Question about HP OfficeJet 7130 All-In-One Printer
When I try to make a copy, the screen says scanner failure - turn power off then on again. I do that and it still won't copy. I unplugged the printer and plug it back in and it lets me make one copy. Thank you for your help. Other than this, I have never had a problem and really enjoy my HP printer.
    President:
  • 3,085 Answers
A replacement SCANNER ASSEMBLY would cost as much as a new printer.
Posted on Jul 25, 2009
  • Leroy Elliott
    Leroy Elliott Jul 25, 2009
Printer will not scan
he HP All-in-One product displays one of the following error messages on the control panel when scanning or copying:
  • Scanner failure, power off and on
  • Scanner System Failure
  • Scanner failed, cannot make copies or fax
  • Scanner failure. Unable to scan, copy, or send a fax
  • Scanner failure, cycle power
Additionally, the scanner bulb might not turn on during scanning.ry the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting.Solution one: Check the scanner lightFollow these steps to check the scanner light by making a color copy of any document.
  1. Load plain white, unused, letter size paper in the paper tray.
  2. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
  3. Make a color copy.
  4. When the product starts to scan the document to copy, slightly lift the scanner lid to see if the scanner light turns on. It is not necessary to lift the lid completely CAUTION:Do not look directly at the scanner light.The scanner light should be visible under the scanner glass to the right or left.Figure 1: Scanner light visible underneath the glass
    1 - Area where scanner light is visible2 - Scanner glass
    • If the scanner light does not turn on when the scanner mechanism moves across the scanner bed, continue to the solution to reset the product.
    • If the scanner light turns on , continue with the next solution.
    Solution two: Check the power connectionFollow these steps to troubleshoot the power connection.
    1. Press the Power button (c01602202.gif ) to turn off the product.
    2. Unplug the product power cord from any surge protector, extension cord, or power strip, and then connect the power cord directly to a wall outlet.
    3. Press the Power button (c01602202.gif ) to turn on the product.
    4. Load plain white, unused, letter size paper in the paper tray.
    5. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
    6. Try again to make a color copy.
      • If these steps resolved the issue , you do not need to continue troubleshooting.note.pngNOTE:If the product works properly when plugged directly into a wall outlet rather than a power strip or surge suppressor, the power strip or surge suppressor might not allow enough voltage for the product to work properly.
      • If the issue persists , continue with these steps.
    7. Press the Power button (c01602202.gif ) to turn off the product, disconnect the power cord from the wall outlet, and then reconnect the power cord to a different wall outlet.
    8. Press the Power button (c01602202.gif ) to turn on the product.
    9. Try again to make a color copy.
    • If the issue persists , continue to the next solution.
    Solution three: Reset the productFollow these steps to reset the product.
    1. Press the Power button (c01602202.gif ) to turn off the product.note.pngNOTE:The product might not turn off after pressing the Power button. Continue to the next step regardless.
    2. Disconnect the power cord from the rear of the product.
    3. Unplug the power cord from the electrical outlet.
    4. Wait 30 seconds.
    5. Replug the power cord into the electrical outlet.
    6. Reconnect the power cord to the rear of the product.
    7. Press the Power button (c01602202.gif ) to turn on the product.
    8. Load plain white, unused, letter size paper in the paper tray.
    9. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
    10. Try again to make a color copy.
Dec 11, 2011 | HEWLETT-PACKARD Officejet 4500 All-in-One...
My HP Photosmart C5240 will print from computer but will not scan or make copies.
Is there any error message displayed on the control panel of the printer just like one of the following:
You may want to try following these steps:
1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product.
2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer.
3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Job Espinosa
Feb 15, 2011 | HP Photosmart C5280 Printer
After printer is on for a few minutes, getting error message-scanner failure turn printer off then on again. I am able to print before the error message appears, however, unable to copy or fax. Thank...
  1. Follow these steps to check the scanner light by making a color copy of any document.
  2. Load plain white, unused, letter size paper in the paper tray.
  3. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
  4. Make a color copy.
  5. When the product starts to scan the document to copy, slightly lift the scanner lid to see if the scanner light turns on. It is not necessary to lift the lid completely.
  1. Press the Power button to turn off the product.
  3. Press the Power button to turn on the product.
  7. Press the Power button to turn off the product, disconnect the power cord from the wall outlet, and then reconnect the power cord to a different wall outlet.
  8. Press the Power button to turn on the product.
Try again to make a color copy.If these steps resolved the issue , you do not need to continue troubleshooting.If the issue persists we have to reset the printer. Doing reset in the beginning stage is not recommended. Reply me back and i will provide the reset step instruction.
Regards
Riztech
Nov 26, 2010 | HP OfficeJet D135 All-In-One InkJet...
HP 7410 All-in-One Printer A 'Scanner Failure' message is desplayed on the printer's front panel
I know i'm not going to get 4 thumbs up for providing this resolution because it seems like a hardware problem but what the heck you need some sort of help so here goes.
This error usually occurs when trying to scan or make copies. The scanner bulb is not hot enough or the electrical conditions are not suitable for the HP All-In-One product. Follow the instructions listed below to resolve this failure. The scanner lamp lighting should be viewable under the scanner glass right or left corner.
  1. c00439542.jpg 1 - Scanner lamp lighting 2 - Scanner glass If the scanner bulb does not light up, the HP All-In-One product may be defective.
  2. Make sure that the room temperature is suitable for the HP All-in-One product. Perform a Power Cycle on the unit by following the steps below:
    1. Turn the unit off.
    2. Unplug the power cord from the unit.
    3. Wait 30 seconds, and then re-connect the power cord to the unit.
    4. Turn the unit on.
    Check the power connections:
    1. Make sure that the unit is connected directly to the wall outlet and not to a power strip.Try a different wall socket.
    2. Every PC provides a standard power cord; it is possible to use it to check whether the electrical failure is prompted by the cord or not.
  3. If the Warming up or Scanner failure error messages persist, please move the unit to a different room or building to verify that the building (or room) is grounded properly.
  4. If your HP All-in-One product uses a external power module, check the power module part number against the part number listed in the User Guide to ensure the proper power module is being used. If both part numbers do not match and your product is still under warranty, please click the Contact HP link at the top of the page. If your product is out of warranty, please click the How to Buy link at the top of the page. c00458738.jpg
  5. Perform a Partial Reset by following the steps below:
    • Unplug the power cord from the HP All-in-One product.Press and hold the appropriate button combination for your HP All-in-One product. The appropriate combination for your model can be consulted in the HP All-in-One Products - Performing a Partial Reset of the All-in-One document.While still holding the buttons down, plug the power cord back in. Release the buttons after the HP All-in-One unit displays the Partial Reset message.
    Make a test copy of any document.If this copy is successful, the scanner mechanism is functioning correctly.If the error appears again, Follow the below troubleshooting
Noisy scanner This failure can occur when the HP All-in-One product is initializing.Every time the unit is turned on, the scanner carriage should move. Sometimes, when the scanner carriage returns to its home position, the carriage could crash and make a loud noise.Within a few seconds, the unit gets blocked, and the front panel display shows a Scanner failure message.Scanner noise could also be caused by the scanner sensor inside the HP All-in-One product being damaged or not properly in place.To solve this failure, follow the steps below:
  1. Perform a Power Cycle on the unit by following the steps below:
    Make a test copy of any document by pressing the Start Copy (black or color) button.
    • If this copy is successful, the scanner mechanism is functioning correctlyIf the failure remains unsolved, skip to the following step.
  2. Perform a Partial Reset on the unit by performing the following steps:
    • Unplug the power cord from the HP All-in-One unit.Press and hold the appropriate button combination for your HP All-In-One product. To know the proper combination for your model, check the HP All-in-One Products - Performing a Partial Reset of the All-in-One document.While still holding the buttons down, plug the power cord back in. Release the buttons after the HP All-In-One unit displays the Partial Reset message.
    Make a test copy of any document by pressing the Start Copy (black or color) button.If this copy is successful, the scanner mechanism is functioning correctly.
  3. Now if this still doesn't resolve the issue then it's a definite hardware problem my request would be regardless of the thumbs up,call up hp at 1800-474-6836 and ask for their upgrade machines because u'll get a machine with a 50-60% discount and an extended warranty with a 70-80% discount or u may get a warranty for the next two years for $1....Sorry if I can't help you
Oct 05, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Scanner failure
Solution one: Check the scanner light Make a color copy of any document by pressing the Start Copy Color button on the product control panel. While the product is making the copy, lift the scanner lid slightly to see if the scanner light is visible.
  • If the scanner mechanism moves across the scan bed, but the light is not lit, proceed to Solution six: Service the product .
  • If the light is lit, proceed to the next solution.
Solution two: Check operating conditions Extreme temperatures can affect the operation of the product. Make sure the operating conditions match those recommended in the User Guide provided with the product. Solution three: Check the power connections
  1. Make sure that the part number on the power supply matches the part number listed in the User Guide .
  2. Disconnect the power cord from any power strips or surge suppressors, and then plug it directly into a wall outlet.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the copy job is successful, you do not need to continue troubleshooting.
  4. If the error message displays again, temporarily move the product to a different room, or plug the power cord into a different wall outlet.
  5. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the error message displays again, proceed to the next solution.
Solution four: Perform a power cycle
  1. Turn the product off.
  2. Unplug the power cord from the product.
  3. Wait 30 seconds, and then connect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
Solution five: Reset the product Follow these steps to reset the product. Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
call in to hp at 1800-474-6836 and since this is a hardware issue directly tell the agent you would like an upgrade if you decide to get it.
It will have a 50% discount on the upgrade printer for you with hardware and software covered by a one year warranty which you can extend upto 3 years on the spot
Jun 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Scanner failure
1. Check scanner light by trying to make a copy.
Caution: do not look directly in the light
3. Perform a power cycly
* Unplug the power cord from the product while its still on
* Plug the power cord back again after 30 seconds
4. Perform a semi-full reset
* Press and hold # and 6 while plugging the power cord
* Do not release the button unless the printer would say reset
5 If you still have the problem replace your printer
Aug 12, 2008 | HP OfficeJet D135 All-In-One InkJet...
Scanner FailureTurn power off then on again Message Window pops up continuously
Below is the document that i want you to follow.
CLICK HERE ===>> DOCUMENT
Pleae let me know the result after performing the steps.
thank you so much.
adonscott
Jun 26, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP officeJet K series scanner failure power off and on again
Hi.
The "Scanner System Failure" error occurs if the scanner bulb is not heating to the correct temperature or there is some other issue with the scanner hardware
Please follow the below given instructions to resolve the issue.
Please remove the All-in-One Printer from the Power Surge Protector and plug it directly into a wall Power outlet, as the surge protector may not provide enough power to printer.
Please perform the step given below to power cycle the unit after removing the print cartridges from the printer:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the USB cable from the computer.
2. Wait 30 seconds.
3. Plug in the power only
4. Repeat steps 2-3 two more times.
5. On the third time after plugging the unit into power, reconnect the USB cable from the all-in-one to your computer.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Hope, this solution would work for you.
Regards,
Lawrence
Jan 05, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanner Failure Message keeps popping up
Here it is all over, with all the steps.
1.Unplug power cable from printer.
2.Hold Cancel and Enter. OR you could Hold Cancel and Black Copy Button. Whichever is easier
3.Then plug back in the power cable, while still holding those 2 buttons.
4.It should turn on, lights blink, then it should say FULL RESET on the little screen thingy .
5.Let go of the buttons, and hopefully, it fixed your problem.
Nov 29, 2007 | HP PSC 750 All-In-One InkJet Printer
I get message " scanner failure".
Nov 16, 2007 | HP PSC 750 All-In-One InkJet Printer
77 people viewed this question
Seeker5211
Seeker5211
