Question about Coleman Powermate Premium Plus 6250W Portable Generator
Gen. wont start been stored since 03 bought new used twice
How to check to see if plug is firing and where is the low oil indicator for mikita g2800r
  • 57 Answers
If you have spark, squirt some starting fluid in the carb...remove the ait filter. If it starts and dies, the carb is gummed up and needs a cleaning. If no spark could be points, kill switch, oil switch etc.
Posted on Jul 30, 2009
    Scholar:
  • 173 Answers
As for checking for a spark, remove the plug from the engine, plug in to lead, then rest it somewhere convenient, with the threaded end to ground. (ie touching the chassis or frame)
The low oil indicator may be on the side of the engine, but I'm not certain.
If you discover that the spark is good, it could be a timing problem.
If there is no spark, it's probably the magneto.
I hope that helps.
Posted on Jul 24, 2009
2003 caravan: malfunction indicator light came on while driving about 2 miles from home . engine oil down 1/2 qtTrans. Fluid OK. Gas filled up 40 miles ago. I notice a slight soft put put noise
You said you engine oil was low 1/2 quart? was it just changed? or does it use a little between changes? Sounds like a mis fire which would have to do with sparkplugs, spark plug wires and the coil pack. I have owned a 97 grand caravan.I know yours is the next gen but drivetrain were just about the same. I had a few fuel injector wires that would cause a mis every now and then. The check engine light will be the key, There will be a code stored in there that will guide you to your answer. If you have 100,000mi on it. Its time for a tune up.As for the 1/2 quart on the oil, sometimes "lube service" Fills to the full line on oil stick. The oil filter will hold just about a 1/2 quart. So if "Lube service" did not account for this, after you start your van and check the oil it will show just shy of 1/2 quart. I would suggest getting the engine code first (mfi lamp)
Apr 03, 2016 | Cars & Trucks
I have fire and gas but will not start oil alert light on when crank
By fire I assume you mean spark at the plug. When turning the engine over with the key and the oil alert light comes on the spark is interrupted by grounding the system thus the engine cannot start.
First, look at the obvious things, check oil level if it is at the recommended level smell the dipstick if it has a strong smell of gas
change the oil and try to start it again. Be sure the plug is not soaked with raw fuel before you try the restart. I the problem persists you can disconnect the wire from the top of the low oil sensor.Try to start the gen. if it starts change the low oil sensor.
I hope this all makes sense to you , good luck with it.
BR
Jul 24, 2014 | Honda 3000 Watt Portable Generator
Stalling issue
an 03 has a gen 2 OBD that stores faults (not all faults trip the ck engine light) i would start there by doing a download (all faults)with a code ck'er , could be something as simple as an idle adjustemnt or maybe a vac line got broken/left off when doing the plugs/wire change , happens!!!
May 13, 2014 | 2003 Ford F250 Super Duty Crew Cab
I have a 1998 chevy blazer with a v 6 it will not start and I'm not getting any fire I change the plugs the distributor cap the Roeder and plug wires I am still not getting any fire what could it be I...
Recheck the engine trouble codes (reset any in history), then try to start it again. Check any new trouble codes - probably an ignition module or ECM problem.
Mar 30, 2017 | 1998 Chevrolet Blazer
PRESSURE WASHER
Check your ignition, sounds like you are not getting fire. Also check to see if it has an instrument that want let it start if the oil is to low. It could have Malfunctioned. Also double check your oil and make sure there's enough in it.
Apr 01, 2012 | Briggs & Stratton Garden
I have a 12kw lp gas genwrator that starts and runs for about ten seconds and then shuts down.after maybe 25 tries doing this the generator will stay running and then i try and start it again and it will...
These type of gens have a low oil shutoff. Check the oil. Always have spare spark plugs, a cheap fix. My gen always wanted a new plug every year. Look to see if it has a fuel filter.
Sep 24, 2011 | Generac 13,000 Watt / 13,000 Watt Home...
Will not start. May need a new spark plug. What size is it?
it should say on the side of the plug very carefully hold the coil wire about a 1/4 inch away from the head or other metal object and crank it and see if it is firing be careful and dont get shocked and make sure to stay away from gas tank and gas fumes and if it sparks chances are it is the plug
and check the oil level because it has a low oil shutdown switch and if it is out of oil or low it wont start
Feb 01, 2011 | Coleman Powermate Proforce 2500 Generator
I have a 1988 Winnebago Motorhome that has a 6.5 Generator in it that will not start. I have put many new parts in it including a circuit board, starter, new plugs, filters, changed the oil. It turns over...
Most times your looking at some sort of safety device that won't allow the engine to start.Especially after all the work you've done.Check for an electrical connection that would sense oil level,they are the most common and are designed to shut down the engine because of a low oil level.What it does is grounds out the ignition or spark output.I hunted around for something on your gen set but because of it's age there's nothing available.So this is all I can do for you.Last but not least,your local CAT heavy equipment dealer services your gen set.Hope this helps?
Jan 02, 2010 | Watts Onan Portable Generator - 5000 ,...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
198 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
