Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
I replaced ink and it reads no catridge now - Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
  • 120 Answers
When you replace the ink, its improperly installed. The gold contact point is not properly connected to the end connector of ink.
Posted on Jul 24, 2009
The answer to my error 5100 question was replace pinhead and clean. where is the "pinhead"??
You need to open the top cover, access the ink catridge case(Where catridges hung), then look for other objects that look like ink catridges but smaller, that's where the catridges feed ink (into the print heads) usually separate by colors cyan, magenta and yellow Usually Black is a lone. Replace the print Heads and clean where the dirty ink drops.
Dec 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Ink catridge error after replacing my ink catrigdes
you need hp 22 and not hp 57
you can still refill the old one
check here how
Jul 14, 2010 | HP Officejet 5610 All-In-One InkJet...
I refilled the catridge it doesn't print
you have to clean and reset the cartridges. clean also your cartridge socket or holder.
Sep 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon mp460 printer. refilled cartridge not recognised
Dear Sir,
This is deffinately due to catridge circuit problem.Canon suggest that we have to replace emptied catridges with new genuine canon catridge they dont suggest refilling and also not give any support for refilling catridges. So you can replace catridge with new one.
This Happens due to weakining of catridge circuit portion or may long period printer not in use.
If you not want to replace catridges i will give you the possible hints it may fix refilled catridges.
1.Clean the catridge circuit portion with soft cloth,care must be taken that there is no smudge or ink traces on catridge circuit.
2.Clean the ciruit of printer catridge placing box present inside the printer .wipe out the any sumdge or ink traces.
Then re install the catridges. give the print if it shows error press resume button continuosly. I think it will fix your problem.
If it is not solution is replace the catridge with new one.
good luck
Aug 26, 2009 | Office Equipment & Supplies
Solution for "dell 946 aio reads error 1203 replacment cartridge wont read"
This is what I found on a Dell Community site.
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
To reset the error code, disconnect the power cord from the wall. Also remove the power brick from the back of the printer for 60 seconds. Then connect everything again.
Hope this helps
Ranjit
ranjit@supportminds.com
Jun 16, 2009 | Dell 946 All-In-One InkJet Printer
Replaced color cartiage, now only one color prints, red? Help
Try to check the level of your ink in your color catridge maybe is running low or empty then if its empty then remove the catridge then replace another color catridge full of ink then run your printer again. If you successfully installed new ink catridge then it will automatically reset the level of your ink monitor to full.
Jun 16, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
Have a Canon PIXMA MP150, just recently replaced the Black ink cartridge. When I make copies I will press the black ink button for my black copies but the only light that come on is the color ink button. ...
the problem occurs mainly due to following reasons
clogged catridge head
*clean it using ammonia solvent
bad contact of catridge terminals
*clean the contacts of both catridge and catridge holder
Apr 13, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Lexmark 3470, new ink dosn't work.
In this case as u said u used this Catridges in 2 printers then check if u have removed the Transparent Strip from the catridges mand if it is removed and still u face this problem make sure u have inserted the Catridges in the right slot........ U need to insert the colour catridge on the right side and the black catridge should go on the left side.... If no go get the catridges replaced....... Good Luck.......
Apr 06, 2008 | Lexmark X7350 All-In-One InkJet Printer
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
