Back to:
Tags:
Pelonis HB156T Ceramic Compact Heater
Hf-0022
posted by amysbay62 on Nov 21, 2007
heater tipped over and shut off automatically, which is good, but now, a few hours later, it won't turn back on
Amy
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Nov 22, 2007
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
tap the heater gently. i say GENTLY, in the area of the on switch. try this several times. usually the tip over mechanism will stick. i say gently.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on hf-0022:
I don't want to Accept this solution
Can you Help with these Heaters problems?
Heaters
what size conductors is needed for the 2yu69 dayton heater...
Heaters
I have a Honeywell HZ519 baseboard heater. We bought and...
Heaters
I need to locate an instruction manual for my Kenwood...
Heaters
My girlfreinds house is old and the furnace is a Royal Jet...
title: Sound driver
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
