Question about Whirlpool Duet GHW9150P Front Load Washer
Washer wont agitate and then flashes F 25
Starts fine and then it wont agitate then just stops and light flashes F 25
  • 744 Answers
If you remove three screws along the bottom front the bottom panel comes off.
On the inside, on the right wall, is a plastic bag with a paper labeled "FOR SERVICE TECHNICIAN ONLY".
This has a section titled "FAILURE/ERROR DISPLAY CODES" with all the error codes along with an explanation and recommended procedure. For F25, this is:
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
I got this working for many on this site :)
thank u
rate me!!
Posted on Jul 24, 2009
Gw612 won't agitate
Fantastic that's great news you got it going.
Oct 04, 2013 | Fisher and Paykel GWL11 Top Load Washer
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
May 21, 2012 | Kenmore Washing Machines
Okay, my fisher and paykel gwl15 is almost brand new. i moved it into my new house tonight. I tried washing my laundry and it starts to fill but then stops at the light that says "wash" and wont...
Sounds like you have low water pressure or a blocked hose inlet screen. take the hoses off and check to see if there is any debris in the screen on the washer hose connection. Make sure the hoses are not kinked and the valves are turned up all the way. Also check to see if you have those special flood proof hoses with the automatic water shut offs. I have had those not work properly many times.
May 18, 2011 | Washing Machines
Will not agitate or spin. Have replaced the belt (was worn) but still wont. Fills fine. When I first put the new belt on I ran it empty (stopped it when it started agitating, moved it to sping, stopped...
Thanks for choosing FixYa and welcome. If you have a washer that has a weak agitation or no agitation at all, here are some possible solutions. You need to check your belts. Most washers have one or two belts. Check your lid switch. If a lid switch is bad, it can cause the washer to not work properly. Sometimes, they will not work at all. Make sure you check your drive motor. The drive motor controls the spinning, draining, and agitation. Most washers have the reverse motor, meaning the shaft rotates in both directions, clockwise and counterclockwise. It is possible to lose one direction and not the other. Some washers have a clutch that controls the agitation. If it is bad or worn, it may prevent the agitator to work. Most of these washers come from General Electric. You could have a bad motor coupler. They are located on the side of the motor drive inside the washer. It is also possible that you have a bad transmission. Check the agitator itself. You could have a bad spline or two. The splin accompanies the shaft and allows the movement of the agitator. If you rule out all the parts above, you may have an electrical issue or an issue with the control board. It is very important to test each part and make sure it is getting power. If a part is not working and not getting any power, the power loss may be the reason that it doesn't work. You can test the current in the wires with a voltage meter. Thank you very much for reading this tip and thank you for using Fixya. As for the spinning, you need to check the lid switch. It may be bad. It may be your motor drive since it doesn't do both. Have you had draining problems?
Feb 23, 2011 | Maytag HAV3460AWW Top Load Washer
Washer wont agitate
if it wont agitate,then it's either your motor coupling,transmission,or capacitor
Feb 11, 2010 | Kenmore Washing Machines
Washer wont agitate or stop filling on any setting
Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
Nov 18, 2009 | Kenmore 24712 Top Load Washer
Model #:WBSR3140DWW
My GE washer will not agitate or spin. Will fill up with water but wont spin. Looked at motor and it has a green light that flashes about every second constantly. I can turn the pulley both ways. Does anyone have any suggestions
Oct 18, 2008 | GE WBSR3140D Top Load Washer
Agitator stopped working
depending the age of the unit the lid switch can be bad if not that old take front panel off and the newer machines have a motor wit a control board on them with a light on it to give you error codes if it flashes one flash every few seconds the motor is fine but if the light flashes twice over and over again replace motor there is a tech sheet behind timer panel to tell ya the codes.as far as shavings the belt would be something to look in to
Dec 08, 2007 | Hotpoint VVSR1070D Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
252 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
