Question about Apple Computers & Internet
I have a 2-year-old iMac all-in-one 216 Ghz Core 2 duo with OSX 10.4.11. For the last week or so, it has suddenly started doing weird things- little horizontal lines appear in some windows (these lines move with the windows, and sometimes disappear when I click near them), and the computer just goes blank sometimes- doesn't shut down completely, the screen just goes dark, and I have to restart it. I've been shutting it down a lot more than usual, rather than leaving it running continuously, since leaving it on seems to make it more likely to go blank or freeze. Help!
  • knittique Jul 24, 2009
    I don't know if this makes a difference or not, but your reply sounds like you think I have a laptop- it's a desktop. Sorry for the misunderstanding. Otherwise, what you said makes sense, in fact I thought myself it had to do with overheating, since I only starting having these problems when the weather suddenly got really hot.
    Thank you! Everything you're saying makes sense to me, since I had suspected overheating, but I would not have known what to do about it. Thanks again! -- Lindy
  • Apple Master
  • 13,433 Answers
This sounds like the video card is overheating or is already been damaged by overheating. Lines and such appear if the card gets too hot or the ram memory the card uses is faulty.
Both of those are not replaceable as they are both build into the same main board, in most laptops, which means that the whole mainboard of the computer would need to be replaced, basically that is like buying a new machine and it costs around the same.
If you are on warranty, your lucky, use your warranty. If your outside of warranty, the repair will not be cheap.
If it only happens when the machine has been used for a while and gets hot, changing the thermal grease on the cpu and video heat sinks might help a little(best left to experienced people) OR try one of those laptop cooling pads.
something like this one maybe: http://www.eforcity.com/pothxxnbfan3.html?efaffdnewtxt090720=dealnews+pothxxnbfan3
this is definitely a hardware problem or overheating.
Posted on Jul 24, 2009
  • Ekse Jul 24, 2009
    I forgot to mention that you could use canned air to blow dust out from the ventilation holes on the laptop and from the fans and its surroundings to get better airflow.
  • Ekse Jul 24, 2009
    Oh You have a Desktop, Yes I though you had a Mac Laptop.
    But this one seems to be one of those macs that are build into a display? so its pretty much the same thing as a laptop and I don't think that the video card would be replaceable if its faulty but I would have to look into it more to be sure.
    But sure you can use canned air, or open it up and clean the dust, with air only.
    maybe a local apple store or computer repairer can help you with the cleaning and possibly replacing the thermal grease that is used between the components and the heatsinks to transfer heat effectively.
    If you think you can do it yourself the stuff doesn't cost much.
How do I get my Stardoll for Facebook app working again?
You should use another P.C and if that hasn't helped you as well than I would suggest you to make another account.
-RedROse
Jun 02, 2013 | Stardoll AB Stardoll
How can I use my second monitor on the iMac via VPN/RDP?
Hi Jessiejeh55,
It sounds like you are using the Microsoft Remote Desktop Connection client for Mac.
  1. Open Remote Desktop Connection
  2. Select the connection you wish to use with both displays
  3. Right-click and choose Edit
  4. Check the "Use all monitors" box at the bottom
Thanks
Aug 01, 2012 | Apple 24" iMac Desktop
I'm having a problem with the website woozworld can you help?
Hi!
1. Check if pop up blocker is disable
2. Here are some specs I found on their website, you should check this to see any compatibility issues:
The high speed connection is essential to use Woozworld in an optimal way, due to the richness of the environment on the web site.
PC:
Windows : processor 1.5 GHz Intel Celeron or Core Duo (or equivalent) and superior, 1GB RAM
MAC:
OSX : 1.5 GHz Intel Core Duo and superior, 1GB RAM
Internet connection :
512 Kbits/seconds minimum (Cable/ADSL) or faster
Woozworld is incompatible with the Safari browser.
3. You can check any antivirus
4. As last resource you can try another internet browser (E.g.: Mozilla, GoogleChrome)
GoodLuck!
eBookBoy
http://digialreader.freeforums.org
Jul 11, 2011 | Woozworld
MA878LL iMac 24" core 2 duo 2.4 do not turn on,
Checking the power supply isn't the easiest thing to do, it involves pulling apart the entire machine.
You can try resetting the SMC, unplugging all power, hold the power button for 5 seconds, replace power, then attempt to turn on.
if it still won't turn on, and assuming you didn't get AppleCare or it is expired (past 3 years) it might be worth taking in to an Authorized Apple Repair Facility and see if they will check it out for free. If it is under warranty, most definitely take it in or call 1-800-APL-CARE
If neither of those are an option, Power Supply http://www.ifixit.com/Apple-Parts/iMac-Intel-24-Inch-2-4-2-8-GHz-or-3-06-EMC-No-2211-GHz-Power-Supply/IF169-002
a tear down from iFixit for the 20" model, it is most likely very similar for your model as well http://www.ifixit.com/Guide/Repair/Installing-iMac-Intel-20-Inch-EMC-2133-and-2210-Power-Supply/1006/1
Hopefully that helps. Good Luck
Feb 23, 2011 | Apple MA878LL iMac with 24" Screen Desktop...
I have imac. and i want to change his operating
Yes it is very easy to do as you are running a Mac with Intel Processor. You have Mac OSx Leopard with updates 1,2, & 3. To upgrade to Mac OSx Snow Leopard you must buy the upgrade. Go here: http://www.apple.com/macosx/ On the top right click (Buy Now) You will have to pay $29 which is a bargain. Once you get the upgrade on CD simply follow the directions for the simple upgrade. I did the same thing when Snow Leopard came out. It is well worth the $29.
May 29, 2010 | Apple 24 iMac - Intel Core 2 Duo 2.8GHz,...
Imac suddenly won't recognize 1 TB G-Drive
Hi there mu names Mark.
Lets see what I can do to help you.
Firstly some really obvious things
1 Is the light on the external drive
2 Is the USB/Firewaire cable connected at the Mac and the disk
3 If so reseat it by pulling it out of both ends and replacing
4 Have you tried another USB or Firewire port
something to be getting on with try those and re-post if no fix
regards from England
Mark
Aug 16, 2009 | G-Technology G-DRIVE (90801201) 250 GB...
Is imac g5 17" lcd compatible with imac intel core duo
Possibly, the newer G5 Imacs feature Intel 2 Core Duo Processers. While older generations, do not support Intel Core Duo or Intel 2 Core Duo Processers.
Jul 09, 2009 | Apple iMac 17" MA199LLA Desktop
Computers & Internet Logo
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
