Question about Kenmore 22422 Top Load Washer
Kenmore washer 110 92581110 top load
Washer leaks it appears to be from tub may be the seal how do I fix or is it worth it
  • 749 Answers
If its from the tub then you should fix it! the water seal could be worn out already. it would result to slipping of the belt ans thus poor spinning is produced! poor washing.
Posted on Nov 21, 2007
Gunk gets on clothes-stains them,i pulled agitator out and cleaned it off ran bleach thru-its better but still getting on clothes
The problem may be the seal on the transmission failing. If this happens, grease from the transmission (necessary for it to function) will leak and float (recall from science class that oil is less dense that water) up into the washer. As the grease enters the tub, it stains your clothes.
Washer Transmission Replacement Whirlpool Kenmore Top Load Washing Machine...
Washer Leaks Water GE Top Load Washer Tub Seal Replacement Part WH02X10383
Jan 21, 2016 | Amana 3.2 cu. ft. Top-Load Washer
Is repair time and parts extensive for this type of repair? Kenmore Front Load Model# 110.45986401
Confirm that it is not the door seal. The door seal can easily be replaced and the parts are available.
You would expect that any water leaking around the door seal would migrate down to the lowest part of the tub leaving the appearance that the leak is where the two half's of the tub are joined by the retaining clips
Replacing the seal between the two tub half's is a different story as compared to the door seal. The tub seal is definitely do-able, but not for the faint of heart!!
Washer Tub Seal Replacement Frigidaire Front Load Washing Machine Repair...
If the leak is very very small I might wait until a major overall is require such as the tub seal/bearing. If I chose to wait I would monitor the situation.
Inspect the area at the hub of the pulley looking for streaks of rust.. If there is an indication that water is leaking past the basket tub seal than doing an over hall now may included front door seal, tub seal, bearing and basket seal replacement.
Dec 30, 2015 | Washing Machines
Maytag Washer Model LAT9416AAE - Top tub seal is leaking or where the tub and the shaft meet is leaking. What would the cost be for parts and repair (service fees, labor, etc.)?
The usual charge when i have repaired that is around $375
in addation to the seal a tub bearing would be required since the seal has leaked it very likely has rusted the bearing. To replace those both the inner and outer tub have to come apart,the breakdown would be
Service Fee $75
Labor $100
labor and service fees vary from company to company and that is probably low,yet it is a great washer and may be well worth investing in to repair
Aug 06, 2011 | Maytag LAT3600A Top Load Washer
Kenmore 500 series top load washer. water on the floor during water pump out cycle. This does not appear to happen on prement press cycle, but does happen on normal cycle. Have no tried the heavy duty...
Could be a tub seal leaking (not likely), or water pump leaking (very common), cracked outer tub, leaking hose. You would really need to take washer cabinet off machine to be able to see where it's actually leaking.
Sep 30, 2017 | Kenmore 22422 Top Load Washer
My washer is a kenmore, it was working fine the durning the spin cycel made a different sound, I came over afew min later to find water on the floor
could have broke your drain pump it is attached to the motor and the seal there could be leaking, also check your hose's , also your tub seal could be leaking,it's between the tub and tranny. and check your outter tub,could have gotten cracked!
Feb 14, 2010 | Kenmore 3.2 cu. Super Capacity Plus Top...
Kenmore washer leaking water out bottom in rinse or spin cycle.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Jan 24, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Mar 01, 2008 | Frigidaire GLWS1233A Top Load Washer
Kenmore 110-91564100 Top Load Washer Problem
Sounds like my 91 Geo Merto LOL! Anywho when it washes the pump spins one way and water is basically thrown back into the tub, then when on spin it spins in the opposite direction and if there is a hose leak past the pump or the pump itself leaks it will come out of the drain system. As for the thump, check under the unit for anything that shouldnt be under there getting caught up in the mechanics. Let us know :-)
Sep 14, 2007 | Kenmore 23822 Top Load Washer
Kenmore 22422 Top Load Washer Logo
144 people viewed this question
Sal De
 Brian Main
Brian Main
