SOURCE: Folding up Cosco play yard
you also need to hold one of the middle indicator tabs on the longer side..because if you don't do that it will not shut... and make sure the 2 legs go inside with the center of the play pen
My wife and I have the same model for visits by our granddaughter. She was having the same trouble as were you and, like you, we did not have instructions.
I'm happy to share with you what I found to close the model up for storage. It may not be the same as what the manufacturer envisioned but it worked for us.
-- With the pad removed from the inside of the Pack n Play, pull up on the red handle so as to loosen the legs;
-- Next, you will find there is a big button in the middle of each of the long sides of the Pack n Play. Start with either long side. You will have to press very hard on either side of that button; I found it helpful to use both hands, one pressing on the outside of the playpen, the other hand pressing on the inside of the playpen. Pressing these together will loosen the long support arm at the open top of the Pack n Play.
-- Do the same for the opposite long side.
-- You will also do the same, one button, one side at a time, for each of the two short sides of the Pack n Play.
-- Now pull up on the red handle in the middle, and guide the four corners so they meet and close.
-- Cover.
I found the buttons may not have fully allowed the support arms to collapse, thus blocking the Pack n Play from folding down completely. If so, try pressing the button again (both the outside and the inside at the same time).
Hope this helps!
SOURCE: i have a rainforest swing and everything on it
You can order the broken part and replace it. Call Fisher-price customer service and they will help you with that.
SOURCE: Graco swing not working, I'm trying to open the motor box.
You need to remove the center of the part the connects to the chair. Use a thin screwdriver to pry it out a little, slide the screwdriver into the center and then pry each of the two tabs outward from the center. As you unhook it, you will be able to pry it out and then the attachment mechanism will pull off.
SOURCE: I have the Eddie Bauer
take apart the side with the on and off switches take apart the swing arm, remove the plastic cover over the motor look at the
blue wire from motor thru the plastic all the way to the contrl board prob broken where it goes thru plastic from motor looks like it happens alot
