Question about Car Audio & Video
I have an 89 supra and im tring to hook up a jvc radio. An i can not figure out the speaker wires for the car. I know the ones on the radio.
    Problem Solver:
  • 4 Answers
I use a AA battery. Take a short piece of speaker wire, cut two pieces about 3 inches long, strip it on both ends. Use black electrical tape and tape one wire on each end of the battery. On the end not taped to the battery twist the wires so they don't fray out. Now when you pull out your factory deck you can use the battery across the two wires for each speaker lead, it will make a crackle sound letting you know which speaker you are on.
Posted on Jul 24, 2009
Radio pro 4 wiring
You should purchase a radio harness for your car, and it's wires will connect to wires of the same color from your JVC radio harness. Join the two harnesses together (solder, crimp caps, barrel connectors, etc.) and then one end plugs into your JVC, the other end plugs into the factory harness that the original radio was connected to. If for some reason, your factory harness plug has been cut, you'll have to hardwire the JVC harness. I've included a link to the wiring diagram for your car. The steering wheel controls are moot; they will not work unless you've got some aftermarket adapter that allows them to interface with the JVC radio.
2004 pontiac grand prix speaker wiring diagram Google Search
Nov 13, 2017 | Car Audio & Video
I have a jvc kdavx1 trying to hook up to a 2000 buick reagal need to know how the wires hook up
Please let me know if you have questions, and thanks for using FixYa.
2000 Buick Regal Car Stereo Install Diagram jvc kdavx1
Radio Constant 12V+ Wire: Orange yellow
Radio Ignition Switched 12V+ Wire: Yellow red
Radio Ground Wire: Black/White black
Radio Illumination Wire: Gray/Black orange/white
Left Front Speaker Wire (+): Tan white
Left Front Speaker Wire (-): Gray white/black
Right Front Speaker Wire (+): Light Green gray
Right Front Speaker Wire (-): Dark Green gray/black
Left Rear Speaker Wire (+): Brown green
Left Rear Speaker Wire (-): Yellow green/black
Right Rear Speaker Wire (+): Dark Blue purple
Right Rear Speaker Wire (-): Light Blue purple/black
parking brake: blue light green
For this last wire, access the back of the parking brake to find a switch with a blue wire. Peel some insulation from the wire and wrap the stripped end of a 3 foot piece of 16 or 18 gauge wire around the stripped section. Solder and wrap the connection with electrical tape, route the wire to the jvc, then strip and solder the other end to the pigtail of the head unit.
If you are also installing a camera seeing behind you when backing, you will need to run a wire to the back-up light on the driver side reverse light (light green) wire along with your video cable.
May 30, 2011 | JVC Car Audio & Video
Im trying to install an after market radio(pioneer) in my 83 impala. i know i hooked up speakers correctly. But i have a yellow black and grey wire on car wires and yellow black and red on harness. I know...
Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Here you go. This is listed for an 85 to 89 Impala, but should still hold true.
May 30, 2011 | Pioneer Car Audio & Video
Im installing a JVC KD - A315 radio in a 2003 alero, when i took out old radio all the wires were cut and turned into speaker wire running all over the place the factory amp is in the back i went ahead...
There may be extra wires you don't need. The basic set of wires on the radio is 4 pairs of colored wires--one black-striped and one plain for each speaker. Yellow is usually accessory power, red is hot, and black is ground. Some additional wires may be one for a power antenna, one for an external amplifyer, and one for facelight (in case it will run on dimmer)
The car should have the following corresponding wires:
Radio 12v--- orange
Radio Ground--- black
Radio Ignition--- yellow
Radio Illumination--- brown
Dimmer--- gray
Power Antenna--- pink (if you have one)
LF Speaker +/- tan - grey
RF Speaker +/- lt green - dk green
LR Speaker +/- brown - yellow
RR Speaker +/- dk. blue- lt. blue
The car or radio could have additional connectors, such as for a subwoofer, CD changer, etc.
Aug 28, 2010 | 2003 Oldsmobile Alero
I have a 1985 supra and the headlights wont go up and down, and I also need a wiring diagram for my audio deck since the last guy who put one in didn't use an adapter
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: 4′
Car Audio Rear Speakers Location: Side Shelves
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
pls rate
Nov 18, 2009 | 1985 Toyota Celica Supra
Jvc KD-G210
Did you know there is a fuse on the back of the radio and one on the amp? Have you checked them? If the radio is working and no ssound it could be the radio, speakers or wiring. In your case it sounds like either the radio or speakers.
Sep 22, 2009 | Car Audio & Video
Jvc deck same problem, powers on and functions but no sound
the car is equiped with an amplifier. there is a black wire that you didn't connect. just connect it to the blue with white wire from your radio and it should work.
Sep 06, 2009 | JVC AM FM CD DET FACE CAR STEREO
Diffrent colour wires from my saxo car to my jvc new radio.
sorry no but try to find the power wire and then turn it on then try to listen for sound to out of the speakers well that's what i had to do i did it in a half hour im sure you'll figure im only 15 and i did
Aug 27, 2009 | JVC AM FM CD DET FACE CAR STEREO
89 toyota supra radio
fit new speakers ,cones have perished
Jul 15, 2008 | 1989 Toyota Supra
Car Audio & Video Logo
37 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
