The fuses are for base radio system. With key out, check the two outside fuse circuits for voltage. Shouldn't be any voltage, if there is, have to check ignition switch wiring circuits. Use a test lite to check for voltage
The fuse in the middle, hot all the time, should be for radio memory and clock where applicable.
Hi Shirley Main, What is the make and model number of this radio ?
Can you please add details in the comment box?
