Question about Motorola Mobility RAZR V3
Razor phone external display
My phone is working fine other than the external display never changes. It is stuck with the M logo on the outside. It never shows caller ID or the time on it. Even when I change the option to "open to answer call", It still never has caller ID on the outside, and I still have to push a button to answer a call. How do I fix the external display. The internal display is fine.
Re: Razor phone external display
My phone is a razor and it turns on but the screen doesnt appear. Also the battery dies fast
Posted on Sep 14, 2008
I had the same problem. I sent it back to Motorola for warranty. They fixed it and said it was a connection issue.The connection between the screen and the keys came unplugged. This is a regular problem they have with this phone. The phone is poor quality!!!!
Posted on Nov 22, 2007
0 characters
3 Points
Hello on moto razor v3i 's external sreen only moto logo is displayed , need help, it doesn't show ordinary information.
pull the battery, let it sit for a few minutes, then replace it and power it back on. If that doesn't work its likely a physical defect with the phone and not a software glitch. these can be easily replaced online for under $20 if you look :0)
Mar 03, 2011 | Motorola Mobility RAZR V3
Want to change external display
Yes I do... first question is your phone under warranty.. because if it is you void the warranty do this..
second.. do you have a USB cable? and software? You will need something like P2K Commander... set it up with MSU and you want to go to the a:/ mobile folder you will see the verizon.gif file in there DO NOT DELET that file.. you are going to replace it.. Find a file that you want to you make sure the size is 96x80.. Change its name to verizon.gif and replace it in that directory.Restart the phone and VOILA! I have an evil Smiley on my outside LCD!
Mar 24, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Razor V3 Lime Green
this is a very simple problem to fix just take it to a mobile service center and have them correct the issue for you.
Mar 06, 2008 | Motorola Mobility RAZR V3
Outside display screen will not show anything but the motorolla logo
Does anything show on the external display if you go to take a picture, but before you acually take it, close the phone and look on the external display as if you were taking a self-portrait?
To make fully sure, while the phone is closed, press a volume button - does anything show on the display? If so, the external display functions and it would be a setting that may have been overlooked.
Go to Menu > Settings > Initial Setup > Display Timeout
Menu > Settings > Personalise > Home Screen
Nov 01, 2007 | Motorola Mobility RAZR V3
Display on Rzar
Check AT&T if the colud provide either changeable operator logo on your phone.
Aug 07, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Logo stays on outside display window of cell phone
I'm having the same trouble, and I've found it's because the v3 no longer recognizes the opening and closing of the phone itself. You see, when you close it, something is triggered that tells the phone to shut off the main screen and change the outer screen to the usual mode where it shows the time. You can also test this by trying to take a picture and closing the phone - the external lcd no longer doubles as a second camera display to easily take pictures of yourself. I dropped mine into the toilet, and I'm not sure if there's anything to do but take it to a tech. Sounds and looks like a hardware problem to me.
Jun 28, 2007 | Motorola Mobility RAZR V3
Screen out side
I hope this anser helps you: First, Press the center select key to open the menu, then scroll to SETTINGS & TOOLS and then go to Display Settings, and press the center select key to select it, nou you should go to "Clock Format" and press the menu key. Scroll to Front Clock (for the external display) and press the center select key THAT IS!
May 24, 2007 | Motorola Mobility RAZR V3
Cannot filp open phone
Please check the moving sections. and the screen problem due to its display strips
Mar 13, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
184 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
