Question about Exercise & Fitness
My Lifespan treadmill is showing an E1 error code. What would cause this ?
  • 2 more comments
  • Anonymous Mar 23, 2014
    E1 shows on my domyos treadmill what does it mean
  • Anonymous Mar 25, 2014
    Hi, my Lifespan Gold is coming up with a ER 3 code, I believe this has to do with the optic sensor? Where do I find this sensor to see if it is obstructed or damaged please?
  • Anonymous Mar 26, 2014
    wont turn on was working fine previously
  • Anonymous Mar 28, 2014
    Lifespan TR500. Belt stopped in middle of run. Error E1
My lifespan treadmill has an error code e1
Posted on Mar 21, 2010
  • 1 more comment
  • jlam247 Oct 08, 2010
    Here's an illustrated guide on how to fix this issue: http://fixmytreadmill.blogspot.com/2010/...
  • oldeagle926
    oldeagle926 Sep 28, 2012
    JLAM247'S Post is just advertising spam - You have to install software or take a survey to view the post. Waste of time
  • oldeagle926
    JLAM247's post is advertising spam - You need to install software or 'take a survey' to view the post..,. Waste of time.
2 Suggested Answers
  • 33 Answers
SOURCE: E1 error code
Your problem might be that the sensor magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
What does the trouble code 70 h95 mean
What does the trouble code 70 h95 mean - Fixya
www.fixya.com/support/t25932829-trouble_code_70_h95_mean
28 mins ago - what does the trouble code 70 h95 mean - Bowflex Treadmills question.
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - Please refer to the following table if your LifeSpan treadmill is displaying an error code. If after trying the suggested solutions your treadmill is .
Oct 30, 2015 | Bowflex Exercise & Fitness
Lifespan Pro3 - treadmill E1 error message
Hello
yes, your correct this could be the lower board with the issue.
The lower board could have blown a fuse, which you can check and replace quite easily. If the fuse is good look for other burnt spots on the board. The lower board may need repairing/replacing.
If the machine stopped while in use (after about 10min) then you will have a few other problems to check. Try adding silicone spray under the belt and if this has already been done then the running belt may need replacing.
E1 is never a good thing...
gymWorld.net.au
Jan 10, 2014 | LifeSpan Fitness Lifespan PRO3 -Treadmill-...
Error code E 7
proceed according you have two alternative: see the diagrams . God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jan 22, 2013 | LifeSpan Fitness Lifespan PRO3 -Treadmill-...
Lifespan tr200 e1
1) lube the deck belt.
2) lube the rollers bearing
3) measure the input voltage motor, if there are the motor need repair.
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
see the block diagram
Jun 29, 2012 | Lifespan TR200i Folding Treadmill
I have a LifeSpan TR1000-SL that stopped running. We are getting an E1 error code and do not know what this means or how to fix it. Ayy help you could provide would be much appreciated. Thanks in...
abrupt shutdown of the belt as the motor control detect a sharp increase in drive
current and inmediately stop driving belt.Some situation as jamming the belt may cause this error.Without such abuse should be a cause for extreme care and analysis for some Tech.
2 reason:
1) Motor drive; possible faulty(Test)
2) motor control board : possible faulty(Test)
Aug 09, 2011 | RTO Lifespan Fitness TR1000 Sl Treadmill
My treadmill is showing an E1 error code, what does this mean?
Your problem might be that a magnet has fallen off. Here's an illustrated guide that should make fixing it child's play: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jul 07, 2010 | RTO Lifespan TR1000TV - TR1000 With A TV...
I have a Tunturi j770 treadmill with error code E1. What does this mean please?
Buckmanservices.com solved the E1 code issue only $30 fixed it from online told me what to do
May 17, 2010 | Exercise & Fitness
My tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
May 16, 2010 | Exercise & Fitness
E1 error code
Good luck.
Jun 20, 2009 | Exercise & Fitness
Exercise & Fitness Logo
4,014 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
