Question about Canon PIXMA MP190 All-In-One InkJet Printer
Printer is not on it's alarm signal only on - Canon PIXMA MP190 All-In-One InkJet Printer
  • 744 Answers
Hi....take it to a tech to check about the system control chip... the control chip would have gone bad... and they will replace u with a new chip..
or else Try manually moving the head carriage back and forth a few times!
Also check, if there isn't some piece of paper lodged inside, if yes try to remove it carefully!..
these are the possible solutions u can try out...
thank u
rate me
Posted on Jul 24, 2009
Why my fridge freezer keeps beeping four hort beeps
Temperature alarm
If the temperature becomes too warm, an alarm will sound and the temperature display will flash. The temperature the appliance is set at will determine when the alarm is triggered.
The alarm will sound and the display will flash under the following conditions:
  • - whenevertoomuchwarmairflows into the appliance, for example when food is being loaded, re-arranged, or taken out.
  • - wheneverlargeamountsoffoodare being frozen at once.
  • - whenevertherehasbeenalengthy interruption of the power supply. Door alarm
    If the appliance door is left open for longer than approx. 60 seconds, the alarm signal will sound.
Switching the alarm system ON
The alarm system is always active. It does not need to be switched on manually.
Switching the alarm OFF early
Once the set temperature has been reached in the freezer section, the alarm signal stops and the temperature display stops blinking. If the alarm signal bothers you, it can be switched off early.
^ Press the alarm off button. The alarm signal will stop. The temperature display will continue to blink until the set temperature has been reached. The display then stops blinking, and shows a steady reading. At this point, the alarm system is ready again if needed.
Aug 15, 2014 | Miele KFN12923 SD-2 Fridge Freezer, A...
I loaded paper and alarm still worked
could be a broken or misplaced paper present sensor lever. When the paper tray is loaded and place back into the machine a "paper present sensor" is actuated and sends a signal back to the machines logic. If this sensor is broken or missing, it never sends the signal therefore the machine thinks its out of paper.
Nov 21, 2013 | Ricoh AFICIO SP4100NL MONO-LASERPR 31PPM...
I have a Casio 50M. I can't stop the alarm function. It seems to beep when it wants to. This watch has the REM feature. Help !!!
Hi trapmanjohn,
Man what an aggravating problem! Try this procedure.
1. To turn the daily alarm and time signal on and off:
2. In the Alarm mode, press "B" , upper right button, to cycle throught the on and off settings as follows:
Alarm on Indicator/Hourly Time Signal On Indicator
a. }}}} with Bell = Both alarms on
b. Display Blank = Both alarms OFF
c. }}}} = Daily alarm on only
d. Bell = Hourly time signal on only
The Alarm ( }}}} ) indicator flashes while the alarm is sounding.
The Alarm ( }}}} ) indicator and hourly time signal on BELL indicator are displayed in all modes.
To Test The Alarm: In Alarm Mode, hold down the "B" to sound the alarm.
Your Module number is #3171. Down an Operation Guide for the 3171 from here for more clarity:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3171.pdf
This should help you with nuisance...Good luck.
Regards, Bill
Sep 08, 2010 | Watches
Security system FOB inactive, battery good, no pin. Need to disarm. What can we try next?
You'll need the PIN number.
If you don't know it, you'll have to change it to a 5 digit PIN number you select.
With the fob present, turn IGN switch:
IGNITION-OFF-IGNITION-OFF-IGNITION
Press LEFT turn signal switch 3 TIMES
Press RIGHT turn signal switch 1 TIME and release
Turn signals will flash 3 times. Current PIN will appear in odometer. The first digit will be flashing.
If changing PIN, enter first digit (a) of new PIN by pressing LEFT signal switch (a) time(s) i.e., for the number 1, press one time. for the number 5, press 5 times.
Press RIGHT signal switch 1 TIME and release.
the new digit (a) will replace the current in odometer window.
Enter second digit (b) with LEFT signal switch.
Repeat until PIN is set.
Once PIN is set (either new or old PIN), to disarm security system, DO NOT sit on seat, lift bike off kick stand, or anything else that will activate the security mode!
Turn IGN to IGNITION.
Quickly (within 2 seconds) hold BOTH turn signal switches until confirmation signal (KEY icon flashes at fast rate, in odometer window, a flashing "-" will be followed by 4 more dashes = "----")
Enter 1st digit (a) in PIN by pressing LEFT turn signal switch (a) times (i.e., 5 times for the number 5)
The 1st "-" will become the 1st digit (i.e., "5")
Press RIGHT switch signal 1 TIME.
The 1st digit is stored and the dash will flash.
Enter 2nd digit (b), and repeat sequence until done.
After the 5th digit is entered, the KEY icon stops blinking, and the system is disarmed.
The system will stay off until the IGN switch is turned off.
If at any time during disarming sequence an error is made, wait 2 minutes before trying again.
Sep 05, 2009 | Harley Davidson FLSTFI Fat Boy Motorcycles
I refilled the ink of my printer, and when I'm about to use it, the printer keeps on alarming signifying that the printer is out of ink. well, in fact the ink cartridges were refilled already
depending on ur printer, some have a microchip on the cartridges and wen they are empty the micro chips knows and sends a signal to ur printer forcing u to buy new cartriges ,SNEAKY!!
Aug 30, 2009 | Office Equipment & Supplies
I have a Canon MP 160 printer with an alarm E-2 flashing - I have followed the steps to troubleshoot this but nothing works.
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-13
Aug 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Left turn signal not working proper
Turn signals flashing is the confirmation of alarm system being on.I thought both sides flashed but if alarm is faulty guess that's messed up too. Try starting from stratch with alarm,disarm it[disconnect neg wire at battery]then reconnect wire and when that sets off alarm turn it off in normal way.That should get things back on track.Plus,try replacing the flasher unit,don't know why this works but I've heard of it.
Apr 06, 2009 | 2001 Harley Davidson FXSTD - FXSTDI Deuce
Alarm and data lights are both on and when i go to print nothing happens
take y'r drum and toner out of the printer.. now there should be two translutent white circular film on either side of your toner... what u have to do is take a small piece of paper and make a bead out of it and insert that small paper bead right in front of those film.. u can insert on both side or on just one...
if u don't find those circular film then open y'r HL printer toner loading tray and turn y'r printer ON.... u will see green or red light coming out of either side of y'r printer where toner sits.. thats the place u should look for those film on y'r toner....
it worked for me... hope it works for u too...
PEACE..
Mar 15, 2008 | Brother HL 1440 Laser Printer
Canon PIXMA MP190 All-In-One InkJet Printer Logo
96 people viewed this question
old marine
old marine
