Question about Philips 60PP9352 60" Rear Projection Television
Tv picture crooked towards bottom right.
I recently moved a 19" SD tv to my new house, and now the picture is crooked towards the bottom right. Do you think I might have broken something while moving it?
    Filmmaker:
    Uploaded 5 video answers.
  • 162 Answers
I have a philips magnavox and had two problems that I recently fixed using kits from www.TvRepairKits.com. I can't say enough about their kits and help. Without them I would have never been able to fix my TV set myself.
The first problem I had was the TV was looking 3D. After doing some homework I found out that this is a convergence problem. I bought a kit, followed the instructions, and to my amazement fixed it myself.
After building my confidence with the 1st repair I decided to get their CRT fluid kit. This kit fixes the dull video,red video, or bright/halo looking video. If you have a magmavox set that is more than 5 years old your tv has this problem already. It happens on every set. As before I bought the kit, followed the instructions, and now my video looks factory new. Once again I wanted to say thanks to the team at Tv Repair Kits for putting together kits that the average joe can use.
ML
Posted on Aug 09, 2009
Our TV has been perfect for many years. We now suddenly have the picture compress, if you will, to the bottom 2/3's of the television screen, and it makes an angle like a triangle going toward the bottom....
This fault sounds like failure of the LINE OUTPUT TRANSFORMER.
It can be fixed, but may cost you around $120, possibly more if you have to call out an engineer.
Best NOT to use the TV as it is, because it could possibly damage the system.
If you do use it, this line will become permanent and if you get the TV fixed later, there will always be a burnt section of the screen where the line was - so I suggest you either pay to get it fixed right away, or consider buying a replacement.
Hope this helps!
Mar 08, 2011 | Sony KV-32S42 32" TV
My screen was hit with a doorknob and has a crack
It's cheaper to buy a whole new TV. I recently acquired a similar TV with a broken screen thinkink I could get a screen cheaper than a whole new TV. I found out different. If you find a place to get a screen cheaper than a new TV I would like to know about it.
Dec 08, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Bowing top and bottom temporary on cold TV
problem with unit is convergence--i would resolder convergence ics(they start with stk932-......)if that does not work replace them--if you need the exact part numbers email me at djstvrepair@comcast.net
Sep 15, 2009 | Pioneer SD-P50A3-K TV
Coloured lines on screen
Make sure first that the picture is centered by using the remote control to move the picture vertically and horizontally. Use the round pad towards the center of the remote and push the button according to which direction you want the frame to move.
Sep 10, 2009 | Philips 42 in. Plasma TV
No picture
I had a similar problem and got a TV repair man to fix it for real cheap. The whole fixing took less then 30 min and he goes to your house to fix the TV. He fixed it for an excellent price that left us astonished. He lives in NY. Email me if anyone needs his contact information. You wont be disappointed.
Mar 19, 2009 | Polaroid FLM-1911 19 in. LCD Television
RCA P52920BL (1999)
The fuse fails when the convergence power supply fails,putting a new fuse in the set will let the unit come back on but convergence is not working,check in screens in the menu to see if you have adj. projection t.v.,if the is not in the menu,replace reg ic part number 215530 on the convergence power supply,this board is above the right module mounted on the black plastic.,hope this helps
Feb 28, 2008 | RCA P52920BL 52" Rear Projection...
Picture crooked. skewed torwards bottom right corner.
replace convergance IC
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 11, 2007 | Philips 60PP9352 60" Rear Projection...
Blue out of whack around sides
I have the convergence problem with the red. After reading your site I replaced the 2 ICs and the problem is worse. Before the only problem was I could not adjust the red horizontal. Now I have no control over the vertical or horizontal and the overall picture is very red and it bows at the top and bottom very bad. A friend said I might have the ribbon connector in wrong or the convergence (silver box?) box maybe bad. Any ideas? Thanks,Dave.
Oct 12, 2007 | Philips 55PP9352 55" Projection Television
Picture and Sound fade in an out
4 years? Sounds like the lamp compartment is overheating. Take the covers off the right side (To Access the lamp) and the whole panel on back. This will give you access to the lamp assembly and fans. Get a can compressed air and blow everything out. Try to blow everything towards the right side and pull the lamp and do it seperatly.
Sep 09, 2007 | LG RU-52SZ51D 52" Rear Projection...
Phillips Big Screen Older Model
It means the fluid that cools each picture tube is low in the green but where did the fluid go,remove the back cover and check for a fluid leak towards the front side of the chassis and if any it should be right below one of the picture tubes.The description of your problem tell us you have a rear projection set but the heading shows a direct view tv.?????????? Since it was move the leak is only a possibility there could be other reason.Be careful and be sure set is unplug.
Sep 29, 2006 | Philips 32RF50S 32" TV
Philips 60PP9352 60" Rear Projection Television Logo
438 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
