Question about Microsoft LifeCam VX-3000 Web Camera
Installer - Microsoft LifeCam VX-3000 Web Camera
    President:
  • 1,884 Answers
You must have got a CD of SW with the webcam. First instal the drivers and other SW and then connect the webcam to your computer. The PC will recognize the New HW only if the drivers are loaded already.
Posted on Jul 24, 2009
Need timing belt digram for a 2000 kia sportage
  1. Install lower timing belt cover.
  2. Install upper timing belt cover.
  3. Install power steering drive belt and adjust belt tension.
  4. Install fan pulley.
  5. Install generator drive belt and adjust belt tension.
  6. Install A/C drive belt and adjust belt tension.
  7. Install splash guard.
  8. Install fan and fan shroud.
  9. Install 4 fan bolts. Tighten to 24 ft lb (33 Nm).
  10. Install fan shroud mounting bolts.
  11. Install fresh air duct.
  12. Connect hose to resonance chamber.
  13. Connect battery negative cable.
Apr 17, 2013 | 2000 Daewoo Nubira
How do u set timing on it? 1.8 engine
Installation
Install crankshaft sprocket on crankshaft.
Make sure mating marks on crankshaft sprocket face front of engine.
Position crankshaft so that No. 1 piston is at TDC and crankshaft key is at 12 o'clock.
Install slack side timing chain guide and timing chain tension guide.
Install timing chain on crankshaft sprocket.
Set timing chain by aligning its mating mark with that on the crankshaft sprocket.
Make sure sprocket's mating mark faces engine front.
Install camshaft sprockets.
Set timing chain by aligning mating marks with those of camshaft sprockets.
Install camshaft sprocket bolts to correct torque.
Apply new engine oil to bolt threads and seat surface.
Install chain tensioner.
Before installing chain tensioner, insert a suitable pin into pin hole of chain tensioner.
After installing chain tensioner, remove the pin.
Install timing chain guide.
Install O-rings to cylinder block.
Before installing front cover, remove all traces of RTV silicone sealant from mating surface using a scraper.
Also remove traces of RTV silicone sealant from mating surface of cylinder block.
Apply a continuous bead of Genuine RTV Silicone Sealant or equivalent to mating surface of front cover. Refer to RECOMMENDED CHEMICAL PRODUCTS AND SEALANTS .
Check alignment of mating marks on chain and crankshaft sprocket.
Align oil drive spacer with oil pump.
Place timing chain to the side of chain guide. This prevents the chain from making contact with water seal area of front cover.
Install front cover.
Make sure two O-rings are present.
Be careful not to damage oil seal when installing front cover.
Install cylinder head bolts at engine front side as shown in Fig. 55.
Tightening procedure:
Tighten bolts (1 - 4): 6.3-8.3 N.m (0.64-0.85 kg.m, 55.8-73.5 in.lb).
Install oil pump drive spacer.
Install water pump and water pump pulley. Refer to REMOVAL AND INSTALLATION .
Install idler pulley and bracket.
Install RH engine mounting bracket
Install RH engine mounting.
Install oil pan. Refer to INSTALLATION.
Install crankshaft pulley.
Remove ring gear stopper.
Install starter motor.
Install cylinder head front cover.
Apply RTV silicone sealant to cylinder head front cover.
Use Genuine RTV Silicone Sealant or equivalent. Refer to RECOMMENDED CHEMICAL PRODUCTS AND SEALANTS .
Install Camshaft Position Sensor (PHASE).
Before installing rocker cover, apply a bead of Genuine RTV Silicone Sealant or equivalent, to mating surface of cylinder head as shown in .
Install rocker cover gasket into rocker cover.
Install rocker cover and tighten in numerical order as shown in
Install spark plugs.
Install ignition coils.
Install front exhaust tube.
Install front/right-side splash undercover.
Install front RH wheel.
Install drive belts.
Adjusting drive belt deflection..
Nov 29, 2010 | 2002 Nissan Sentra
I want to install printer hp deskjet d2460
How to install Printer
Follow these steps to install the downloaded software.
  1. When the download is complete and you are ready to install the files, click Open Folder , and then click the downloaded file. The file name ends in .exe . NOTE: If you closed the Download Complete screen, browse to the folder where you saved the .exe file, and then click it.
  2. You can accept the default place to save the files. Click Next , and then wait while the installer extracts the files to prepare for installation.
  3. When the Install Wizard starts, follow the on-screen instructions to install the software. NOTE: If you have previously installed the software and are changing the connection type from USB to Ethernet, click Add a device when the Uninstall the software or Add a device window opens. For a Full Feature installation, you choose what type of installation you want. The following information might help you decide which installation type to use. Typical (Recommended) Minimum For full use of all your product features : HP includes valuable software to help you get the most out of your product.
    HP designed this installation type to work for most users. A custom type of installation might be available for your product. This installation allows you to install the minimum software required or the preferred software. Use this type of installation only if you have one of the following reasons:
    • The computer is low on hard disk space.
    • You attempted a recommended type of installation and received errors. (If errors occur during the recommended installation, fix them before trying a custom installation.)
Apr 10, 2010 | HP Deskjet 2460 Printer
Lost my installer. i reformat my computer. how cn i install the printer without the installer HP Deskjet D2360
Nov 11, 2009 | HP Deskjet D2360 InkJet Printer
F380 All-In-One won't print
first of all you need to install the software..these are the steps to install the software please follow the steps below
Two installation options are available when installing the software and drivers from the product CD. The recommended install installs everything your device requires to work, including a suite of software recommended for your installation. The custom install allows you to choose what software to install. The recommended install is designed to work for most users. Use the custom install only if you have one of the following reasons:
  • Low hard disk space on the computer.
  • You do not want the additional software.
  • Errors occur during the recommended installation. NOTE: If errors occur during the recommended install, fix them before doing a custom install.
Recommended install Complete the following instructions to install the software: CAUTION: Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 10 feet (3 meters) long. NOTE: Choose unblock or accept on all firewall messages or the install will fail.
  1. Insert the software CD into the CD-ROM drive of the computer. The software installer starts automatically. NOTE: The User Account Control screen might display. Click Continue .
  2. Click Install on the Thank you for purchasing from HP! screen.
  3. Click Next on the Welcome to the Install Wizard... screen.
  4. Click Next on the Do Not Block HP Install Wizard Processes screen.
  5. Select Yes or No on the Automatically Check For Updates screen and then click Next .
    • Choose the Yes (recommended) option to check for updates through an Internet connection.
    • Choose the No option if you do not want to check for updates.
  6. Select Recommended on the Installation Options screen, and then click Next .
  7. Follow the instructions on the screen that displays to finish installing the software.
Custom install CAUTION: Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 10 feet (3 meters) long. NOTE: Select unblock or accept on all firewall messages or the install will fail.
  6. Select Custom on the Installation Options screen, and then click Next .
  7. Select which software to install by selecting or clicking to clear the check box next to each item on the Custom Installation screen. Click an item to see its description and the required disk space. NOTE: You must install the drivers and the HP Imaging Device Functions for the buttons on the front panel to be functional.
  8. Follow the instructions on the screen that displays to finish installing the software.
  9. once the software installation is complete try to print that should work
Mar 09, 2009 | HP DeskJet F380 All-In-One Printer
Installation?
Hai,
first instal program software from the site provided by dell install in d/drive and strat your program if any case error pops up retry by software from intel
Dec 25, 2008 | Dell Inspiron 6000 Notebook
T3 sync with PC- Windows XP
Need to reload software in pc. Dropping stuff. If you found this helpful, please post as so. If you need to knwo how, live chat
Sep 14, 2008 | Palm Tungsten T3 Handheld
I Have a Hp Deskjet F380 ALL-In-ONE Printer-Scanner-Copier,I Need Know How to install a print driver for my Hp Deskjet F380 Printer.Thank You, I Need Help????
How do I download and install the software? To download the software, do the following:
  1. Click here to go to the Software and Drivers page for your product.
  2. Click your operating system.
  3. In the Driver section, click the appropriate software driver.
  4. Follow the instructions on the page that appears to download and install the software.
How do I install from the CD? Two installation options are available when installing the software and drivers from the product CD. The recommended install installs everything your device requires to work, including a suite of software recommended for your installation. The custom install allows you to choose what software to install. The recommended install is designed to work for most users. Use the custom install only if you have one of the following reasons:
Aug 19, 2008 | HP Office Equipment & Supplies
Install A4 tech PK635 M web cam without cd installer
help me solve my problem give me installer
May 19, 2008 | A4tech PK5
how to install a A4 tech PK 635 M web cam without using cd installer?
how to install a A4 tech PK 635 M web cam without using cd installer?coz ive lost it.
installer
May 03, 2008 | A4tech PK5
Microsoft LifeCam VX-3000 Web Camera Logo
165 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
