembly's rubbers etc...dont know whats going on..
Comments:
Jul 25, 2009
- Thanks so much for your help es, i will take the exhaust port apart again and see. All though i have redone this 2 times already and followed the instructions/pictures from the www.coffeeparts.com.au site on faema e61 group heads. The other thing i forgot to mention is that whilts the shot is in process and all thougth the shot comes out slow, the exhaust port does drip some water as the shot is flowing, it drips like a fast tap. So maybe i have done it wrong indeed. The 3 gaskets you talk about, what colour are they?? The rubbet ones brown? or the white plastic like ones.??
Thanks again for your help ES. Most appreciated.
Marcello - Australia
marc724@bigpond.comJul 27, 2009
- Hi again es, my machine head is an e61, if you have the time look at the pictures of it on this site.
http://www.mokaflor.it/lang_ENG/unico_splendor.php
that way you get a better idea of what i have.
And it is a pump assisted lever and not a full old style lever.
Hope this helps, as i took it apart again on the weekend and changed around some things, but still it seems to be blocked or water pressure coming out the group head....driving me nuts, i thought i had it.
Best Solution
posted on Jul 25, 2009
Rank: Guru
Expert
Rating: 86%, 326 votes
There might be one of 2 things going on,
1- the exhaust tube is blocked.
2- one of the three gaskets in the group is on backwards.
Comments:
Jul 27, 2009
- O.k the second part of the advice I gave you was for the long lever model machine. The head on your machine is the same as the San Marco levers.
Is the machine a full lever or a pump assisted lever?
Was this helpful?1 person thought this was helpful
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop...
(More)
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop espresso maker?
The Breville Die-Cast Espresso Machine, 800ESXL would not turn on. I looked at the electronic board...
(More)
The Breville Die-Cast Espresso Machine, 800ESXL would not turn on. I looked at the electronic board and changed the burned resistance (1.2 khoms) and the board ZD02 identified diod. The diod values I had was too week (it did work for one coffee and burned). I need to know what is the board diod named zd02 tolerance. Thanks
I have a Mr. Coffee Model JWX27 which is only 7 months old. The lights light up but the coffee will...
(More)
I have a Mr. Coffee Model JWX27 which is only 7 months old. The lights light up but the coffee will not brew and there is no indication of any heat or noise. I have tried the suggestions in the trouble shooting guide to no avail. I live in zip 01469. Is there an authorized dealer in the area?
our Krups 888 coffee/espresso maker 'blew' the rubber seal on the espresso side, so that the...
(More)
our Krups 888 coffee/espresso maker 'blew' the rubber seal on the espresso side, so that the pressure now comes out the side of the coffee holder instead of through the coffee -- big mess! Are replacement gaskets still available for this machine?
