Question about GE Hotpoint® HTS18GBS Top Freezer Refrigerator
My refrigerator leaks from the inside on the top but the freezer is working just fine. It is a top mount refigerator model HTS18GBNAWW.
  • GE Master
  • 4,654 Answers
Leaking water inside of refrigerator. Ice maker is off and disconnected from water supply. Seals around doors look fine and seem to close tight, no signs of cracking. No cracks in interior of...
Hello Rick,
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Aug 27, 2011 | Kenmore 21.7 cu. ft. Top Mount...
It's a Viking freezer, not refrigerator. I know it is an older model but I don't know the model number. Ice forms on the coils on top of the freezer and the temperature inside the unit rises to...
VCBB363SS is a refigerator on top with a large door that opens and has a pull out drawer below that is a freezer
25 is too warm for freezer section
are coils snowed over complete or just on top 2 passes
if snowed solid defrost problem
if only snow on top fc fan is not running or system low on charge low side leak
unrelated if your mod is correct there is a hinge recall that should have been replaced
May 30, 2017 | Viking Professional VCBB363SS Stainless...
How msny cubic ft. is my 106.9750610 Kenmore refrigerator?
I tried downloading a manual for your Kenmore Top-mount refrigerator-freezer but it is no-longer available. the next best way is to measure the inside dimensions of your refrigerator. Measure the depth, height and width in inches. Times them together and divide by 1728.
example: if your inside of your refigerator is 30 inches wide by 20 inched deep by 50 inches tall you get 30 x 50 x 20 = 30000 cuin / 1728 = 17.36 cuft. Do the freezer section seperate to know thier individual measurements and add them together to get the total. I hope this helps. - subdriver
Mar 25, 2010 | Refrigerators
Kitchen Aid KTRC22EK leak inside refridgerator
It sounds like the drain for the defrost water is pluged. You can remove the back panel inside the freezer(ice maker will have to coe out first) and access the drain in the rear center of the freezer. Check the drain. It can be defrsted with a hair dryer(shut off the referigerator first) good luck, snugglepants
Nov 03, 2009 | KitchenAid KTRS22EL Top Freezer...
Refigerator temp is rising Lower freezer compartment seems to be fine
Check rear wall of freezer by feel for frost. Frost indicates likely problem in the defrost system. Defrost heater (in freezer), defrost thermostat (in freezer) or 1 of Defrost timer or Defrost control (Circuit board) generally located in Refrigerator compartment but may be inside rear of outer case.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Model and brand is always helpful when requesting information.
Aug 22, 2009 | Refrigerators
Water is leaking on the top shelves in my kenmore refriderator water is leaking on the top shelves in my kenmore I have water leaking onto the top shelf of our Kenmore refrigerator. I believe it goes into...
During the defrost cycle heaters inside the walls of the freezer turn on to melt the frost. The melted frost "water" is supposed to drain into a pan under the fridge where it will evaporate. I think the drain line from the freezer to this pan may be blocked. I'd also check the seal on the freezer door. If it's not sealing well it lets a lot of moisture into the freezer which means more water during the defrost cycle. I'd also recommend checking to make sure the ice maker is not leaking.
May 31, 2009 | Kenmore 64802 Top Freezer Refrigerator
Refigerator not cooling and hot to the touch
It sounds a lot like lost charge caused by a leak in your system. If your unit has been moved or improperly cleaned, some part of the pressurized system may be damaged.
Refrigerant (with very small molecules) may leak off over many years but it shouldn't happen in the single digits.
Apr 05, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Kenmore top freezer leaking water on the inside when defrosting
MAKE SURE THE FAN IN REAR OF FREEZER COMPARTMENT IS RUNNING , SOME TIME YOU MUST DEPRESS THE DOOR SWITCH ON THE FREEZER DOOR TO WATCH FAN IF NOT REPLACE FAN , NOT BAD MOST UNPLUG , IF THIS IS NOT IT YOU COULD HAVE A INTERMITTENT DEFROST TIMER OR A BAD DEFROST HEATER
Feb 24, 2009 | Kenmore 18.9 cu. ft. Top Mount...
GE Hotpoint® HTS18GBS Top Freezer Refrigerator Logo
262 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
