Question about Panasonic Air Purifiers
Can we buy and how much for the filter material
Can we buy and how much for the smaller component filter material from a CZ-SF5N air purifying filter used in a panasonic reverse cycle wall mounted panasonic air conditioner. The material we are chasing measures 27cm x 5cm x 4 mm and it sits inside plastic green frame of similar size. Please respond to our e-mail
Thanks.
Best regards,
Chris Jones
SOURCE: Filter Queen Air Purifier
you can call 1.866.660.0612 Fm Air Inc a Filter Queen distributor will be happy to assist you.
Posted on Apr 17, 2008
SOURCE: kenmore air purifier- model 85500
Power Off the unit then Press and HOLD the Off-Timer and Function buttons at the same time WHILE Powering the unit back On. The Replace Filter light will blink for 5 seconds than go out. Now you can release the the buttons.
Just to make sure everything is working fine power off and on the unit.
On a side note if you are a tight wad like me you may want to just smak the filter layers against the ground a few times to clean them and re-use them / make them last longer. When the replace fileter light comes on too often then it is time to replace the filter.
No worries ;o)
CDA
Posted on Nov 16, 2008
Dutch7773
  • 31 Answers
SOURCE: Ecoquest Flair Air Purifier leaves black residue on walls and...
The black residue is what is in your air. The reason for it to cling to the walls is the Ionization process that the machine creates. The ionization is to create a clean breathing space, free from contaminants. All particles floating in the air will be negatively charged and cling to each other or to objects in the room (like walls) that are positively charged.
If you cook, there is some smoke created, or when you burn candles. These greasy particles will stick to the wall or to surfaces. Cleaning them up regularly might help. You can also try another product from EcoQuest called EcoH which is based on enzymes and cut through that grime easily. That might take the black stuff off the walls.
Dutch
Posted on Mar 05, 2009
  • 8 Answers
SOURCE: My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Posted on Dec 25, 2009
  • 19 Answers
SOURCE: green purifier light no longer comes on
the plates are damage you need to replace it and be careful wen it`s to much humidity because that can damage the plates,and the ligth its the uv ligth you can get parts at ecoquest
Posted on Apr 03, 2010
Wall unit keeps frosting up, will not heat
Clogged air filter or a loose belt between the fan motor and fan wheel will cause a frost up.
Nov 19, 2015 | Mitsubishi MSZ-GE15NA Mr. Slim Wall...
There is a bad smell coming from the indoor unit of my Mitsubishi Mr Slim split-type a.c.
Mitsubishi MSZ-GE06NA Mr.... Repair Questions - Fixya
www.fixya.com/.../p3677512-mitsubishi_msz_ge06na_mr_slim_wall_m...
Recent Mitsubishi MSZ-GE06NA Mr. Slim Wall Mounted Indoor Unit Air Handlerquestions, problems & answers. Free expert DIY tips, support, troubleshooting ..
Jul 26, 2015 | Mitsubishi MSZ-GE06NA Mr. Slim Wall...
Why HEPA certified Filters are more preferred?
The HEPA certified air purifier by far has been the best type useable since it is very efficient. The most advantageous aspect of this type of air purifier is that does not emit any by-product or secondary pollutants like ozone that is so very harmful. Buy certified HEPA filter air purifier to maintain the freshness of the room.
Oct 01, 2014 | Air Purifiers
I have been looking to buy an air purifier and people keep telling me to get a HEPA. What does this mean?
HEPA is a type of air purifier. It stands for high-efficiency particulate air. To qualify as a HEPA filter by government standards the filter must remove 99.7% of all particles larger than 0.3 micrometers from the air. The following site lists the top 10 HEPA purifiers available online - http://www.air-purifiers-america.com/AP101_top10.asp.
Jul 12, 2012 | 3M "Replacement Filter, 11 7/8 x 18 3/4"
Just received a new air purifier, and was quite surprised to see big pieces of styrofoam in the fan/air output area.....at first we thought it must be packing materials. My question is: I thought that...
That is packing materials. It was placed there to protect the vent louvers on the front from breaking during shipping. Apparently, some of them chipped or broke and found their way into the louver section. Simply clean them out. Small pieces can be sucked out with a vacuum that has a hose and crevice tool attachment.
Mar 07, 2011 | Hunter (30067) Air Purifier
How do I clean the Oreck Air 7
Hi There,
Here's how you can clean the machine, and I have copied the link to the owners manual below for your convenience.
Cleaning
The Cabinet
You can clean the air purifier cabinet with mild, non-abrasive cleanser and a
soft cloth. IMPORTANT: Unplug the unit from its electrical power source.
Do not spray cleansers or furniture polish into the louver or grill areas.
Collector Cell
Indicator light is green under normal operation and flashes red
when the cell requires cleaning. To clean, proceed as follows:
The red "WASH CELL" light will flash or illuminate when it is
time to clean your cell. However, it is recommended that every four to
eight weeks or if snapping sounds become frequent, clean your
electronic air purifier. Your electronic air purifier is still filtering the air
when the red light illuminates. Cleaning your electronic air purifier is a
snap too... and a must for efficient operation.
1. Turn the unit off and unplug it from the electric power source. If wall
mounted, remove unit from wall.
2. Remove front grill by unscrewing the retainer screw under the grill on
the cabinet bottom. (fig. 1)
3. Pull the cell out of the cabinet by using the two small handles on the
front of the cell. (fig. 2)
4. Snap off the charcoal odor absorber from the back of the cell. Change
as necessary for continued odor removal. (fig. 3)
5. Slide off pre-filter. This can be cleaned with the cell and reused. (fig. 4)
NOTE: Handle the electronic cell with care. Damaged metal plates
and/or broken wires will cause the air purifier to malfunction. (Do
not wash charcoal odor absorber; it is disposable.)
Cleaning with Assail-A-Cell® Cell Cleaner:
6. Using Assail-A-Cell® Cleaner, thoroughly saturate the cell and prefilter.
Be sure to spray between each cell plate and cover every
surface. Allow product to soak for a few minutes, not allowing it to dry.
Rinse thoroughly with water. For extremely heavy deposits, repeat the
process.
IMPORTANT: Dry the collection cell thoroughly outside of the
air purifier before reinstalling it into the air purifier. Ensure
that all areas including corners and areas that may trap
water are dry before reinstalling into the air purifier. DO NOT
process.
place a wet or damp collection cell in the air purifier.
Here's the link to the owners manual for your Oreck Air 7:
http://www.oreck.com/includes/customer-service/owners-guides/pdfs/3323-3018-AIR7-Rev-H.pdf
I hope this was helpful to you. If this helped, please be kind and rate the repair, or leave feedback for me. Thank you,
Chris Jones
GoVacuum.com
May 01, 2010 | Oreck Super Air 7 Air Purifier
No problem but can't find replacement filters for my Family Care air purifier/ionizer Model HAP221
Hi just a tip for you, if you can't find a filter you can buy filter media at your hardware store such as Home Depot, and have it cut to fit. It is good material made to replace any type filters. Sincerely,
Shastalaker7
Dec 04, 2009 | Family Care HAP221 Air Purifier
It appears to have been on fire,surronding walls & unit covered i
hmmmm... maybe it was on fire... Barring that,
One thing to be aware of is how these things work: they don't actually filter the air. Rather, they electrically charge dust/dirt/etc. particles in the air as they pass through. This new charge makes them attracted to walls, floors, objects, etc. So rather than straining or filtering dust from the air (like a more traditional air filter), they make dust more likely to stick to walls, surfaces, etc. so that you can then wipe them up.
If there is something in the room that is manufacturing air pollutants, it could cause the problem you're having. The most likely culprit is anything that makes smoke. For example: smoking (duh), or burning CANDLES (especially scented candles) or INCENSE.
Jun 22, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Panasonic F-P10HU1 Air Purifier
I found one on Google - the part number for this is the F-Y15XS. A number of small online stores have it. Good luck!
Sep 08, 2008 | Panasonic F-P10HU1 Air Purifier
Need to buy replacement filters
Here is the link; http://www.hamiltonbeach.com/cgi-bin/main/co_disp/displ/pgname/trueair_home/strfnbr/20 Hope this helps :)
Dec 01, 2006 | True Air Plug-Mount Odor Eliminator with...
Air Purifiers Logo
128 people viewed this question
Top Panasonic Air Purifiers Experts
Jerry Kramer
Jerry Kramer
Tom Chichester
Joseph Hoffmann
Are you a Panasonic Air Purifier Expert? Answer questions, earn points and help others
