Question about Dryers
Dryer turns on, but does not heat up? is this the heating element?
  • 6,784 Answers
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
***If the Thermal fuse is in good conditon, you will need to replace the element.
Posted on Jul 24, 2009
Troubleshooting heating element on samsung steam dryer
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot or not heat at all. . If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Dec 10, 2016 | Samsung Dryers
Changed out rear bearing and heating coil now something smells like its burning
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Oct 02, 2012 | Frigidaire Electric Dryer
Hi My dryer does not get hot. It seems the heating element has blown. It does have a smell to it similar to a hair dryer that has been over worked. I am not sure where to find the heating element to...
It is located in behind the drum.The heat sensor may be also gone and not the heat element.The sensor may be stuck in the spot where it turns of the element.....If u hold a lighter to one it should click to turn the heat element of at a certain temp.Hope this helps u out Ms Young.
Aug 12, 2010 | Maytag PYG4558A Gas Dryer
Barrel of dryer turns but no heat
Your heating element needs to be replaced, or the 240 breaker in your breaker box has tripped. I was a maytag technician for several years...So, check your breaker box for any tripped breakers or the heating element in the dryer needs to be replaced, or the t.stat for the element has blown.
Apr 26, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Kenmore Dryer, heating element doesnt turn off
remove the back of dryer and remove the heating element from the heater box,check to see if the wires in the box are touching the heater box walls any where,this would make the element stay on all the time,also check the high temp thermostat on the left side bottom,this is the on off thermo for the heating element-mike
Feb 16, 2010 | Kenmore 63942 Dryer
No heat coming from dryer
Double check the circuit breaker for the dryer (Electric Neptune). Turn it off, then turn it back on. Its possible that the breaker may have tripped for some reason, but wasn't able to trip all the way.
Does the interior of the dryer get warm at all? You could have a 1 of multiple heating elements that has shorted. If no heat at all, the likely a heating element has opened up. Unplug dryer from wall (turn off circuit breaker first!). Use a ohm meter to measure and check continuity of the heating elements.
There may also be a sail switch in the air path of the dryer. The purpose of the sail switch is to keep the elements turned off until there is enough air blowing through the dryer. This helps prevent fires, as well as shrunken denim.
Jan 04, 2010 | Maytag Neptune MCE8000AY Electric Dryer
Procedure to replace heating element on 84152 electric dryer
This is a simple repair. Just follow these steps:
1. UNPLUG dryer. Dangerous voltage is still present even with the dryer turned off.
2. Remove the dryer vent exhaust hose and remove the back of the dryer.
3. The heating circuits are located on the right hand side (as viewed from the rear). The heating element is located inside the heater box. Simply remove the mounting screws on the heater box and remove the two wires on the heating element terminals. NOTE: You can leave the two remaining components (Thermal Cut-Out and Hi limit Thermostat) connected on some models. If you need to remove them in order to remove the heating element make sure you label the wires.
4. Locate the mounting screw(s) on the outside of the heater box that hold the heating element in place.
5. With the mounting screw(s) removed the heating element will slide out of the heater box.
6. Insert new heating element, making sure you avoid touching the coil and align the screw holes so you can reinsert the mounting screws.
7. Re-install the heater box and any remaining components.
Now...are you sure you have a bad heating element? Just because a dryer does not heat, does not necessarily mean the heating element is bad. The following link explains:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
The most common fail item that causes a dryer heating circuit failure is a blown TCO caused by poor dryer ventilation. Just something you may consider.
If you have any questions, please let me know. I hope you find this information helpful.
Aug 22, 2009 | Kenmore 84152 Electric Dryer
Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Jan 21, 2009 | Dryers
The dryer works but does not heat
Before you buy an expensive heating element change out the thermal fuse. It's only about 15 dollars for a fuse as opposed to around 100 dollars for a heating element. Both can be purchased at a appliance repair shop. The thermal fuse is usually located near the heating element housing and has two wires coming off of it. Make sure you unplug the dryer first though. If the thermal fuse if dead then your heating element will only heat for about a second or two at a time. The way to check this is to open up the dryer so you can see the heating element. While it's running watch it and it the heating element comes on and then turns off then the thermal fuse is bad. If it doesn't come on at all then the heating element is bad. Wait a good 5 minutes though before determining if the heating element isn't coming on. Sometimes it takes a bit before it engages. I hope this helps you and if you have any more questions feel free to ask me. Good luck.
Jan 08, 2009 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
81 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
