Question about Bernina Sewing Machines
I keep getting a message saying the machine has
I have a Bernina 200. I have been digitizing applique. When I try to embroidery it I keep getting a message saying 'the machine has limited capacity. Your machine has nearly reached its limit. Please save data need at this time. Switch the machine off. Switch the machine on to continue'. I get the same message everytime. I am using my USB stick and have nothing in memory that I can find. I can open other designs on my stick but not this one. I have reworked and saved it a numbe of time and it still will not open. Help
Claudia
dupina
  • 110 Answers
SOURCE: embroidery stick
You need the USB Manager software to view the files. Have a look at all the software that were supplied with the machine. Load the embroidery software on your laptop and then open the USB manager.
When it opens it will show a light blue screen and grey icons to the left. Click in "disk", then click on "read disk" and you should be able to see your designs. The grey icons will turn orange were designs are stored, and the grey ones indicate empty space for more designs.
Enjoy your fantastic machine
Posted on Dec 18, 2007
SOURCE: Bernina 440 QEE embroidery
I'm not an expert, but maybe your bobbin is wound incorrectly, or not put in the bobbin case properly?  Hope it is something as simple as this.  Good luck!
Posted on Dec 25, 2007
  • 185 Answers
SOURCE: 180E Hoop problem
Joan, there are 3 micrositches on your embroidery unit arm. these switches are depressed when you attach the hoops, it appears from your comments that one switch is not functioning. This could be simple, it is out of alignment or more complex it is broken. Either way you need to take it to a professional for repair.
Posted on Feb 25, 2008
  • 9 Answers
SOURCE: Bernina Deco 650 - whistles when I put in the embroidery card
Try a diffrent card?
Posted on Nov 18, 2008
SOURCE: viking designer se limited
You can find this information by touching the configuration icon (this looks like pliers). The item that shows you how many sewing hours is called Timer. You should know that this can be reset to 0 by anyone.
Posted on Dec 29, 2008
Bernina artista
It could be a sensor.
You can contact Bernina Support here:
https://berninaofamerica.zendesk.com/hc/en-us
or call your local Bernina Dealer.
Jul 24, 2016 | Bernina Sewing Machines
Need Bernina Artista 200 manual ASAP
You can download a manual from the Bernina web site.
BERNINA Support Machine and Accessories Finders and Software Support...
Then go to "Search Support Info for Bernina Models"
BERNINA artista 200 Support BERNINA
Jul 13, 2016 | Bernina Sewing Machines
After cleaning the bobbin sensor, error message keeps coming on. What else should I do?
You should probably take it to a Bernina repair person.
https://www.youtube.com/watch?v=RHYwvv8lJ74
http://sewsabina.com/blog/?p=84
http://freemo.com/bernina-artista-730e/
Jun 23, 2016 | Bernina Artista 640E Sewing, Quilting and...
I have a Bernina 145 S activa and I can't get my satin stitch to work , it brings the bobbin thread to the top , what can I do ?
Do you use stabilizer when you are satin stitching? I had a teacher who also hooped the fabric with a spring-loaded embroidery hoop (turned upside-down under the presser foot so the fabric is flat against the needle plate) that would keep the fabric taut.
It is not uncommon for bobbin thread to rise to the top when doing embroidery, satin stitch, etc., especially if you are using lighter-weight thread than usual. You would normally loosen the upper tension so the upper thread will sink into the fabric. However, if loosened upper tension is not doing enough, you may need to adjust bobbin tension when doing embroidery, applique... You might try tightening the bobbin tension just a smidgen to get the bobbin thread to stay below the fabric. Be sure to mark the bobbin case before making any adjustments so you can return it to the original setting when finished with the satin stitch. (If you do a lot of satin stitch or applique, etc., you may want to invest in a separate bobbin case that is set up only for doing that kind of work--saves having to alter the bobbin tension frequently.)
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwiRr76k0sbLAhXBKGMKHei6AfIQFggqMAI&url=http%3A%2F%2Fmachinequilting.mqumag.com%2Fwp-content%2Fuploads%2F2014%2F12%2FSatin-Stitch-Techniques-Part-1.pdf&usg=AFQjCNFXYKp2C-RJEAAUMWwApqZlU895uQ&cad=rja
Mar 16, 2016 | Bernina Sewing Machines
How can I use my Bernina 640 Artista to applique
Perhaps I'm not understanding your question. When doing applique, I use a very tight zigzag stitch with a satin stitch foot or open-toe embroidery foot (so the thickness of the stitches do not create buildup under the presser foot). Set the tension so the bobbin thread stays mostly under the fabric so the top thread is the only thread that shows on the top (sometimes threading the bobbin pigtail will help).
Fuse the cutout fabric to the backing fabric. Then zigzag so the raw edge of the fabric is covered by the zigzag (helps to use a thicker thread so the coverage is easier).
Some newer machines have the ability to miter corners. On my 930, I set the needle position to the outside of the raw edged. Then when I near the corner, I gently, but consistently, narrow the stitch width to an an outside point, since the needle on the outside edge, turn the fabric and gently, but consistently, widen the stitch to full width. This creates a nice mitered corner.
When making curves, stitch small lengths and then sink the needle on the outside of the curve, and gently turn the fabric to follow the curve and repeat while going around the curve.
https://books.google.com/books?id=MQneD8cQ5KAC&pg=PA13&lpg=PA13&dq=mitered+applique+corner&source=bl&ots=1sHsUrkVAz&sig=1WZ-i2-T3RtvUEW797sHxTKiq4E&hl=en&sa=X&ved=0ahUKEwiaoZeiwunKAhVslYMKHewdDFEQ6AEIKzAC#v=onepage&q=mitered%20applique%20corner&f=false
How to Appliqu Like Pro Sew4Home (FWIW, IMHO, the satin stitch on the bird is really a poor example. The stitch is not very even at all--could be the sewing machine.)
How to Make and Apply Appliques (The giraffe is a better example, although choosing a simple design to applique usually yields better results.)
Practice, practice, practice!
Feb 08, 2016 | Bernina Artista 640E Sewing, Quilting and...
Can this to freehand machine embroidery?
If you can drop the feed dogs (or have a plate to cover the feed dogs), the machine has a zig-zag stitch, and you have a darning foot or free motion foot, you can do free motion quilting, hand manipulated embroidery (monograms), and applique on a basic sewing machine. It will take some testing and quite a bit of practice. You can also use an embroidery foot to monogram and applique. You will want to sink the needle into the fabric at every corner and frequently when creating curves so you can move the fabric.
Search the internet for instructions & tutorials on how to set up your machine and the best way to accomplish what you want.
How to Monogram with Basic Sewing Machine
How to Use Monogramming Foot
Machine Applique Tutorial
Machine Applique Sewing
Jan 12, 2016 | Sewing Machines
With embroidery card inserted into module, no motifs appear on the display screen.
Here are two other possibilities other than electrical problems with your Bernina. There are embroidery design cards that were made for the 200 & 730 that simply do not work in a 180. There is nothing marked on the card or the packaging that will tell you what model machine the card will work in. I sold a bunch of my design cards on eBay last winter and I tested all of them in both a 730 and a 180 before making the ad discription. I found that most of the design cards worked in the 180 & 730, but there were a few that only worked in the 730. So if your design card is one of those that won't work in a 180, that could be your problem.
You did not say if you have other design cards that do work or there is only one you tried. Possibly the card itself is bad.
A static shock to the card could possibly damage it.
So if you take your machine to a dealer to have it looked at, take your design card along.
The 180's memory for storing designs is located in the embroidery module, not the machine itself. If that memory is filled up with other designs this can cause a problem.
So your problem is most likely with the design card or with the embroidery module. Should you need to get another embroidery module, that module needs to be the same version number as your machine or it will not work. I have a. video posted on YouTube that shows you how to check the version number of your machine and module. That information is in my "Bernina check hours 165, 170, 180, 185" video. Put that in the YouTube search box and you will find my video. Plus I have other helpful Bernina videos posted.
Aug 14, 2014 | Bernina Artista 180
What can I do to widen my satin stitch when it is to narrow for the applique
Unless you have and know how to use digitizing software, will you be able to add width to the satin stitches when doing applique. You need to cut the applique fabric larger than the cut-out-line so the applique fabric will held down properly. Some Commercial or higher end home embroidery machines can re-interpret the embroidery design and widen the satin stitches in a design without software. 6f3dbcfe-19c3-4021-b143-de10c9a89868.jpg
Jul 14, 2014 | Brother PE770 Computerized Sewing Machine
Embroidery
If you doing an embroidery, it has to have something to do with the way the design was digitized. We have a BERNINA ARTISTA 180 and have never come across this problem. The embroidery machine only reads what is on the disk. Try putting your design through the computer.
Sep 07, 2006 | Bernina Artista 180
Sewing Machines Logo
48 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
