Question about Garden
Need to remove clutch from TB425CS trimmer to access ignition coil.
  • 130 Answers
Get a peaice of brass and a hammer hit the clutch where the spring is on clutch. knock to the left to get off couple of strike it should come lose.let me know if this help you.ok
Posted on Jul 25, 2009
Homelite hlt25cs, pull starter cord, wont engage starter clutch, cant find how to access it
hello sir, ryobi trimmers and other models removal of the bell housing,removal of the metal bell housing,or clutch drum, on models 780R & 790R, here is what you do. after removing the trimmer & shaft assembly.remove the spark plug insert a screwdriver in the cylinder to keep piston from moveing. to remove the bell housing twist off the spring and using a T20 TORX screwdriver unscrew the retaining screw in the center of the bell housing (normal r/h thread) . push down firmely try not to strip screw head . you should be able to remove clutch housing.remove clutch using a pair of channel locks,works for me, (normal r/h thread) you should be able to remove front engine cover to repair what you need to.coil,pull stsrt, hope this works,. this solution applies to all trimmers with clutch removal~~~hope this helps,,any comments welcome,thank you. ``
Feb 02, 2012 | Homelite Garden
How do you remove clutch hub from unit to get to
If the clutch hub on this model is like the clutch hub on the two strokes, there is a screw that stays in the unit . I think it is a Torx screw like T-10 or T-15 size. To keep engine from turning while doing this, remove spark plug, pull start cord till piston goes down at bottom of cylinder and stick some loose, soft rope in the engine...when you turn the screw (it's in there) the piston will move up compressing the rope and stop the engine from turning while you loosen the screw.
Jun 02, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
My kill switch on my troy bilt TB425CS doesn't stop the motor anymore. What can I do to fix it?
its just a switch that grounds out the coil remove the switch and replace it with any that connects two wires to currentso when on the two wires are connected that should fix it if not follow the wires to where they end and check the connections.
Mar 09, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Flywheel removal from TB425CS
YOU MAY HAVE TO USE A PULLER FOR THE FLYWHEEL I CAN'T SEE ANYTHING ON THE BREAKDOWN OF THE ENGINE THAT WOULD SHOW ANY THREADED HOLES FOR BOLTS TO REMOVE THE FLYWHEEL
Sep 17, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Troy-Bilt TB425CS trimmer hard to start, won't accelerate
Hi the key is moulded as part of the flywheel on most machines these days which doesent take much to sheer off , By the sounds of it this may well be your problem.
Sep 08, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
I have a TB425cs that won't accelerate. It will
try adjusting the mixture screws out a bit if any otherwise it will need a diaphram kit
Jul 16, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
The clutch is not engaging
I threw it away, now I am looking for another one.
Jun 29, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Troy-Bilt Trimmer TB425CS
Sound like the clutch is going out or already is bad. There should be a cone shape cover that attaches the engine to the handle. Usually with 4 screws. Take those screws out and seperate the housing. There is a small centrifugal clutch, which is probably bad.
Jan 20, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Garden Logo
173 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
