Question about Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Not getting spark
I was just given an older troy bilt pony with a tecumseh hs40 55508k motor on it. I just put a new coil, condenser, and points and am still not getting spark. What now?
    President:
  • 1,776 Answers
I would check that I didn't have a key sheared off in the flywheel, that the start/stop switch isn't faulty, and that there is no missing or weak flywheel magnet. Hope this helped and best wishes.
Posted on Jul 24, 2009
I have a troy bilt pony with a 6hp Tecumseh engine. It's difficult to start and when I get it started I have to leave the choke on or it will die. Also it doesn't run as it should. I drained the...
I recommend cleaning the filter with gasoline if its foam or replacing it if its paper. If this doesn't fix the problem you should remove the carburetor (in between the air filter box and the engine) and cleaning it thoroughly with carb cleaner from your local parts store.
Jun 17, 2011 | Troy-Bilt Pony Garden Tiller
Installed new points and condenser on a Troy HH60 with a Tecumseh Motor. Ohmmeter shows dead short across points when points are broken and apart...No spark. I must have wired something back wrongly or??...
Check your wire connections and make sure nothing is touching the metal case. sometimes the double crimped connector for coil wire has a wire strand hanging out. Check without wires on for short then attach one at a time checking each time for short. could be defective condenser . Thanks for using fixya.
May 11, 2011 | Troy-Bilt Pony Garden Tiller
I don't think my tiller is getting any juice to the sparkplug. I changed the sparkplug and air filter, checked the oil and gas, but it still won't start.
disconnect the kill wire on the motor and then see if you get spark. If so its your switch, if not it either points or electronic coil or regular coil or condenser problem did you gap the pints correctly and was there a problem b4 you changed the points.
May 03, 2011 | Troy-Bilt Pony Garden Tiller
I have an older Troy-Bilt tiller (model & serial # unknown) that when I start it (manual pull) it runs for a second and then shuts off. I checked the spark plug, fuel line and inline filter, fuel, oil...
could be bad coil. does it stay running with choke on? or half on, if so its a gas problem. could be the main jet is plugged in the carb. Or water in the carb bowl. Remove the bowl nut and let some gas run out the put it back in and try it. just guessing as not much info to go on.
Apr 26, 2011 | Troy-Bilt Pony Garden Tiller
Wont spark
check flywheel sounds like keymay be broke
Jul 14, 2010 | Troy-Bilt Pony Garden Tiller
I need a owner's manual for a early 80's Troy-bilt Horse tiller It hasn't been used for a couple of years and we can't get it started. Want to make sure I have the correct spark plug and the correct fuel...
Ebay has manuals on CD for $6.99 with free shipping. If the spark plug is firing when you crank the engine you probably have a gummed up carburater and it will have to be cleaned. They will do this when they set for a while. Not sure if that will have points and condenser or not but if it does and will not fire they will have to be cleaned or possible replaced also.
Feb 20, 2010 | Troy-Bilt Pony Garden Tiller
I have an older Troy-Bilt Pony Garden Tiller witha
From what I read you need a new rewind clutch and the spring and cord go into the housing. Briggs is easy to fix. contact me at kerryjonjon@yahoo.com and I can send you what you need or you can send it to me and I will repair it very cheap!! Parts are available at almost any small engine parts place.
Jul 17, 2009 | Troy-Bilt Pony Garden Tiller
Need free repair manual down load on Troy Bilt Junior 500 30 82
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
Free manuals for Troybilt here
May 17, 2009 | Troy-Bilt Pony Garden Tiller
I have 1980's model troy built pony tiller that won't fire
Great machine, I had one. The points need replacement. Look for a gadget that replaces the points. I found mine in PepBoys. Search the Internet, the cost was about $5.00.
Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
May 05, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt Pony 6.5 Hp Rear Tine Tiller Logo
295 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
