Question about Lands Phones
Phone rings but when pick up get busy signal only
The console mitel super console 1000 is giving busy signal only
we do get the busy ring but when pick up the receiver get busy
signal only. Appreciate you suggestion for fixing the problem
    President:
  • 1,734 Answers
In my understanding there exist several possible reasons:
1) While you are monitoring, you can’t make or receive calls. Anyone who
calls your telephone while you are monitoring receives busy tone. The
caller can leave a callback, but is unable to camp on or override your
monitoring session. If you want to place an outgoing call, you must first
cancel your monitoring session.
2) A user can only be monitored from one console or extension at a time.
If you try to monitor someone who is already being monitored, you
receive busy tone and BUSY appears in your display.
3) You hear a special busy tone when the extension you called has Do Not
Disturb activated.
The Override feature allows you to intrude into a busy extension or an
extension with Do Not Disturb (DND) active.
To use Override:
1. Press and hold [OVERRIDE].
If you are overriding a busy extension, both parties hear a long beep,
and then you enter the conversation. You will remain connected to the
conversation until you release the [OVERRIDE] softkey.
If you are overriding an extension with DND active, you will hear
ringing.
2. Press Cancel or Release to disconnect the console from the busy
extension.
If the busy extension hangs up while you are pressing [OVERRIDE], you will
hear fast busy tone and the display will show “Hung Up” instead of “Busy.”
Posted on Jul 24, 2009
Mitel SX-50 phone console keeps ringing for no reason.
first make sure it is not a line problem by disconnecting the phone line when you get the rings, then make sure it is getting proper power to the unit. if it does not have electric plug look for batt in unit and replace. If unit is dirty, gummed up try blowing out with air, before giving up on the unit. good luck
Jun 02, 2014 | Mitel SX-50 Console White Phone...
We are unable to turn a ringer on, for when the general number rings, on one Mitel 5020 IP Phone, and we would like to make it so another phone doesn't have to hear the ring on the general number ring.
This is set on the buttons for the phone from within the system programming. Individual buttons can be set to NO Ring, Ring, Ring Continuous, Delay Ring, or Delay Ring Continuous.
Continuous meaning that even if you are on the phone, it will ring audibly on your phone. If it's not set to continuous, it will only give a blip.
You should contact your vendor for assistance in setting this up.
Aug 03, 2010 | Mitel 5220 IP Phone
I can't pick up a phone call
Call Pickup doesn't ring your phone or light up. Your 5212 phone isn't considered a "display phone" Meaning that the display doesn't have softkeys. These are the 3 keys directly below the display and their function changes as you are using the phone.
Your phone's Pickup Key should be used if you want to pick up a call that is ringing on a nearby telephone... usually only the phones within earshot of your phone.
You must pick up the handset, then either press the call pickup key or dial the call pickup feature code.... this code can be different for every system as it's custom from the install vendor.
I hope this helps.
Mark
May 24, 2010 | Mitel 5212 IP Phone
How do I pick up another phone that is ringing in my office
You will have to get the Mitel Programmer to program a button that can do that for you. Mitel systems are amazing, but unfortunately most things have to be programmed to do what you want.
Jun 09, 2009 | Mitel 5220 IP Phone
Too many rings on 4025 Superset
You will need the Mitel system programmer to change the Class Of Service of your set, this will change the number of rings before it goes to Voicemail.
Unfortunately, unless you know how to get into the system or have an administrator onsite that has rights to the Mitel system, a Mitel Specialist will be required to make this change.
Dec 16, 2008 | Mitel Superset 4025 Corded Phone...
Need to have a Mitel SX 50 Phone System ring on cordless phones
You can switch to "night" mode on the console and the incoming calls should ring on the cordless. try it.
Nov 11, 2008 | Uniden 5.8GHz Cordless Phone
Caller ID on Mitel Superset 4025
Try pressing the superkey button and then the button that is ringing
Sep 12, 2008 | Mitel Superset 4025 Corded Phone...
I have a 4025 Not Forwarding to VM?
The Call Forward is set up by using the BLUE Super KEY located below the display. You have to know the Voicemail Pilot Number to be able to complete the programming. Basically you press " superkey ", say NO to the prompts until Call Forwarding comes up, say YES to Call Fordward, choise the type of forward you want ( always, no answer, busy, busy/no answer )dial in the voicemail pilot number, press save and then press the superkey to exit programming. Good Luck
Aug 01, 2008 | Mitel Superset 4025 Corded Phone...
How do you answer another phone in the office by using your own phone
Ascertain from your system administrator the directed call pickup feature access code, this will allow you to pickup any ringing call as long as you know what ext number is ringing.
Jul 11, 2008 | Mitel 5220 IP Phone
Mitel 5220 IP phone won't ring when the main line is ringing
WOW
Ok this post is OLD, but for anyone else having this issue, this is the solution...
There is a programming feature that states: DELAYED RING on certain lines, meaning you can physically see a call coming in to the system (via line flashing), but it will not ring at your desk till something like the 4th ring(hence the name DELAYED ring).
If your set does not ring, and you pick up the heandset, the phone system doesn't know if you want to answer the call -or- you just want to make an outgoing call...
Therefore the Mitel system picks up internal dialtone and waits for you to make the initial reaction (hit 9 for a line out or hit a line that is flashing on the set).
Too change this option, a Mitel Tech is required...
Jan 23, 2007 | Mitel 5220 IP Phone
Lands Phones Logo
239 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
