Question about RCA D52W23 52" HDTV CRT TV
Board shorting out
Looking from the backside of the TV, the bottom nearest left board is sparking up like a high school kid in alley. It is near the center by a relay circuit that measures 3/8 wide x 1" long x 1/2" high. I was wondering what the board was called and the cost. I assume I will not be able to switch out the connector.
    President:
  • RCA Master
  • 1,779 Answers
Best to hard wire it because the board is not availabe. I have fixed a ton of those for that.
That is your Deflection board.
Posted on Jul 24, 2009
I get no picture from my rca 52 inch tv
Have you taken the back off to see what is visible to you ? it could be a high voltage transformer or bad connections on the bottom of the SMPS deflection board being the board on the left looking in to the back of set. or a you should be able to see something burnt or a smell of the area some times helps to locate what you don't notice .
but most likely the problem in on that circuit board .
Mar 04, 2015 | RCA D52W20 52" Rear Projection HDTV-Ready...
Whats wrong with my tv when i turn it on and that little blue light that turns on but the screen stays black and i cant hear or see anything
Fault with main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 14, 2014 | Element Electronics Televison & Video
My Panasonic Plasma 42 in will not give a picture now bottom left red light flashes 6 7 times someone has told me that its a resitor that needs replaced but where they said it was i cant find even with the...
USALLY FLASH 7 IS SC BOARD ON SC BOARD THERE ARE MANY MOSSFETTE TRANSISTERS THAT ARE SHORT CHECK TO SEE IF YOU HAVE SHORT TRANSISTER IS YES REPLACE SC BOARD 150 DOLLARS DONT FORGET TO MAKE FIRMWARE UPDATE OR PROBLEME WILL COME BACK !!!!!!!tombou300619_5.jpgtombou300619_6.jpgFIST PICTURE TRANS SECOND C BOARD
Jan 14, 2011 | Panasonic TH-42PZ77U TV
Got a Hitachi rear projection model # 50ux58b. Kids been playing the Wii and all of a sudden no power. Course nobody knows nothing. You know the story. Anyway Fuse and cap probably need replaced. Any idea...
the three guns that the lenses drive operate at 28kv.
there are very high and dangerous voltages in a tv set.
you can look for the fuse main pc board by the power cord..if it is black,there is a major short.if it is just barely blown,change it.
the fuses are 3ag glass type and just pop in. use a set of rubber gloves and insulated pliers.. tvs are DANGEROUS
Jul 04, 2009 | Hitachi 50UX58B 50" Rear Projection...
57xbr10w pops & sparks under one of the lamps & shuts off
The Lamp (CRT) got shorted / leaky that gets spark / arcing and requires replacement. TV is an old model and I'm not sure that CRT is available any more.
May 31, 2009 | Sony KP-57XBR10 57" Rear Projection...
KP-46WT510 Sony, locating boards?
I have the same model tv, with the same problem... convergence ICs were shot.  As you look into the back of the tv, the ICs are located on the backside of the large heat sinks on the tan board.  The pico fuses are directly under the heat sinks.
Removing the board is fairly easy with the exception of removing the red cables at the rear left side of the board.  You have to exert a lot of force to pull them out (they go into the grey tower looking thing) but they do come out.
I recommend taking pictures of the board before removing, and then make sure you label each connector you pull off the board.  There are six screws to remove as well.
Check with Sonny and Barry at this site.  They gave excellent directions and have a convergence repair kit for your model tv. http://servicemanuals.vstore.ca/index.php/cName/convergence-repair-kits
Dec 25, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony Trinitron Vega KV-34HS420
it's better if you bring you're tv to sony service center and ask to an authorized repairman
May 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Red screen and only red bulb powers on.
The red tube and the red crt board sound like the problem. these would be the first thing that needs to replace 250 for tube +50 for crt board. + labor about 300 to 500 to repair
Jan 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w20b
Unless your a tech ....it would not be wise... the crt board as it called has very high voltages... which board was it red green or blue .. right center or left... usally when one of these boards are bad that indicates a possible problem with the actually crt.. very diffcult repair.. be carefull please
Nov 22, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W23 52" HDTV CRT TV Logo
85 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
